    New firmware release v1.17.0.b1 (Completely new LTE class)
    firmware
    46 Posts 16 Posters 16.9k Views 16 Watching
    • X Offline
      Xykon administrators
      A few notes about the new updater tool:
      It now supports re-setting the default LoRa region stored in flash memory. This is only supported when upgrading the firmware via the online software server.
      It now supports flashing from a local file.
      It also now supports offline mode that allows flashing from a local file when no online connection is available or the software server is unavailable. It is now also possible to "retry" to connect to the software server if the connection has failed. The initial timeout is 5 seconds and will be increased by 5 seconds on every attempt up to a maximum of 60 seconds.
      @seb is working on the documentation for the CLI tool. It has a few new features which you might find helpful.
      First off there are now some helpful messages being displayed by default. For scripting purposes, there is a new global option -q / --quiet to disable the messages.
      One of the new messages being shown is the mode in which the updater is operating. If it shows PIC mode, it is trying to use the Pytrack / Pysense to automatically switch into firmware update mode. If it shows FTDI mode, this indicates an Expansion Board 2.0 (or 3rd party adapter). There are some rare cases where this detection could fail, and you can now force either mode by using the global --ftdi / --pic options. [Update:] These options can now also be used with the update command for the Linux dialog based updater.
      Other notable changes are the sigfox command now functioning correctly and a new option in the lpwan command --erase_region which allows erasing the default LoRa region in flash memory. The other new commands lpwan --lora_region and write_remote are specifically to support the dialog based cli updater for Linux and especially write_remote is not intended for general use.
      As Daniel mentioned this is a mandatory update and you might see various types of error messages in earlier version.
      If you have any issues with this new version please don't hesitate to contact me and I will try to help / fix it as quickly as possible.
      Christian Ehlers
        danielm
        @Xykon
        It's great to see option to flash from local file implemented.
        Does it perform full flash erase prior to upgrading? If not, would it be possible to add such option?
        • X Offline
          Xykon administrators @danielm
          @danielm May I ask what would be the purpose of that? Is it just to erase the flash file system or do you have any reason to erase the config, nvs and ota partitions?
          Christian Ehlers
            robert-hh @daniel
            @daniel I'm a little bit sad that you did not add a fix to deactivate Ctrl-F if wanted.
              danielm
              @Xykon
              I currently use esptool.py to perform flash erase mainly because my application checks for a flag in the NVS when booting. If this flag is not present initialization routine is launched during first boot after the upgrade. Secondly I would like to be sure that no data from previous versions will stay in the file system. My application creates config file (during first boot) which may differ between versions of the firmware.
              • X Offline
                @danielm I would not allow this in a general release.
                Since you are using custom firmware, you can define the erase yourself in the script file. See below example from the LoPy archive:
                    ["e", "0x1000",      "0x40000"],
                    ["e", "0x41000",     "0x40000"],
                    ["e", "0x81000",     "0x40000"],
                    ["e", "0xC1000",     "0x40000"],
                    ["e", "0x101000",    "0x40000"],
                    ["e", "0x141000",    "0x40000"],
                    ["e", "0x181000",    "0x40000"],
                    ["e", "0x1C1000",    "0x40000"],
                    ["w", "0x1000", "bootloader.bin"],
                    ["w", "0x8000", "partitions.bin"],
                    ["w", "0x10000", "lopy.bin"]
                All lines starting with "e" are erase commands. Then you have the start block and the erase size (which is limited to 0x40000).
                Please keep in mind that if you use a LoRa or Sigfox device then the LoRa MAC address and Sigfox credentials are stored in the config block (0x3FF000) and if you don't have an online connection while flashing, these details would not be restored. If a device is erased before being flashed for the first time with the online updater, the LoRa MAC address will be permanently lost.
                P.S. Could you please send us an email at support@pycom.io with a reference to this discussion. I have a few ideas that might work really well for you and allow us to get some feedback at the same time.
                Christian Ehlers
                • N Offline
                  Neuromystix @daniel
                  @daniel using lora.stat() in lorawan mode is always getting 0 value in tx_power and tx_frequency. It's supposed to be like that??? All the other fields appear to be fine.
                  Researcher @ UALG, Portugal
                    jcaron @Neuromystix
                    @neuromystix tx_frequency is incorrect and always returns 0.
                    tx_power should show correct values. Note that it represents the power setting as specified in the regions spec, so for instance in EU868 0 is max, 1 is 2 dBm below max, etc.
                    • N Offline
                      Neuromystix @jcaron
                      @jcaron Iep, for tx_power it make sense, following the specification. Only now i read your last post that say the frequency problem.
                      Not that i need this values, however since i'm testing ADR (and checking if in this release it works better) i added a print of stats and found that 0 values strange. At least for the frequency.
                        jcaron @Neuromystix
                        @neuromystix It should work better, with the data rate no longer stuck at the default value forever.
                        I'm not 100% convinced by the approach chosen which is to ignore completely data rate set requests if ADR is enabled (I would still allow them and use them as a starting point until either the network says something or there are enough losses to change), let us know what you think.
                        Note that there are still at least 2 issues I'm aware of when using LoRaWAN with deep sleep:
                        • the channels mask is not saved/restored, so after deep sleep you go back to the default channel numbers.
                        • buffered MAC commands are not properly restored, so MAC command ACKs will never be sent and the network will continue to send the request again and again (if you sleep after each frame).
                        • N Offline
                          Neuromystix @jcaron
                          @jcaron Confirmed: If i manually change DR in Lorawan Server (with ADR disabled or enable on device), Lopy also change it. In old versions it wasn't working.
                          I'm not using deep sleep right now (don't have any shield yet) however i'm using lora_save/restore and after the first restart i loose all the additional 5 channels, being stuck at the default 3 (868.1, 868,.3, 868,5). In my project i need the devices to be restart tolerant, even if i don't use deep sleeps. I workaround it, re-initiating all the 8 channels after call nvram_restore(), when restarting and when already activated. If i don't do it, restore() get the three default channels. Maybe it's not the correct way to do it but worked here.
                          Not really sure what is being stored by lora.nvram_save(), it should be clarified in documentation. I know that FCnt and keys are stored but what else?
                          @jcaron Is there any simple way to check what's going on at Lopy MAC layer? At server side i can check the log's, but in the devices i don't know how?
                            jcaron @Neuromystix
                            @neuromystix The issues with deep sleep would be the same if you use nvram_save/restore around a restart/power down.
                            The channels issue is due to the channels mask not being saved/restored, I suppose @daniel should be able to fix it soon along with the MAC command buffer issue.
                            nvram_save saves a lot of things (this has grown significantly over the various firmware releases), but there's always one additional bit missing :-( The Semtech LoRaWAN stack has a tendency to have the state spread out over lots of different places which makes it a bit difficult at times.
                            To know what's happening at the MAC layer, at the moment the only way I know of is to rebuild the firmware yourself and add traces. I have dozens of printfs all over there right now :-) I agree that it would be really, really helpful if there was a way to activate some kind of debug/monitor mode which would show all the data being sent/received along with the different settings (frequency, data rate, power...), though given how the Semtech LoRa stack is structured, it's not necessarily easy.
                            N 2 Replies Last reply Reply Quote 0
                            • N Offline
                              Neuromystix @jcaron
                              @jcaron Iep that was the MAC layer solution i was thinking about. Right now i don't have time to try it. But i'm following your feedback ;)
                              This evening i will continue my tests with ADR.
                                losi
                                Can someone point me towards the URL of the new updater tool (OSX) and download link for v1.17.0.b1? I am having lots of problems with SigFox locking up, so I'd love to test this.
                                • sebS Offline
                                  seb @losi
                                  @losi
                                  The links at the top of this page should always point to the latest version:
                                  https://docs.pycom.io/chapter/gettingstarted/installation/firmwaretool.html
                                  L I 2 Replies Last reply Reply Quote 0
                                  • N Offline
                                    Neuromystix @jcaron
                                    @jcaron simple question: what is the default DR/power you get when starting a device with ADR enabled?
                                    Yesterday i tried ADR, which appear to be working but always started at DR0. After the server send the LinkADRReq command Lopy change DR, so in a simple way it appears to be working. However server is configured to start with DR5, Lopy the same, but always start with DR0. Same code, with ADR disabled and Lopy start with DR5 without problem.
                                      jcaron @Neuromystix
                                      @neuromystix as I understand the changes as @daniel made them in this version:
                                      • if ADR is enabled then it will start at DR0 (SF12), and change if the network says otherwise (LinkADRReq) or there's enough packet loss to increment the DR
                                      • if ADR is not enabled, then each single frame will be sent with the data rate configured via setsockopt, or DR5 (SF7) if nothing has been specifically set. Not sure if LinkADRReq requests are denied or accepted, but they will have no effect.
                                        Colateral
                                        Board: L01
                                        CRASH with flash erase. This is happening often after sending multiple Lora messages as request and receiving a Lora message as response in a simple Lora - Lora connection.
                                        Can someone explain why ESP32 is flashed? - my scripts are erased and also main.py and boot.py are restored to default.
                                        I checked also with uos.listdir() and there are a lot of junks (see below after crash uput)
                                                    Guru Meditation Error: Core  1 panic'ed (Cache disabled but cached memory region accessed)
                                                    Register dump:
                                                    PC      : 0x400dbec8  PS      : 0x00060034  A0      : 0x80084c68  A1      : 0x3ffc1390
                                                    A2      : 0x3ffc784c  A3      : 0x00000001  A4      : 0x8008bf73  A5      : 0x3ffc13a0
                                                    A6      : 0x00000020  A7      : 0x00000020  A8      : 0x80084a58  A9      : 0x3ffc1370
                                                    A10     : 0x00000012  A11     : 0x3ffc1391  A12     : 0x3ffc1391  A13     : 0x3ffc7864
                                                    A14     : 0x3ffc7854  A15     : 0x00000402  SAR     : 0x0000000e  EXCCAUSE: 0x00000007
                                                    EXCVADDR: 0x00000000  LBEG    : 0x4009a73c  LEND    : 0x4009a76a  LCOUNT  : 0x00000000
                                                    Backtrace: 0x400dbec8:0x3ffc1390 0x40084c65:0x3ffc13c0 0x40083f0b:0x3ffc13f0 0x40083585:0x3ffc1410 0x400621f9:0x00000000
                                                    LCgAAA0AAABsAQAA
                                                    UDj9P+A2/T9IOP0/
                                                    4Db9P+A3/T9UkePQ6FH8P+hR/D9QOP0/4FH8PwEAAADIav0/yGr9P1A4/T8AAAAA
                                                    GAAAAEw0/T9pcGMwABVA5g5OoraPJm8AAAAAAEg4/T8AAAAAJQAGABgAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAA0Z/0/nGf9PwRo/T8AAAAAAAAAAAEAAAAAAAAA
                                                    ullAPwAAAAAcrwlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKi2sQ==
                                                    NDMIQH5XCEA0DwYAmh0IgKA3/T8AAAAAAQAAAJBq/T8AAAAAAQAAAAAAAAAEpPw/
                                                    AAAAAAEAAABMAAASBBn8PwEAAAD+AAAAFwAAAAAAAAAHAAAAAAAAAAAAAAAAAAAA
                                                    AAAAAAQZ/D8BAAAAVDAIQHjm+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAACGIAAA/gAAABcAAAAAAAAAwDf9P9hO/D/ITvw/
                                                    6Gr9PwAAAACcav0/AAAAAAAAAADgN/0/AAAAAAAAAABAVwhAAAAAAAAAAAAAAAAA
                                                    NRIIgEA8/j9kT/w/bE/8PwAAAAAAAAAA7Df9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                                    IFv9P6BZ/T8YW/0/
                                                    oFn9P7Ba/T+NvCD1nGD9PwhQ/D8gW/0/AFD8PxkAAABqGlDhXg+IxSBb/T8AAAAA
                                                    AAAAABxX/T9JRExFAPOBHrhQ9qfnu4AAAAAAABhb/T8AAAAAIQAGAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD7VKQ==
                                                    NDMIQMTmFEAwDwYA4L4IgGBa/T8gAAAAAQAAAAAAAACUpvw/9FH8P5xP/D+wpvw/
                                                    QFr9PwAAAAD4OAhAIA0GAGBR/T8DAAAAIwAGAAAAAABgWv0/OEL9PwAAAAAAAAAA
                                                    AAAAAC01CEBgUf0/SM0IQEgJ+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAAgFr9PwAAAAAAAAAA
                                                    AAAAAAQZ/D/0Ufw/nE/8PwAAAACwWv0/AAAAAAAAAAAEGfw/AAAAAAAAAAAAAAAA
                                                    AQAAAAAAAAAEAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALxa/T8AAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
                                                    lGD9PxBf/T+MYP0/
                                                    EF/9PyBg/T9eWJqiCFD8Pyhb/T+UYP0/AFD8PxkAAACIFjsVs8Kan5Rg/T8AAAAA
                                                    AAAAAJBc/T9JRExFACa9xXw2jMuuC8gAAQAAAIxg/T8AAAAAIwAGAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAOBFug==
                                                    NDMIQMTmFEAwCgYA4L4IgNBf/T8gAAAAAQAAACAAAACUpvw/+FH8P5xP/D/Qpvw/
                                                    sF/9PwAAAAAAAAAAAAAAAPCb/T8DAAAAIwAGAAwAAADQX/0/IAAAAPhvDkA0cA5A
                                                    AAAAAC01CEDwm/0/SM0IQLgO+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAA8F/9PwAAAAABAAAA
                                                    IAAAAJSm/D/4Ufw/nE/8PwAAAAAgYP0/AAAAAAAAAAAEGfw/AAAAAAAAAAAAAAAA
                                                    AQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACxg/T8AAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
                                                    BGL9P0B1/T+Ydv0/
                                                    QHX9PzB2/T+HIAAAWGv7P0RV/T8EYv0/7E/8Pw8AAADQa/0/0Gv9PwRi/T/Ia/0/
                                                    CgAAAJxs/T9UbXIgU3ZjAMBjrnOpEqcAAAAAAJh2/T8AAAAAIQAGAAoAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABcGTw==
                                                    NDMIQJnLCEAwAQYAAAAAAAB2/T8BAAAAhyAAAAAAAAAEUvw//FH8P4YgAACZywiA
                                                    4HX9PwAAAAAEGfw/AAAAAAAAAAAAAAAAAAAAACAAAADIJPk/AAAAADynCUBqpwlA
                                                    AAAAAC01CEAAAAAASM0IQMgk+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABgAAAAAAAAAMHb9PwAAAAAAAAAA
                                                    AAAAACgIAAB04/0/AAAAAAAAAAAEUvw//FH8P1ogAAAAAAAAAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAA8dv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAA=
                                                    UGv7P1Bp+z9Ia/s/
                                                    UGn7P+Bq+z+HIAAAjGP9Pwxi/T9Qa/s/7E/8PxMAAACgFP306bsvWlBr+z8AAAAA
                                                    BgAAAExh+z9Mb1JhAEACTFqOUf/RMYAAAQAAAEhr+z8AAAAAIQAGAAYAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABOyiA==
                                                    NDMIQFC+CEAwDgYAUhwQgBBq+z+HIAAA+FH8PwQZ/D8BAAAAAAAAAAAAAABQvgiA
                                                    8Gn7PwEAAACHIAAAUGv7PwEAAAD+AAAAEAAAAA4AAACDafs/ZHj8PyCpCUArqQlA
                                                    AAAAAC01CEABAAAASM0IQHgZ9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAgAAAAAAAAAAQAAAAAAAAAAAAAAMGr7P8hk/D8EAAAA
                                                    B////0x4/D8BAAAAAAAAAAAAAADgavs/AAAAAAAAAAAIAAAAAAAAAAAAAAABAAAA
                                                    AAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAB4Gfc/AAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAZvw/CwAAAGzhQj8BAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA7Gr7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                                    hGP9P1BL/T8wTf0/
                                                    UEv9P9BM/T/CIAAA9E/8P1hr+z+EY/0/7E/8PwcAAAD4rv0/+K79P4Rj/T/wrv0/
                                                    EgAAADQ//T90aVQAdACZ0es3LF7mEIQA////fzBN/T8AAAAAIQAGABIAAAABAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANrEAA==
                                                    NDMIQAixCEAwDQYArYAWgBBM/T/Mrv0/oEz9Pxiv/T8AAAAAIK/9PwAAAAAIsQiA
                                                    8Ev9PwAAAABkAAAA9FH8PwAAAAAEGfw/AAAAAB8AAAAAAAAAAAAAAJFrFkCaaxZA
                                                    AAAAAC01CEAAAAAASM0IQGj7+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAACBM/T8ATP0/DAAAABSv/D/xBRaAUEz9P6Sp/D+gTP0/
                                                    AAAAAF4gAAAAAAAAAAAAAGQAAABgTP0/BgAAABSv/D/8BRaAYEz9PwAAAAD4OAhA
                                                    v5AVgIBM/T+kqfw/oEz9P7+QFYCATP0/pKn8P6BM/T9kAAAAXiAAAPb///8BAAAA
                                                    AAAAAKBM/T+krRVAAAAAAECw/D+8BBZAAAAAAPRR/D8AAAAA0Ez9PwAAAAAAAAAA
                                                    AAAAAAAAAADcTP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                                    PFX9P9BT/T80Vf0/
                                                    0FP9P9BU/T+HIAAADGL9P/RP/D88Vf0/7E/8PxQAAAAAAAAAAAAAADxV/T8AAAAA
                                                    BQAAADhN/T9TZXJ2ZXJzAAAAAAAAAAAAAQAAADRV/T8AAAAAIQAGAAUAAAAAAAAA
                                                    HNv7PwAAAABwNw1AAAAAAAsAAAA0Z/0/nGf9PwRo/T8AAAAAAAAAAAEAAAAAAAAA
                                                    NDMIQFC+CEAwAgYAT9ENgJBU/T+HIAAA+FH8PwQZ/D8BAAAAAAD/AAAAAP9QvgiA
                                                    cFT9PwEAAACHIAAAPFX9PwEAAAD+AAAAIwAGAAAAAABoA/k/AAAAADynCUBqpwlA
                                                    /////y01CEABAAAASM0IQGgD+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAAsFT9PwAAAAABAAAA
                                                    BBn8PwEAAAAAAP8AAAAA/wAAAADQVP0/AAAAAAAAAAAAAAAAAQAAAKpX/D8AAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3FT9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                                    xD39PzA8/T+8Pf0/
                                                    MDz9P1A9/T80WTHQoFH7PzTJ/T/EPf0/fE/8PwEAAAAga/0/IGv9P8Q9/T8Ya/0/
                                                    GAAAAMA5/T9pcGMxALwC3EZYrlOeBN8AAQAAALw9/T8AAAAAIQAGABgAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAB5ygw==
                                                    NDMIQAixCEAwBgYAbB0IgPA8/T/0av0/AAAAAEBr/T8AAAAA9Gr9PwAAAAAIsQiA
                                                    0Dz9PwEAAAD/////+FH8PwEAAAAEGfw/IAMGAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                                    AAAAAC01CEABAAAASM0IQOjr+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAMQ9/T8BAAAA/gAAACMABgAAAAAAMD39P9xO/D8AAAAA
                                                    AAAAABMIAAAAAAAAIAMGAP////8AAAAA3E78P8hO/D+Qav0/AAAAAAEAAAAAAAAA
                                                    AAAAAFA9/T8AAAAAAAAAAEBXCEABAAAAAAAAAAAAAADREgiAgH3+PwEAAAAAAAAA
                                                    AAAAAAAAAABcPf0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAA
                                                    mFH7PwBQ+z+QUfs/
                                                    AFD7PzBR+z+Jm813/GT9P8w9/T+YUfs/fE/8PwQAAAAIR/s/CEf7P5hR+z8AR/s/
                                                    FQAAAJRH+z9wbVQAM3Pixyq2xIrxMIUA////f5BR+z8AAAAAIQAGABUAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEV9gw==
                                                    NDMIQAixCEAwBAYAVeQSgMBQ+z/cRvs/AFH7PyhH+z8AAAAAMEf7PwAAAAAIsQiA
                                                    oFD7PwEAAAD/////+FH8PwEAAAAEGfw/AAAAAAAAAADI//Y/AAAAADynCUBqpwlA
                                                    /////y01CEABAAAASM0IQMj/9j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAADoAwABAAAABBn8PwAAAAAAAAAAAFH7PxCM/D+MN0M/
                                                    AAAAABUIAAAQjPw/jDdDP/////8tNQhAAAAAAEjNCEAoR/s/AAAAADBH+z8AAAAA
                                                    AAAAADBR+z8AAAAAAAAAAAEAAAAAAAAAAAAAAAAAAABMjfw/EIz8PywBAAAAAAAg
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPFH7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                                    9GT9P3DB/T8ow/0/
                                                    cMH9P8DC/T+UaaUxYNj7P6BR+z/0ZP0/fE/8PwUAAAAAsf0/ALH9P/Rk/T/4sP0/
                                                    FAAAACy3/T9ldmVudFRhc2sA7qT7rxsAAAAAACjD/T8AAAAAIQAGABQAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFN6A==
                                                    NDMIQAixCEAwAwYA6OUUgDDC/T/UsP0/cML9PyCx/T8AAAAAKLH9PwAAAAAIsQiA
                                                    EML9PwAAAAD/////9FH8PwAAAAAEGfw/hGP9PwAAAABY8BSA8MH9PzynCUBqpwlA
                                                    /////y01CEAAAAAASM0IQFhx+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAACADBgCgwv0/AAAAAAAAAAAAAAAAcML9P0ym/D8AAAAA
                                                    AAAAACUIAAD+AAAAhGP9P/////9wwv0/TKb8PwAAAAAgsf0/AAAAALix/T8BAAAA
                                                    AAAAAMDC/T8AAAAAAAAAAAMAAAAAAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAADMwv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAA=
                                                    WNj7P7DW+z9Q2Ps/
                                                    sNb7P/DX+z9qsVforDL9P/xk/T9Y2Ps/fE/8PwIAAADowfs/6MH7P1jY+z/gwfs/
                                                    FwAAAFTI+z93aWZpAJ2ZNA3UZ72NvrgAAAAAAFDY+z8AAAAAIQAGABcAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAOU9pA==
                                                    NDMIQAixCEAwAwYAKBATgHDX+z+8wfs/wNf7PwjC+z8AAAAAEML7PwAAAAAIsQiA
                                                    UNf7PwAAAAD/////9FH8PwAAAAAEGfw/AAAAAAUAAAAAAAAAAAAAADynCUBqpwlA
                                                    /////y01CEAAAAAASM0IQIiG9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAACADBgDI1/s/CgAAAIQAlD8AAAAAsNf7P6DN/D9gjfw/
                                                    AAAAACUIAAABAAAAAAAAAP////+w1/s/oM38P2CN/D9Y2Ps/AQAAAP4AAAABAAAA
                                                    AAAAAPDX+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKAAAAhACUPwAAAAAAAAAA
                                                    GgAAAFDrEUBgkfw/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPzX+z8AAAAA
                                                    pDL9PxAx/T+cMv0/
                                                    EDH9PzAy/T8nNaOGhE/8P2DY+z+kMv0/fE/8PwMAAAAEaf0/BGn9P6Qy/T/8aP0/
                                                    FgAAAKAm/T9lc3BfdGltZXIApG5THSgAAAAAAJwy/T8AAAAAIQAGABYAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABF2zw==
                                                    NDMIQAixCEAwDwYANSYNgNAx/T/YaP0/AAAAACRp/T8AAAAA2Gj9PwAAAAAIsQiA
                                                    sDH9PwAAAAD/////9FH8PwAAAAAEGfw/IAAGAAAAAAAAAAAAAAAAADynCUBqpwlA
                                                    /////y01CEAAAAAASM0IQMjg+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAPRR/D8AAAAABBn8PyAABgAAAAAAEDL9P4RO/D+MTvw/
                                                    AAAAAAoJAAAJAAAAIAAGAP////8QMv0/yFj7P4xO/D8kaf0/AAAAANho/T8AAAAA
                                                    AAAAADAy/T8AAAAAAAAAAAAAAAAAAAAAjE78PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAA8Mv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAA
                                                    LMn9P4Dg/T+Y4v0/
                                                    gOD9PzDi/T9dOJVYzD39P4RP/D8syf0/fE/8Pw4AAABcw/0/XMP9PyzJ/T9Uw/0/
                                                    CwAAAJzK/T9JUlFzAEp92baI7hUgPNgAAQAAAJji/T8AAAAAIQAGAAsAAAAAAAAA
                                                    AAAAAMzh/T8AAAAAAAAAAAAAAAA0Z/0/nGf9PwRo/T8AAAAAAAAAAAEAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAg3VOA==
                                                    NDMIQAixCEAwAQYAI4MOgEDh/T8ww/0/4OH9P3zD/T8AAAAAhMP9PwAAAAAIsQiA
                                                    IOH9PwEAAAD/////+FH8PwEAAAAEGfw/AAAAAAAAAADIkPk/AAAAAAAAAAAAAAAA
                                                    AAAAAC01CEABAAAASM0IQMiQ+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAABjAAAApaWlpaWlpaXI0w2AgOH9P9hd/D/g4f0/
                                                    AAAAAGsAAAClpaWlpaWlpf////+A4f0/tGD8P+Dh/T8AAAAAAQAAAMxd/D+AM/w/
                                                    AAAAABDi/T/MXfw/AAAAADDi/T8AAAAAAAAAAAAAAAAAAAAAzF38PwAAAAAAAAAA
                                                    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABQX/w/
                                                    UF/8PwAAAADg4f0/ABQAAMiQ+T8AAAAAAAAAAAAAAABQX/w/AAAAAAoAAAD///9/
                                                    AAAAADDi/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAA84v0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                                    AAAAAAAAAAA=
                                                    E (10277) esp_core_dump: Skipped 1 tasks with bad TCB!
                                                    E (10282) esp_core_dump: Crashed task has been skipped!
                                                    Rebooting...
                                                    ets Jun  8 2016 00:22:57
                                                    rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
                                                    configsip: 0, SPIWP:0xee
                                                    mode:DIO, clock div:1
                                                    load:0x3fff9028,len:8
                                                    load:0x3fff9030,len:1060
                                                    load:0x4009fa00,len:0
                                                    ho 12 tail 0 room 4
                                                    load:0x4009fa00,len:14096
                                                    entry 0x400a05e0
                                                    MicroPython d0dc708-dirty on 2018-03-01; LoPy with ESP32
                                                    >>> uos.listdir()
                                                    ['\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                                                    '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x 00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                                                    '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x0 0.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                                                    '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x0 0\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                                                    '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x0 0\x00\x00\x00\x00.\x00\x00\x00',
                                                    '\x00\x0 0\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                                                    '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x0 0\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                                                    '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00 .\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                                                    '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00 \x00\x00.\x00\x00\x00',
                                                    '\x00\x00\x00\x00 \x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                                                    '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00 \x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                                                    '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', ' \x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00',
                                                    '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', 'main.py', 'sys', 'lib', 'cert', 'boot.py']
                                          robert-hh @daniel
                                          @daniel @Xykon @seb Thanks for the Linux software updater. I ignored that since a while, and I am still not using it for software updates, but it has a lot of other management options, which are very useful.
                                            losi @seb
                                            @seb Your link points to release v1.12.0.b0, which is why i asked.
                                            • 1 / 3
