    Woks from Atom RUN but not when uploaded
    ds18b20pymakrpysense
    2 Posts 1 Posters 685 Views 1 Watching
      maxi
      Hi forum,
      I'm new and I'm testing for a research project a monitoring solution based on LoPy. So fa I have added two DS18B20 to the LoPy + PySense. The strage things is that when i run the code from the Pymkr in Atom it correctly read the DS18B20 temperatures, but when I upload the code on the LoPy the reading is None.
      Doe anyone have any idea or similar experience? Where should I look to start debugging?
      from lib.onewire import DS18X20
      from lib.onewire import OneWire
      ow1 = OneWire(Pin('P4'))
      ow2 = OneWire(Pin('P8'))
      time.sleep(1)
      temp1 = DS18X20(ow1)
      temp2 = DS18X20(ow2)
          print("T1:",temp1.read_temp_async(temp1.roms[0]))
          time.sleep(1)
          temp1.start_conversion()
          time.sleep(1)
          print("T2:", temp2.read_temp_async())
          time.sleep(1)
          temp2.start_conversion()
          time.sleep(1)
        maxi
        It looks like it needs a double scan to find the rom.
        After inserting
        print('found devices:', ow1.scan())
        Even if the print is an empty array ('found devices:[]') then the temperature reading is working with appropriate rom...
        Anyone can get why?
        Maxi
