@livius Thanks. I was looking into docs and I found the examples. Though they needed modifications, it worked perfectly.
I have a setup with a node and a nano gateway with the latest default script from Github. The data is received in the TTN backend, so that part is working.
I want to update the date and time on the nodes over Lora (no wifi) I discovered that no rx data is received on the node. Could you give me a hint how to configure the gateway to send back the current time to the node?
@rvandam
In LoRaWAN with TTN (Class A) you must send data from the node in order to receive any messages back.But if you queue a downlink with TTN you should receive it in your node - for example with
data = s.recv(64)- once you've done an uplink (an s.send(...) ). -
@jmarcelino thank you for your reply!
When I add some data in the downlink field in the TTN backend, this data is received by the node. This is already one more step forward :-)
Should I see the gateway as a "dumb" packet forwarder, and do the logic on the node and the TTN side?
@rvandam
Glad you managed to receive data.Yes, that's exactly what LoRaWAN gateways are :) They don't send or receive anything on their own, that's the job for the network server.
@jmarcelino thank you again. This makes much sense. I was looking on the wrong end.
@jmarcelino I live in Malaysia. May i know what frequency should i use? i have tried to search but i couldn't find.
Thanks.
Malaysia uses the AS923 plan:
https://www.thethingsnetwork.org/wiki/LoRaWAN/Frequencies/Frequency-Plans#lorawan-frequencies_as923
Hello Daniel,
Did you add the functionality : "Ability to receive packets sent on any spreading factor" to the lopy gateway ?
Thanks in advance
Hello guys, regarding this code here at https://github.com/pycom/pycom-libraries/tree/master/examples/lorawan-nano-gateway
When I am trying to use the config for both, node and nano-gtw, with the AU915 configuration and change the following parameters into:
LORA_FREQUENCY = 915200000
LORA_GW_DR = "SF10BW125"
LORA_NODE_DR = 2Because on LoraWAN Regional Parameters v1.1rb it says on page 37 that for OTAA procedure, the JoinReq message should be sent with DR2 data rate when BW = 125 kHz.
But when uploading the code, it outputs an error regarding that the following function has an error:
lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0, dr=config.LORA_NODE_DR)
However, it works when I change the config file into:
LORA_NODE_DR = 0
LORA_GW_DR = "SF12BW125"Am I doing something wrong? Maybe not understanding correctly the technical specification?
Thanks in advance
