Woks from Atom RUN but not when uploaded
Hi forum,
I'm new and I'm testing for a research project a monitoring solution based on LoPy. So fa I have added two DS18B20 to the LoPy + PySense. The strage things is that when i run the code from the Pymkr in Atom it correctly read the DS18B20 temperatures, but when I upload the code on the LoPy the reading is None.Doe anyone have any idea or similar experience? Where should I look to start debugging?
import time from lib.onewire import DS18X20 from lib.onewire import OneWire ow1 = OneWire(Pin('P4')) ow2 = OneWire(Pin('P8')) time.sleep(1) temp1 = DS18X20(ow1) temp2 = DS18X20(ow2) while True: print("T1:",temp1.read_temp_async(temp1.roms[0])) time.sleep(1) temp1.start_conversion() time.sleep(1) print("T2:", temp2.read_temp_async()) time.sleep(1) temp2.start_conversion() time.sleep(1) -
It looks like it needs a double scan to find the rom.
After inserting
ow1 = OneWire(Pin('P4')) print('found devices:', ow1.scan())Even if the print is an empty array ('found devices:[]') then the temperature reading is working with appropriate rom...
Anyone can get why?
Maxi
