    GPy LTE-M Connection
    gpylte-msend datainternet connec
    15 Posts 2 Posters 3.5k Views 2 Watching
      livius @francesco.gallo
      @francesco-gallo
      You ask about LTE-M or generic problem with send to io.adafruit.com?
      I suppose that about sending at all. Because there is not difference between wifi and LTE socket use
      • F Offline
        francesco.gallo @livius
        @livius Hi @livius , thank you for your interest.
        My idea is to use the LTE-M module with my SIM to send data (e.g. Temperature Value) to a service like io.adafruit.com.
        I don't want to use Wi-fi...How can modify the example from this link? https://docs.pycom.io/chapter/firmwareapi/pycom/network/lte/cat-m1.html
        BR
          @francesco-gallo said in GPy LTE-M Connection:
          Back to my first question. You do not know how to send something to io.adafruit.com
          not how to send something throught LTE-M1?
          Because sample you provided is exacly for LTE-CAT M1 (and there is no diiference between wifi and socket usage)
          use api provided
          https://io.adafruit.com/api/docs/#operation/lastData
          and send http request by e.g. urequest
          https://github.com/micropython/micropython-lib/blob/master/urequests/urequests.py
          F 2 Replies Last reply Reply Quote 0
          • F Offline
            @livius Thanks a lot
            • F Offline
              @livius Hi,
              sorry, but I have the error message as in figure...
              • F Offline
                francesco.gallo @francesco.gallo
                @francesco-gallo And please, I am a newbie :(.. And I would like learn as send data (e.g. Temperature) using LTE...
                Is there an example code?
                BR
                  @francesco-gallo
                  What is your firmware version?
                  os.uname()
                  you should have 1.17.0.b1
                  • F Offline
                    Ops...no...
                      @francesco-gallo
                      update device because docs fallow firmware and in 1.17 there was big change in LTE
                      https://forum.pycom.io/topic/2734/new-firmware-release-v1-17-0-b1-completely-new-lte-class
                      • F Offline
                        @livius And please, I am a newbie :(.. And I would like learn as send data (e.g. Temperature) using LTE...
                          example of what? Updating firmware?
                          after this step we can go next :)
                          • F Offline
                            @livius Thanks...
                            The update is done...and now is ok..
                            My question is about an example code regards the use of LTE to send temperature value to online service, or send the temperature value to smartphone...
                            BR
                              @francesco-gallo
                              First question is - do you have succesfully connected to LTE CAT M1?
                              If yes, which provider do you use and in which location (country)
                              For sensors you can use any code sample existed for e.g. wifi
                              only difference is start point (connection to the network)
                              next steps are the same create socket and send data
                              you can use e.g. urequest
                              e.g.
                              import urequests
                              res = urequests.post('your_service_url', json={'MyTemerarureSensorName': str(temp)})
                              res.close()
                              if (res.status_code - 200) < 100:
                                  print("post ok:" + str(temp) + " C")
                                  print('some error')
                              • F Offline
                                @livius Regards first question: i used the code here: https://docs.pycom.io/chapter/firmwareapi/pycom/network/lte/cat-m1.html...
                                But I did not have any results...The country is Italy and I have the tim sim..
                                BR
