Lopy 1 with latest firmware possible?
Trying to update the Lopy 1 with the latest firmnware 1.0.17 but it doesn't appear to work. The firmware shows a date in hune 2016?
I have tried the firmware update on Windows 10 and windows 7 and the update stays stuck on "Please wait. Reading information about the board ..."
Last week Xylon sent a *.tar.gz file which I was able to update the firmware using the CLI tool.
Could you please provide the same. Thanks.
This shows that you are on the latest
release='1.17.0.b1
, The LoPy4 is an upgrade of the lopy in the following ways:- LoPy4 can also connect to Sigfox
- LoPy4 can do LoRa on 433MHz
- LoPy4 does not have the deep sleep issue as the LoPy does
- LoPy4 has 8MB of flash (vs 4MB)
- LoPy4 has 4MB+520KB of RAM (vs 520KB)
(sysname='LoPy', nodename='LoPy', release='1.17.0.b1', version='v1.8.6-849-d0dc708 on 2018-02-27', machine='LoPy with ESP32', lorawan='1.0.2')
Are the Lopy very limited with memory? Is the Lopy4 a hardware memory upgrade?
If you run the following what does it return?
import os print(os.uname())
