New firmware release v1.17.0.b1 (Completely new LTE class)
  • @robert-hh Thank you! That is exactly what I was looking for.
  • @losi I think it's selected automagically. But besides that, all files are here: https://github.com/pycom/pycom-micropython-sigfox/releases/tag/v1.17.0.b1
    You will need one of the xxx.tar.gz files.
  • @rskoniec Okay, so I can use the v1.12.0.b0 updater tool, which I have installed. I also see the selection for uploading alternate firmware.
    Now where is the v1.17.0.b1 image hiding? I don't see any link on this post containing this image.
  • @colateral Backtrace output:
    Decoding 8 results
    0x400dbec8: system_get_rtc_time at /Users/danicampora/Code/Espressif/IDF/esp-idf-20180112/components/newlib/./time.c line 261
    0x4009a73c: memcpy at /home/jeroen/esp8266/esp32/newlib_xtensa-2.2.0-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/machine/xtensa/../../../../.././newlib/libc/machine/xtensa/memcpy.S line 168
    0x4009a76a: memcpy at /home/jeroen/esp8266/esp32/newlib_xtensa-2.2.0-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/machine/xtensa/../../../../.././newlib/libc/machine/xtensa/memcpy.S line 201
    0x40084c65: SX1272OnDioIrq at D:\Colateral\Programming\pycom\pycom-micropython-sigfox\esp32/../drivers/sx127x/sx1272/sx1272.c line 1039
    0x40083f0b: machpin_intr_process at D:\Colateral\Programming\pycom\pycom-micropython-sigfox\esp32/mods/machpin.c line 187
    0x40083585: _xt_lowint1 at /Users/danicampora/Code/Espressif/IDF/esp-idf-20180112/components/freertos/./xtensa_vectors.S line 1105
  • @jcaron with my tests that's the behavior.
    • With ADR enabled, it start with DR0 and change when LS send LinkADRReq.
    • With ADR disabled, Lopy started with DR defined in setsockopt. In this case LorawanServer don't send LinkADRReq command, when we try to manually adjust DR. Since ADR bit is disabled, i suppose that LS don't even try to send the command.
  • @losi said in New firmware release v1.17.0.b1 (Completely new LTE class):
    @seb Your link points to release v1.12.0.b0, which is why i asked.
    Let's clear something:
    v1.12.0.b0 is the newest version of the Updater Tool.
    v1.17.0.b1 is the newest version of the Firmware.
    So @seb gave you right answer.
  • @seb Your link points to release v1.12.0.b0, which is why i asked.
  • @daniel @Xykon @seb Thanks for the Linux software updater. I ignored that since a while, and I am still not using it for software updates, but it has a lot of other management options, which are very useful.
  • Board: L01
    CRASH with flash erase. This is happening often after sending multiple Lora messages as request and receiving a Lora message as response in a simple Lora - Lora connection.
    Can someone explain why ESP32 is flashed? - my scripts are erased and also main.py and boot.py are restored to default.
    I checked also with uos.listdir() and there are a lot of junks (see below after crash uput)
                Guru Meditation Error: Core  1 panic'ed (Cache disabled but cached memory region accessed)
                Register dump:
                PC      : 0x400dbec8  PS      : 0x00060034  A0      : 0x80084c68  A1      : 0x3ffc1390
                A2      : 0x3ffc784c  A3      : 0x00000001  A4      : 0x8008bf73  A5      : 0x3ffc13a0
                A6      : 0x00000020  A7      : 0x00000020  A8      : 0x80084a58  A9      : 0x3ffc1370
                A10     : 0x00000012  A11     : 0x3ffc1391  A12     : 0x3ffc1391  A13     : 0x3ffc7864
                A14     : 0x3ffc7854  A15     : 0x00000402  SAR     : 0x0000000e  EXCCAUSE: 0x00000007
                EXCVADDR: 0x00000000  LBEG    : 0x4009a73c  LEND    : 0x4009a76a  LCOUNT  : 0x00000000
                Backtrace: 0x400dbec8:0x3ffc1390 0x40084c65:0x3ffc13c0 0x40083f0b:0x3ffc13f0 0x40083585:0x3ffc1410 0x400621f9:0x00000000
                LCgAAA0AAABsAQAA
                UDj9P+A2/T9IOP0/
                4Db9P+A3/T9UkePQ6FH8P+hR/D9QOP0/4FH8PwEAAADIav0/yGr9P1A4/T8AAAAA
                GAAAAEw0/T9pcGMwABVA5g5OoraPJm8AAAAAAEg4/T8AAAAAJQAGABgAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAA0Z/0/nGf9PwRo/T8AAAAAAAAAAAEAAAAAAAAA
                ullAPwAAAAAcrwlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKi2sQ==
                NDMIQH5XCEA0DwYAmh0IgKA3/T8AAAAAAQAAAJBq/T8AAAAAAQAAAAAAAAAEpPw/
                AAAAAAEAAABMAAASBBn8PwEAAAD+AAAAFwAAAAAAAAAHAAAAAAAAAAAAAAAAAAAA
                AAAAAAQZ/D8BAAAAVDAIQHjm+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAACGIAAA/gAAABcAAAAAAAAAwDf9P9hO/D/ITvw/
                6Gr9PwAAAACcav0/AAAAAAAAAADgN/0/AAAAAAAAAABAVwhAAAAAAAAAAAAAAAAA
                NRIIgEA8/j9kT/w/bE/8PwAAAAAAAAAA7Df9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                IFv9P6BZ/T8YW/0/
                oFn9P7Ba/T+NvCD1nGD9PwhQ/D8gW/0/AFD8PxkAAABqGlDhXg+IxSBb/T8AAAAA
                AAAAABxX/T9JRExFAPOBHrhQ9qfnu4AAAAAAABhb/T8AAAAAIQAGAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD7VKQ==
                NDMIQMTmFEAwDwYA4L4IgGBa/T8gAAAAAQAAAAAAAACUpvw/9FH8P5xP/D+wpvw/
                QFr9PwAAAAD4OAhAIA0GAGBR/T8DAAAAIwAGAAAAAABgWv0/OEL9PwAAAAAAAAAA
                AAAAAC01CEBgUf0/SM0IQEgJ+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAAgFr9PwAAAAAAAAAA
                AAAAAAQZ/D/0Ufw/nE/8PwAAAACwWv0/AAAAAAAAAAAEGfw/AAAAAAAAAAAAAAAA
                AQAAAAAAAAAEAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALxa/T8AAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
                lGD9PxBf/T+MYP0/
                EF/9PyBg/T9eWJqiCFD8Pyhb/T+UYP0/AFD8PxkAAACIFjsVs8Kan5Rg/T8AAAAA
                AAAAAJBc/T9JRExFACa9xXw2jMuuC8gAAQAAAIxg/T8AAAAAIwAGAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAOBFug==
                NDMIQMTmFEAwCgYA4L4IgNBf/T8gAAAAAQAAACAAAACUpvw/+FH8P5xP/D/Qpvw/
                sF/9PwAAAAAAAAAAAAAAAPCb/T8DAAAAIwAGAAwAAADQX/0/IAAAAPhvDkA0cA5A
                AAAAAC01CEDwm/0/SM0IQLgO+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAA8F/9PwAAAAABAAAA
                IAAAAJSm/D/4Ufw/nE/8PwAAAAAgYP0/AAAAAAAAAAAEGfw/AAAAAAAAAAAAAAAA
                AQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACxg/T8AAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
                BGL9P0B1/T+Ydv0/
                QHX9PzB2/T+HIAAAWGv7P0RV/T8EYv0/7E/8Pw8AAADQa/0/0Gv9PwRi/T/Ia/0/
                CgAAAJxs/T9UbXIgU3ZjAMBjrnOpEqcAAAAAAJh2/T8AAAAAIQAGAAoAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABcGTw==
                NDMIQJnLCEAwAQYAAAAAAAB2/T8BAAAAhyAAAAAAAAAEUvw//FH8P4YgAACZywiA
                4HX9PwAAAAAEGfw/AAAAAAAAAAAAAAAAAAAAACAAAADIJPk/AAAAADynCUBqpwlA
                AAAAAC01CEAAAAAASM0IQMgk+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABgAAAAAAAAAMHb9PwAAAAAAAAAA
                AAAAACgIAAB04/0/AAAAAAAAAAAEUvw//FH8P1ogAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAA8dv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAA=
                UGv7P1Bp+z9Ia/s/
                UGn7P+Bq+z+HIAAAjGP9Pwxi/T9Qa/s/7E/8PxMAAACgFP306bsvWlBr+z8AAAAA
                BgAAAExh+z9Mb1JhAEACTFqOUf/RMYAAAQAAAEhr+z8AAAAAIQAGAAYAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABOyiA==
                NDMIQFC+CEAwDgYAUhwQgBBq+z+HIAAA+FH8PwQZ/D8BAAAAAAAAAAAAAABQvgiA
                8Gn7PwEAAACHIAAAUGv7PwEAAAD+AAAAEAAAAA4AAACDafs/ZHj8PyCpCUArqQlA
                AAAAAC01CEABAAAASM0IQHgZ9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAgAAAAAAAAAAQAAAAAAAAAAAAAAMGr7P8hk/D8EAAAA
                B////0x4/D8BAAAAAAAAAAAAAADgavs/AAAAAAAAAAAIAAAAAAAAAAAAAAABAAAA
                AAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAB4Gfc/AAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAZvw/CwAAAGzhQj8BAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA7Gr7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                hGP9P1BL/T8wTf0/
                UEv9P9BM/T/CIAAA9E/8P1hr+z+EY/0/7E/8PwcAAAD4rv0/+K79P4Rj/T/wrv0/
                EgAAADQ//T90aVQAdACZ0es3LF7mEIQA////fzBN/T8AAAAAIQAGABIAAAABAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANrEAA==
                NDMIQAixCEAwDQYArYAWgBBM/T/Mrv0/oEz9Pxiv/T8AAAAAIK/9PwAAAAAIsQiA
                8Ev9PwAAAABkAAAA9FH8PwAAAAAEGfw/AAAAAB8AAAAAAAAAAAAAAJFrFkCaaxZA
                AAAAAC01CEAAAAAASM0IQGj7+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAACBM/T8ATP0/DAAAABSv/D/xBRaAUEz9P6Sp/D+gTP0/
                AAAAAF4gAAAAAAAAAAAAAGQAAABgTP0/BgAAABSv/D/8BRaAYEz9PwAAAAD4OAhA
                v5AVgIBM/T+kqfw/oEz9P7+QFYCATP0/pKn8P6BM/T9kAAAAXiAAAPb///8BAAAA
                AAAAAKBM/T+krRVAAAAAAECw/D+8BBZAAAAAAPRR/D8AAAAA0Ez9PwAAAAAAAAAA
                AAAAAAAAAADcTP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                PFX9P9BT/T80Vf0/
                0FP9P9BU/T+HIAAADGL9P/RP/D88Vf0/7E/8PxQAAAAAAAAAAAAAADxV/T8AAAAA
                BQAAADhN/T9TZXJ2ZXJzAAAAAAAAAAAAAQAAADRV/T8AAAAAIQAGAAUAAAAAAAAA
                HNv7PwAAAABwNw1AAAAAAAsAAAA0Z/0/nGf9PwRo/T8AAAAAAAAAAAEAAAAAAAAA
                NDMIQFC+CEAwAgYAT9ENgJBU/T+HIAAA+FH8PwQZ/D8BAAAAAAD/AAAAAP9QvgiA
                cFT9PwEAAACHIAAAPFX9PwEAAAD+AAAAIwAGAAAAAABoA/k/AAAAADynCUBqpwlA
                /////y01CEABAAAASM0IQGgD+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAAsFT9PwAAAAABAAAA
                BBn8PwEAAAAAAP8AAAAA/wAAAADQVP0/AAAAAAAAAAAAAAAAAQAAAKpX/D8AAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3FT9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                xD39PzA8/T+8Pf0/
                MDz9P1A9/T80WTHQoFH7PzTJ/T/EPf0/fE/8PwEAAAAga/0/IGv9P8Q9/T8Ya/0/
                GAAAAMA5/T9pcGMxALwC3EZYrlOeBN8AAQAAALw9/T8AAAAAIQAGABgAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAB5ygw==
                NDMIQAixCEAwBgYAbB0IgPA8/T/0av0/AAAAAEBr/T8AAAAA9Gr9PwAAAAAIsQiA
                0Dz9PwEAAAD/////+FH8PwEAAAAEGfw/IAMGAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAC01CEABAAAASM0IQOjr+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAMQ9/T8BAAAA/gAAACMABgAAAAAAMD39P9xO/D8AAAAA
                AAAAABMIAAAAAAAAIAMGAP////8AAAAA3E78P8hO/D+Qav0/AAAAAAEAAAAAAAAA
                AAAAAFA9/T8AAAAAAAAAAEBXCEABAAAAAAAAAAAAAADREgiAgH3+PwEAAAAAAAAA
                AAAAAAAAAABcPf0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAA
                mFH7PwBQ+z+QUfs/
                AFD7PzBR+z+Jm813/GT9P8w9/T+YUfs/fE/8PwQAAAAIR/s/CEf7P5hR+z8AR/s/
                FQAAAJRH+z9wbVQAM3Pixyq2xIrxMIUA////f5BR+z8AAAAAIQAGABUAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEV9gw==
                NDMIQAixCEAwBAYAVeQSgMBQ+z/cRvs/AFH7PyhH+z8AAAAAMEf7PwAAAAAIsQiA
                oFD7PwEAAAD/////+FH8PwEAAAAEGfw/AAAAAAAAAADI//Y/AAAAADynCUBqpwlA
                /////y01CEABAAAASM0IQMj/9j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAADoAwABAAAABBn8PwAAAAAAAAAAAFH7PxCM/D+MN0M/
                AAAAABUIAAAQjPw/jDdDP/////8tNQhAAAAAAEjNCEAoR/s/AAAAADBH+z8AAAAA
                AAAAADBR+z8AAAAAAAAAAAEAAAAAAAAAAAAAAAAAAABMjfw/EIz8PywBAAAAAAAg
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPFH7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                9GT9P3DB/T8ow/0/
                cMH9P8DC/T+UaaUxYNj7P6BR+z/0ZP0/fE/8PwUAAAAAsf0/ALH9P/Rk/T/4sP0/
                FAAAACy3/T9ldmVudFRhc2sA7qT7rxsAAAAAACjD/T8AAAAAIQAGABQAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFN6A==
                NDMIQAixCEAwAwYA6OUUgDDC/T/UsP0/cML9PyCx/T8AAAAAKLH9PwAAAAAIsQiA
                EML9PwAAAAD/////9FH8PwAAAAAEGfw/hGP9PwAAAABY8BSA8MH9PzynCUBqpwlA
                /////y01CEAAAAAASM0IQFhx+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAACADBgCgwv0/AAAAAAAAAAAAAAAAcML9P0ym/D8AAAAA
                AAAAACUIAAD+AAAAhGP9P/////9wwv0/TKb8PwAAAAAgsf0/AAAAALix/T8BAAAA
                AAAAAMDC/T8AAAAAAAAAAAMAAAAAAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAADMwv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAA=
                WNj7P7DW+z9Q2Ps/
                sNb7P/DX+z9qsVforDL9P/xk/T9Y2Ps/fE/8PwIAAADowfs/6MH7P1jY+z/gwfs/
                FwAAAFTI+z93aWZpAJ2ZNA3UZ72NvrgAAAAAAFDY+z8AAAAAIQAGABcAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAOU9pA==
                NDMIQAixCEAwAwYAKBATgHDX+z+8wfs/wNf7PwjC+z8AAAAAEML7PwAAAAAIsQiA
                UNf7PwAAAAD/////9FH8PwAAAAAEGfw/AAAAAAUAAAAAAAAAAAAAADynCUBqpwlA
                /////y01CEAAAAAASM0IQIiG9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAACADBgDI1/s/CgAAAIQAlD8AAAAAsNf7P6DN/D9gjfw/
                AAAAACUIAAABAAAAAAAAAP////+w1/s/oM38P2CN/D9Y2Ps/AQAAAP4AAAABAAAA
                AAAAAPDX+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKAAAAhACUPwAAAAAAAAAA
                GgAAAFDrEUBgkfw/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPzX+z8AAAAA
                pDL9PxAx/T+cMv0/
                EDH9PzAy/T8nNaOGhE/8P2DY+z+kMv0/fE/8PwMAAAAEaf0/BGn9P6Qy/T/8aP0/
                FgAAAKAm/T9lc3BfdGltZXIApG5THSgAAAAAAJwy/T8AAAAAIQAGABYAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABF2zw==
                NDMIQAixCEAwDwYANSYNgNAx/T/YaP0/AAAAACRp/T8AAAAA2Gj9PwAAAAAIsQiA
                sDH9PwAAAAD/////9FH8PwAAAAAEGfw/IAAGAAAAAAAAAAAAAAAAADynCUBqpwlA
                /////y01CEAAAAAASM0IQMjg+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAPRR/D8AAAAABBn8PyAABgAAAAAAEDL9P4RO/D+MTvw/
                AAAAAAoJAAAJAAAAIAAGAP////8QMv0/yFj7P4xO/D8kaf0/AAAAANho/T8AAAAA
                AAAAADAy/T8AAAAAAAAAAAAAAAAAAAAAjE78PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAA8Mv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAA
                LMn9P4Dg/T+Y4v0/
                gOD9PzDi/T9dOJVYzD39P4RP/D8syf0/fE/8Pw4AAABcw/0/XMP9PyzJ/T9Uw/0/
                CwAAAJzK/T9JUlFzAEp92baI7hUgPNgAAQAAAJji/T8AAAAAIQAGAAsAAAAAAAAA
                AAAAAMzh/T8AAAAAAAAAAAAAAAA0Z/0/nGf9PwRo/T8AAAAAAAAAAAEAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAg3VOA==
                NDMIQAixCEAwAQYAI4MOgEDh/T8ww/0/4OH9P3zD/T8AAAAAhMP9PwAAAAAIsQiA
                IOH9PwEAAAD/////+FH8PwEAAAAEGfw/AAAAAAAAAADIkPk/AAAAAAAAAAAAAAAA
                AAAAAC01CEABAAAASM0IQMiQ+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAABjAAAApaWlpaWlpaXI0w2AgOH9P9hd/D/g4f0/
                AAAAAGsAAAClpaWlpaWlpf////+A4f0/tGD8P+Dh/T8AAAAAAQAAAMxd/D+AM/w/
                AAAAABDi/T/MXfw/AAAAADDi/T8AAAAAAAAAAAAAAAAAAAAAzF38PwAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABQX/w/
                UF/8PwAAAADg4f0/ABQAAMiQ+T8AAAAAAAAAAAAAAABQX/w/AAAAAAoAAAD///9/
                AAAAADDi/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAA84v0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAA=
                E (10277) esp_core_dump: Skipped 1 tasks with bad TCB!
                E (10282) esp_core_dump: Crashed task has been skipped!
                Rebooting...
                ets Jun  8 2016 00:22:57
                rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
                configsip: 0, SPIWP:0xee
                mode:DIO, clock div:1
                load:0x3fff9028,len:8
                load:0x3fff9030,len:1060
                load:0x4009fa00,len:0
                ho 12 tail 0 room 4
                load:0x4009fa00,len:14096
                entry 0x400a05e0
                MicroPython d0dc708-dirty on 2018-03-01; LoPy with ESP32
                >>> uos.listdir()
                ['\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x 00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x0 0.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x0 0\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x0 0\x00\x00\x00\x00.\x00\x00\x00',
                '\x00\x0 0\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x0 0\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00 .\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00 \x00\x00.\x00\x00\x00',
                '\x00\x00\x00\x00 \x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00 \x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', ' \x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', 'main.py', 'sys', 'lib', 'cert', 'boot.py']
  • @neuromystix as I understand the changes as @daniel made them in this version:
    • if ADR is enabled then it will start at DR0 (SF12), and change if the network says otherwise (LinkADRReq) or there's enough packet loss to increment the DR
    • if ADR is not enabled, then each single frame will be sent with the data rate configured via setsockopt, or DR5 (SF7) if nothing has been specifically set. Not sure if LinkADRReq requests are denied or accepted, but they will have no effect.
  • @jcaron simple question: what is the default DR/power you get when starting a device with ADR enabled?
    Yesterday i tried ADR, which appear to be working but always started at DR0. After the server send the LinkADRReq command Lopy change DR, so in a simple way it appears to be working. However server is configured to start with DR5, Lopy the same, but always start with DR0. Same code, with ADR disabled and Lopy start with DR5 without problem.
  • @losi
    The links at the top of this page should always point to the latest version:
    https://docs.pycom.io/chapter/gettingstarted/installation/firmwaretool.html
  • Can someone point me towards the URL of the new updater tool (OSX) and download link for v1.17.0.b1? I am having lots of problems with SigFox locking up, so I'd love to test this.
  • @jcaron Iep that was the MAC layer solution i was thinking about. Right now i don't have time to try it. But i'm following your feedback ;)
    This evening i will continue my tests with ADR.
  • @neuromystix The issues with deep sleep would be the same if you use nvram_save/restore around a restart/power down.
    The channels issue is due to the channels mask not being saved/restored, I suppose @daniel should be able to fix it soon along with the MAC command buffer issue.
    nvram_save saves a lot of things (this has grown significantly over the various firmware releases), but there's always one additional bit missing :-( The Semtech LoRaWAN stack has a tendency to have the state spread out over lots of different places which makes it a bit difficult at times.
    To know what's happening at the MAC layer, at the moment the only way I know of is to rebuild the firmware yourself and add traces. I have dozens of printfs all over there right now :-) I agree that it would be really, really helpful if there was a way to activate some kind of debug/monitor mode which would show all the data being sent/received along with the different settings (frequency, data rate, power...), though given how the Semtech LoRa stack is structured, it's not necessarily easy.
  • @jcaron Confirmed: If i manually change DR in Lorawan Server (with ADR disabled or enable on device), Lopy also change it. In old versions it wasn't working.
    I'm not using deep sleep right now (don't have any shield yet) however i'm using lora_save/restore and after the first restart i loose all the additional 5 channels, being stuck at the default 3 (868.1, 868,.3, 868,5). In my project i need the devices to be restart tolerant, even if i don't use deep sleeps. I workaround it, re-initiating all the 8 channels after call nvram_restore(), when restarting and when already activated. If i don't do it, restore() get the three default channels. Maybe it's not the correct way to do it but worked here.
    Not really sure what is being stored by lora.nvram_save(), it should be clarified in documentation. I know that FCnt and keys are stored but what else?
    @jcaron Is there any simple way to check what's going on at Lopy MAC layer? At server side i can check the log's, but in the devices i don't know how?
  • @neuromystix It should work better, with the data rate no longer stuck at the default value forever.
    I'm not 100% convinced by the approach chosen which is to ignore completely data rate set requests if ADR is enabled (I would still allow them and use them as a starting point until either the network says something or there are enough losses to change), let us know what you think.
    Note that there are still at least 2 issues I'm aware of when using LoRaWAN with deep sleep:
    • the channels mask is not saved/restored, so after deep sleep you go back to the default channel numbers.
    • buffered MAC commands are not properly restored, so MAC command ACKs will never be sent and the network will continue to send the request again and again (if you sleep after each frame).
  • @jcaron Iep, for tx_power it make sense, following the specification. Only now i read your last post that say the frequency problem.
    Not that i need this values, however since i'm testing ADR (and checking if in this release it works better) i added a print of stats and found that 0 values strange. At least for the frequency.
  • @neuromystix tx_frequency is incorrect and always returns 0.
    tx_power should show correct values. Note that it represents the power setting as specified in the regions spec, so for instance in EU868 0 is max, 1 is 2 dBm below max, etc.
  • @daniel using lora.stat() in lorawan mode is always getting 0 value in tx_power and tx_frequency. It's supposed to be like that??? All the other fields appear to be fine.
39 out of 46
