    LOPY in case running on battery
    batterybattery connectgetting startednew
    10 Posts 4 Posters 3.0k Views 4 Watching
      thr
      I'm new to LOPY world. I would like to know what is required to get LOPY to run on battery and what sort of battery / connector I need so I can order all the parts I need at the same time.
      Do I need to connect LOPY to the expansion board or to PyTrack and then connect that a battery to power LOPY?
      Or can I connect some type of battery directly to LOPY?
      What sort of battery will I need?
        robert-hh @thr
        @thr The most conevient is a rechargable LiPo battery, connected to the expansion board. Theer are plenty available with the matching connector. Go for capacities of at least 1000 mAh. You can also connect a LiPo battery directly to Vin/GND of the module. The only thing to consider is not to exceed 5.5V at Vin.
        • sebS Offline
          seb
          Adafruit sell many compatible batteries: https://www.adafruit.com/category/889
          Just be careful when purchasing from other suppliers that the battery polarity is correct. I have had to swap the connector polarity on many batteries with JST-PH connectors in order to use them with Pycom products.
            rskoniec
            • any 1-cell LiPo 3.7V battery (with needed capacity) should be OK
            • JST 2-pin connector with 2.0mm raster
            • Expansion Board 2.0 / Pysense / Pytrack has built-in LiPo battery charger
            Also look here
              thr @robert-hh
              Thank you very much @robert-hh
              @robert-hh said in LOPY in case running on battery:
              Will I need some sort of battery management or regulator for this? Or do the batteries provide this?
              Can I use the PyTrack? And separately, can I use the PyTrack to program LOPY (thereby avoiding buying the expansion board)?
                robert-hh @thr
                @thr You can use the pytrack shield for both battery connection and programming. Pytrack has a battery charger on board and the USB/Serial bridge to suuport programming and firmware update.
                  thr @rskoniec
                  Thanks. All.
                  Think I'll buy a LOPY with the PyTrack and IP67 Case for Pysense/Pytrack. That way I can use the Pytrack to program and connect to a LiPo battery!
                  Pardon the newbe question, but does that mean I can attach a LiPo battery to the PyTrack and then attach the PyTrack to the USB port of my PC and it will slowly charge up the LiPo until I unplug it form USB computer / power?
                  Or do I need to buy something like this also: https://www.adafruit.com/product/1904
                    robert-hh @thr
                    @thr said in LOPY in case running on battery:
                    Yes, you can charge the LiPo battery through the USB port, either using the PC or any other USB power adapter.
                      thr @robert-hh
                      If I wanted to also do this as well as using the PyTrack as mentioned above, how do I go about it?
                      Is it simply a matter of attaching a LiPo battery direclty to the Vin/GND?
                      Do I need something else? An adapter or power regulator?
                        robert-hh @thr
                        @thr If you are using Pytrack, connect the battery to the dedicated battery connector on Pytrack.
                        With your input, this post could be even better šŸ’—
