    firmware
    113 Posts 34 Posters 88.5k Views 32 Watching
    • F Offline
      fredg
      I'm coming from this tutorial: https://docs.pycom.io/chapter/tutorials/lopy/lorawan-nano-gateway.html
      You should update it probably to mention the "I'm using the legacy packet forwarder" for TTN network, and update the code to make it easy to extract the GATEWAY_ID.
      Or maybe update the code to allow any GATEWAY_ID for TTN? I'm not sure how it really works...
      J 2 Replies Last reply Reply Quote 1
        jmarcelino @fredg
        @fredg
        Thank you very much for your suggestion, TTN changed their language and gateway registration process recently - we'll update our documentation to reflect this.
          jmarcelino @fredg
          @fredg
          I've updated the Nano-gateway documentation to show how to generate a Gateway ID and also to reflect the changes in the TTN interface: https://docs.pycom.io/chapter/tutorials/lopy/lorawan-nano-gateway.html
          Thanks again for your suggestion!
            Devang Sharma
            @daniel, I live in India. While registering the gateway, which frequency plan I should choose? Can I choose Europe or do I have to choose Asia?
            Thanks.
              jmarcelino @Devang Sharma
              @devang-sharma
              India has a unique Frequency plan:
              https://kotahi.net/network/frequencies/
              I recommend setting your config.py for the nano gateway and nodes to
              LORA_FREQUENCY = 865062500
              and make sure your nodes use this 865062500 frequency as well:
              # set the 3 default channels to the same frequency
              lora.add_channel(0, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=5)
              lora.add_channel(1, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=5)
              lora.add_channel(2, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=5)
                Devang Sharma @jmarcelino
                @jmarcelino, thanks. I've sent them an e-mail in order to get a free network connection. I hope they'll reply soon.
                  Devang Sharma
                  @jmarcelino, KotahiNet does not provide free connectivity in India. Also, they provide private LoRaWAN network only to the larger companies.
                  Is it possible to connect one LoPy(acting as a node) to connect with another LoPy(acting as a Gateway) without such LoRaWAN network?
                  If yes, can you guide me how to achieve it?
                  My question might not seem a good one, but I'm really new to LoRa.
                  Thanks.
                    livius @Devang Sharma
                    @devang-sharma said in New firmware release 1.6.7.b1 (LoRaWAN Nano Gateway with TTN example!!):
                    look at examples
                    in doc
                    https://docs.pycom.io/chapter/tutorials/lopy/lopy-lopy.html
                    and sources on git
                    https://github.com/pycom/pycom-libraries/tree/master/examples
                      Devang Sharma @livius
                      @livius Thanks. I was looking into docs and I found the examples. Though they needed modifications, it worked perfectly.
                        rvandam
                        I have a setup with a node and a nano gateway with the latest default script from Github. The data is received in the TTN backend, so that part is working.
                        I want to update the date and time on the nodes over Lora (no wifi) I discovered that no rx data is received on the node. Could you give me a hint how to configure the gateway to send back the current time to the node?
                          jmarcelino @rvandam
                          @rvandam
                          In LoRaWAN with TTN (Class A) you must send data from the node in order to receive any messages back.
                          But if you queue a downlink with TTN you should receive it in your node - for example with data = s.recv(64) - once you've done an uplink (an s.send(...) ).
                            rvandam @jmarcelino
                            @jmarcelino thank you for your reply!
                            When I add some data in the downlink field in the TTN backend, this data is received by the node. This is already one more step forward :-)
                            Should I see the gateway as a "dumb" packet forwarder, and do the logic on the node and the TTN side?
                              jmarcelino @rvandam
                              @rvandam
                              Glad you managed to receive data.
                              Yes, that's exactly what LoRaWAN gateways are :) They don't send or receive anything on their own, that's the job for the network server.
                                rvandam @jmarcelino
                                @jmarcelino thank you again. This makes much sense. I was looking on the wrong end.
                                • V Offline
                                  Vicky_
                                  @jmarcelino I live in Malaysia. May i know what frequency should i use? i have tried to search but i couldn't find.
                                  Thanks.
                                    jmarcelino @Vicky_
                                    @vicky_
                                    Malaysia uses the AS923 plan:
                                    https://www.thethingsnetwork.org/wiki/LoRaWAN/Frequencies/Frequency-Plans#lorawan-frequencies_as923
                                      bilou7
                                      Hello Daniel,
                                      Did you add the functionality : "Ability to receive packets sent on any spreading factor" to the lopy gateway ?
                                      Thanks in advance
                                        researcher
                                        Hello guys, regarding this code here at https://github.com/pycom/pycom-libraries/tree/master/examples/lorawan-nano-gateway
                                        When I am trying to use the config for both, node and nano-gtw, with the AU915 configuration and change the following parameters into:
                                        LORA_FREQUENCY = 915200000
                                        LORA_GW_DR = "SF10BW125"
                                        LORA_NODE_DR = 2
                                        Because on LoraWAN Regional Parameters v1.1rb it says on page 37 that for OTAA procedure, the JoinReq message should be sent with DR2 data rate when BW = 125 kHz.
                                        But when uploading the code, it outputs an error regarding that the following function has an error:
                                        lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0, dr=config.LORA_NODE_DR)
                                        However, it works when I change the config file into:
                                        LORA_NODE_DR = 0
                                        LORA_GW_DR = "SF12BW125"
                                        Am I doing something wrong? Maybe not understanding correctly the technical specification?
                                        Thanks in advance
                                          Bert J Zazueta
                                          • 5
                                          • 6
                                          • 6 / 6
