Guru Meditation Error of type LoadProhibited occurred on core.
Please be aware that there are also a number of difference between the pyboard and the Pycom devices namely that Pycom doesn't use the pyb library and that a number of the standard classes/methods are different.
I think my issue might actaully be related to this post: https://forum.pycom.io/topic/1061/https-post-using-urequests-py-and-guru-mediation-error
the urequest class and nothing to do with the ultrasonic sensor.
@tobz Ah ok, you are using the urequests library? We're looking into this.
@bucknall Cool. I'll follow along with that thread & hopefully that IS my issue and it gets resolved :)
@tobz Did you manage to get the HC-SR04 working after all?
@RobTuDelft yeah the sensor works fine (once I worked out you need a resistor in the circuit - derp). The crash appears to be caused by the urequest library (see https://forum.pycom.io/topic/1061/https-post-using-urequests-py-and-guru-mediation-error).
@tobz That's nice, could you share your code perhaps? Got one of these sensors coming in soon and would help to have a starting point.
@RobTuDelft sorry - I've been head down in work - will hopefully get some time later this week & post my code if you're still interested in it.
@RobTuDelft Here's the code I was using for the HC-SR04.
I hope it makes sense & works for you.import machine import time import math from machine import Timer class Ultrasonic: def __init__(self, name, trigPin, echoPin, delay = 60): self.name = name self.triggerPin = trigPin self.echoPin = echoPin self.delay = delay self.last_distance = 0 # Init trigger pin (out) self.trigger = machine.Pin(self.triggerPin) self.trigger.init(machine.Pin.OUT, None) self.trigger.value(False) # Init echo pin (in) self.echo = machine.Pin(self.echoPin) self.echo.init(machine.Pin.IN) def distance_in_inches(self): return (self.distance_in_cm() * 0.3937) def distance_in_cm(self): start = 0 end = 0 # Create a microseconds counter. micros = Timer.Chrono() micros.reset() micros.start() # Send a 10us pulse. self.trigger.value(True) Timer.sleep_us(10) self.trigger.value(False) # Wait 'till whe pulse starts. while self.echo.value() == 0: start = micros.read_us() # Wait 'till the pulse is gone. while self.echo.value() == 1: end = micros.read_us() # Deinit the microseconds counter micros.stop() # Calc the duration of the recieved pulse, divide the result by # 2 (round-trip) and divide it by 29 (the speed of sound is # 340 m/s and that is 29 us/cm). dist_in_cm = ((end - start) / 2) / 29 return dist_in_cm def start(self, threshold, callback): print('Start reading Ultrasonic Sensor') while True: # get the current distance distance = self.distance_in_cm() # if the distance between this reading and the previous one # and the difference is greater than the threshold then # run the callback method if (math.fabs(self.last_distance - distance) > threshold): print("%s value: %s -> %s at %s" % (self.name, self.last_distance, distance, time.time())) if callback(self.name, distance) is True: # set this readding as the previous reading for next run self.last_distance = distance else: print("%s value: %s <-> %s at %s" % (self.name, self.last_distance, distance, time.time())) time.sleep(self.delay)useage:
// init sensor, reading every 60 seconds sensor = Ultrasonic('some-name', triggerPin, echoPin, 60) sensor.start(changeThreshold, callbackMethod) -
@tobz Thanks a lot for sharing the code. How did you connect the sensor to the board? You mentioned something about a resistor you had to use?
@tobru From memory I think it was a 10k resister - check the spec sheet for the HC-SR04. I probably just attached it straight onto the expansion board, maybe via a breadboard - I can't remember sorry.
