Guru Meditation Error of type LoadProhibited occurred on core.
 I'm running a basic all reading a distance from an HC-SR04 ultrasonic sensor, & after a shortish(irregular) amount of time the board crashes with the following message: Guru Meditation Error of type Load Prohibited occurred on core 0. Exception was unhandled. Register dump: PC : 0x400869c6 PS : 0x00060037 A0 : 0x80085b58 A1 : 0x3ff81c50 A2 : 0x3ff81cac A3 : 0x3ff81c70 A4 : 0x00000020 A5 : 0x3ffc397c A6 : 0x00000005 A7 : 0x3ffae010 A8 : 0xe67ec000 A9 : 0x3ffb6db8 A10 : 0x3ff81cac A11 : 0x3ffc3a88 A12 : 0x3ffb6db8 A13 : 0x3ffae020 A14 : 0x3ffae040 A15 : 0x3ffae6c0 SAR : 0x0000001f EXCCAUSE: 0x0000001c EXCVADDR: 0xe67ec004 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0x00000000 Backtrace: 0x400869c6:0x3ff81c50My code is based on this: https://github.com/mithru/MicroPython-Examples/blob/master/08.Sensors/HC-SR04/ultrasonic.py Anyone have any idea what this means & what can be done about it?
 @tobru From memory I think it was a 10k resister - check the spec sheet for the HC-SR04. I probably just attached it straight onto the expansion board, maybe via a breadboard - I can't remember sorry.
 @tobz Thanks a lot for sharing the code. How did you connect the sensor to the board? You mentioned something about a resistor you had to use?
 @RobTuDelft Here's the code I was using for the HC-SR04.
 I hope it makes sense & works for you.import machine import time import math from machine import Timer class Ultrasonic: def __init__(self, name, trigPin, echoPin, delay = 60): self.name = name self.triggerPin = trigPin self.echoPin = echoPin self.delay = delay self.last_distance = 0 # Init trigger pin (out) self.trigger = machine.Pin(self.triggerPin) self.trigger.init(machine.Pin.OUT, None) self.trigger.value(False) # Init echo pin (in) self.echo = machine.Pin(self.echoPin) self.echo.init(machine.Pin.IN) def distance_in_inches(self): return (self.distance_in_cm() * 0.3937) def distance_in_cm(self): start = 0 end = 0 # Create a microseconds counter. micros = Timer.Chrono() micros.reset() micros.start() # Send a 10us pulse. self.trigger.value(True) Timer.sleep_us(10) self.trigger.value(False) # Wait 'till whe pulse starts. while self.echo.value() == 0: start = micros.read_us() # Wait 'till the pulse is gone. while self.echo.value() == 1: end = micros.read_us() # Deinit the microseconds counter micros.stop() # Calc the duration of the recieved pulse, divide the result by # 2 (round-trip) and divide it by 29 (the speed of sound is # 340 m/s and that is 29 us/cm). dist_in_cm = ((end - start) / 2) / 29 return dist_in_cm def start(self, threshold, callback): print('Start reading Ultrasonic Sensor') while True: # get the current distance distance = self.distance_in_cm() # if the distance between this reading and the previous one # and the difference is greater than the threshold then # run the callback method if (math.fabs(self.last_distance - distance) > threshold): print("%s value: %s -> %s at %s" % (self.name, self.last_distance, distance, time.time())) if callback(self.name, distance) is True: # set this readding as the previous reading for next run self.last_distance = distance else: print("%s value: %s <-> %s at %s" % (self.name, self.last_distance, distance, time.time())) time.sleep(self.delay)useage: // init sensor, reading every 60 seconds sensor = Ultrasonic('some-name', triggerPin, echoPin, 60) sensor.start(changeThreshold, callbackMethod)
 @RobTuDelft sorry - I've been head down in work - will hopefully get some time later this week & post my code if you're still interested in it.
 @tobz That's nice, could you share your code perhaps? Got one of these sensors coming in soon and would help to have a starting point.
 @RobTuDelft yeah the sensor works fine (once I worked out you need a resistor in the circuit - derp). The crash appears to be caused by the urequest library (see https://forum.pycom.io/topic/1061/https-post-using-urequests-py-and-guru-mediation-error).
 @tobz Did you manage to get the HC-SR04 working after all?
 @bucknall Cool. I'll follow along with that thread & hopefully that IS my issue and it gets resolved :)
 @tobz Ah ok, you are using the urequests library? We're looking into this. Thanks!
 I think my issue might actaully be related to this post: https://forum.pycom.io/topic/1061/https-post-using-urequests-py-and-guru-mediation-error the urequest class and nothing to do with the ultrasonic sensor.
 Please be aware that there are also a number of difference between the pyboard and the Pycom devices namely that Pycom doesn't use the pyb library and that a number of the standard classes/methods are different.
 @tobz Can you please list where in your code that this error occurs?
