FiPy microcontroller network compatibility/compliance
 Hello all, In Greece, the cellular provider COSMOTE is opening up their Narrowband network and its frequency will be LTE @800MHz.
 I would like to verify that the microcontroller listed here: https://gr.mouser.com/ProductDetail/Pycom/FiPy?qs=%2Fha2pyFaduiN1LDUqXKJgtbmxvyrxeuC%2bZqv%2blXdLnwFzvBRdcyq0TD%2FdejF%2FrUIis compliant to be used with this frequency. I checked the spec sheet on the site, and found no mention of this. I need it verified by someone, before we can purchase the part for development. A quick response would be greatly appreciated.!
 Thank you,
 M.
 @marilenam
 Ok, but please note there is a lot more to NB-IoT than just the frequency.
 Yes, my provider confirms they are testing on this band, so we're good compatibility wise. Thank you very much for your prompt responses!
 @marilenam
 The guaranteed option is to contact your operator directly and ask what they support, all operators run testing/certification programs
 so in this case, how would you recommend going about finding a module that I can be sure will work here in Greece in that band range? thank you
 Our module works with Band 20 (800Mhz) but I cannot guarantee when/if we will work with that particular operator yet.
