I need working code for LoRaWAN
Once you have successfully joined, sending data is simple:
s = socket.socket(socket.AF_LORA, socket.SOCK_RAW) # Can be used to force a specific data rate / spread factor #s.setsockopt(socket.SOL_LORA, socket.SO_DR, 0) s.setsockopt(socket.SOL_LORA, socket.SO_CONFIRMED, 0) s.send(bytes([your,data,here])); -
@jcaron I want to send the following bytes: Payload (Hex) 03 67 01 10 05 67 00 FF
Can you show me the correct formating I should use in the brackets? -
@miroslav-petrov There are many ways to do it, but you can do it this way:
s.send(bytes([0x03, 0x67, 0x01, 0x10, 0x05, 0x67, 0x00, 0xff]))An alternative would be:
s.send(binascii.unhexlify("03 67 01 10 05 67 00 FF".replace(" ","")))The latter requires an
import binasciiif you don't already have it, but you probably have it already for the OTAA credentials. -
@jcaron
This is a screenshot showing my code and a telnet window to my LoPy after opening the script. I got this "B'" " after executing the script and I get nothing in the application.
@miroslav-petrov try setting the data rate explicitly to 0. How far away is the gateway? Is in indoors or outdoors? What kind of antenna are you using?
It takes quite a while to join, which probably indicates pretty bad communication...
@jcaron said in I need working code for LoRaWAN:
I am using a local LoRa operator and I don't know where the gateway is. But I don't think the bad connection is the problem since I get a "Network joined!" Do you happen to know where this b" comes from?
@miroslav-petrov that b' ' means that you recieved and empty package, otherwise you should have b'your_message_here'. I think you should swipe line 19 and 18, setblocking it before the data transmision.
@miroslav-petrov There's something weird in your screenshot... The console output shows "Network joined!", but that does not appear in your code? Are you sure you are running the right script?
@miroslav-petrov Hi I am new as you too. The same problem of you, may I ask if you finish the connection now, if worked can you share your code. Many thanks!
@rachelsimida I gave up. I have my LoPy for 1 year and I cannot find a single working code that reads a sensor (dht22 for example) and sends it to the things network.
