    Gpy + Pysense - urequests AttributeError: 'module' object has no attribute 'get'
    gpypsensehttp geturequestsurequest.py
    7 Posts 2 Posters 2.1k Views 2 Watching
      madeira199
      Hi
      I am trying to make an HTTP get request for testing but have getting this message:
      urequests.py library downloaded from https://github.com/micropython/micropython-lib/tree/master/urequests
      Please give me some help, i am started with Pycom...
      Network found!
      WLAN connection succeeded!
      RTC Set from NTP to UTC: (2018, 2, 28, 14, 23, 38, 97276, None)
      File "main.py", line 11, in <module>
      MicroPython v1.8.6-849-055728a on 2018-02-13; GPy with ESP32
       # boot.py
      from network import WLAN
      wlan = WLAN(mode=WLAN.STA)
      nets = wlan.scan()
      for net in nets:
          if net.ssid == 'REMOVED':
              print('Network found!')
              wlan.connect(net.ssid, auth=(net.sec, 'REMOVED.'), timeout=5000)
              while not wlan.isconnected():
      # main.py
      import urequests as requests
      import utime
      from machine import RTC
      rtc = machine.RTC()
      rtc.ntp_sync("pool.ntp.org")
      utime.sleep_ms(750)
      r = requests.get('http://api.xively.com/')
      print(r)
      print(r.content)
      print(r.text)
      print(r.content)
      print(r.json())
      r.close()
      • sebS Offline
        seb
        1. Are you on the latest firmware?
        2. Are you sure you have correctly downloaded the urequest.py file from the link you provided? When I attempted to run this code I could not replicate your error. I did however have to patch line 53 to be:
            ai = usocket.getaddrinfo(host, port)
          madeira199 @seb
          @seb Yes i have the latest firmware, updated yesterday, Gpy, and Pysense
          i have patch line 53, and the problem remains
          • sebS Offline
            seb @madeira199
            @madeira199
            In the REPL console can you please run the following:
            print(dir(requests))
            print(type(requests))
              madeira199 @seb
              thank you very much for your help!
              • sebS Offline
                seb @madeira199
                @madeira199
                Ah there seems to have been an issue syncing the library because the output should be:
                ['put', 'post', 'usocket', 'patch', 'request', '__file__', '__name__', 'delete', 'head', 'Response', 'get']
                <class 'module'>
                Can you please run the following to clear your device and sync again:
                os.mkfs('/flash')
                  madeira199 @seb
                  @seb Everything work fine, after sync again!
                  Thank you very much
