    pymakr does not start
    31 Posts 6 Posters 11.8k Views 6 Watching
      abilio @wathoom
      Hi @wathoom, I can now confirm that having both PyQt4 and PyQt5 seems to be the culprit.
      As we now identified the real cause of it, we will look for a solution to this problem and try to include it in the upcoming release.
      Thank you so much for all your support and your patience.
        abilio @robert-hh
        @robert-hh . Yes, it is possible to put a name in that field, if you have a DNS (or hosts) entry for it. Can I ask something about your WiPy 1 setup? Are you running it as an access point mode=WLAN.AP , or station mode=WLAN.STA?
          robert-hh
          WiPy is running in it's default configuration as an Access point, and I can Telnet & ftp to it.
            robert-hh
            OK. I removed PyQt5 the hard way, and now pymakr runs. At least that's a second confirmation. I do not know the side effectes of that yet, but I might find it.
              abilio @robert-hh
              @robert-hh, thanks a lot for performing that test. It seems to me it definitely proves it.
              Now about the WiPy failing, with your permission, I would like to go step by step on finding out the reason. Can I ask you to create a new thread for that specific subject, so future users can find it under the right label? Actually I created a completely separated category for Pymakr, it will be good for it to go there.
              Thanks again for the test,
              Abilio
              • K Offline
                kephasp
                Same issue with 1.0.0.b6
                <type 'exceptions.ImportError'>:
                cannot import name QLabel
                  File "/usr/share/pymakr/modules/pymakr.py", line 368, in <module>
                    main()
                  File "/usr/share/pymakr/modules/pymakr.py", line 288, in main
                    from UI.SplashScreen import SplashScreen, NoneSplashScreen
                  File "/usr/share/pymakr/modules/UI/SplashScreen.py", line 16, in <module>
                    from PyQt5.QtGui import QPixmap, QColor, QLabel
                Version Numbers:
                  Python 2.7.12+
                  Qt 5.7.1
                  PyQt 5.7
                  sip 4.18.1
                  QScintilla 2.9.3
                  WebKit 538.1
                  Pymakr 1.0.0.b6
                Platform: linux2
                2.7.12+ (default, Sep  1 2016, 20:27:38)
                [GCC 6.2.0 20160822]
                • K Offline
                  kephasp
                  This may be an issue with PyQt5's API. In PyQt 5.7, QLabel is not in module QTGui but in QtWidgets.
                  I tried the following patch:
                  diff --git a/modules/UI/SplashScreen.py b/modules/UI/SplashScreen.py
                  index dd72130..e7f73d0 100644
                  --- a/modules/UI/SplashScreen.py
                  +++ b/modules/UI/SplashScreen.py
                  @@ -13,8 +13,8 @@ import os.path
                   import logging
                   from PyQt5.QtCore import Qt
                  -from PyQt5.QtGui import QPixmap, QColor, QLabel
                  -from PyQt5.QtWidgets import QApplication, QSplashScreen
                  +from PyQt5.QtGui import QPixmap, QColor
                  +from PyQt5.QtWidgets import QApplication, QSplashScreen, QLabel
                   from eric6config import getConfig
                   import UI.Info
                  But it got me the following error:
                  2016-11-22, 15:36:40
                  <type 'exceptions.RuntimeError'>:
                  the PyQt4.QtCore and PyQt5.QtCore modules both wrap the QObject class
                    File "modules/pymakr.py", line 368, in <module>
                      main()
                    File "modules/pymakr.py", line 344, in main
                      from UI.UserInterface import UserInterface
                    File "/home/pierre/Logiciel/pymakr/modules/UI/UserInterface.py", line 45, in <module>
                      from E5Gui.E5ZoomWidget import E5ZoomWidget
                    File "/home/pierre/Logiciel/pymakr/modules/E5Gui/E5ZoomWidget.py", line 15, in <module>
                      from .Ui_E5ZoomWidget import Ui_E5ZoomWidget
                    File "/home/pierre/Logiciel/pymakr/modules/E5Gui/Ui_E5ZoomWidget.py", line 9, in <module>
                      from PyQt4 import QtCore, QtGui
                  • U Offline
                    ulno
                    The same errors happen on pymakr_1.0.0.b6-1 under ubuntu yakkety. Just wanted to start. Any way to use command line tools and not pymakr? I have quite some experience with micropython, so what do I need to know to continue?
                    Python 2.7.12+
                    An unhandled exception occurred. Please report the problem
                    using the error reporting dialog or via email to support@pycom.io.
                    A log has been written to "/home/ulno/.pymakr/pymakr_error.log".
                    Error information:
                    2016-11-22, 20:43:00
                    main()
                    Version Numbers:
                    Python 2.7.12+
                    Qt 5.6.1
                    PyQt 5.7
                    sip 4.18.1
                    QScintilla 2.9.3
                    WebKit 538.1
                    Pymakr 1.0.0.b6
                    Platform: linux2
                    2.7.12+ (default, Sep 17 2016, 12:08:02)
                    [GCC 6.2.0 20160914]
                    Distribution Info:
                    /etc/lsb-release
                    DISTRIB_ID=Ubuntu
                    DISTRIB_RELEASE=16.10
                    DISTRIB_CODENAME=yakkety
                    DISTRIB_DESCRIPTION="Ubuntu 16.10"
                    /etc/os-release
                    NAME="Ubuntu"
                    VERSION="16.10 (Yakkety Yak)"
                    ID=ubuntu
                    ID_LIKE=debian
                    PRETTY_NAME="Ubuntu 16.10"
                    VERSION_ID="16.10"
                    HOME_URL="http://www.ubuntu.com/"
                    SUPPORT_URL="http://help.ubuntu.com/"
                    BUG_REPORT_URL="http://bugs.launchpad.net/ubuntu/"
                    PRIVACY_POLICY_URL="http://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
                    VERSION_CODENAME=yakkety
                    UBUNTU_CODENAME=yakkety
                      robert-hh
                      You can always use telnet for the REPL prompt, ftp for file transfer using your favorite tool and your favorite editor. With ubuntu, you can also mount the file system directly in the file manager (go to server) and edit the files in place, if you like. In my view, that works anyhow much better then pymakr with it's very-hard-to-view design.
                      All these 'nice' tools seem just a wast of effort, trying to replace stuff which already exists in better quality and broader selection.
                        Ralph
                        Hi @kephasp and @ulno,
                        At this moment, Pymakr is compatible with PyQt5 but doesn't handle PyQt5 very well. If you already had PyQt5 installed, it'll try to use it anyway. It's very high on our priority list to fix, but for the moment you'll have to uninstall PyQt5. I hope that's not too inconvenient in your cases.
                        • K Offline
                          kephasp
                          In my case, removing PyQt5 means removing Calibre. Not really an option.
                          In the meantime, changing the Debian package to accurately reflect this incompatibility would at least make it obvious what prevents it from working and prevent installing in a non-working environment.
                            robert-hh
                            Oh yes, that#s true. Calibre does not work any more. And since Calibre seems to be stable and I see pymakr still in an early alpha phase, I removed pymakr. It is anyhow not needed, since all the standard tools work and are reliable. If pycom's resources are limited, they should more focus on there boards firmware and not waste time on components, where a lot of alternatives exist for all operating systems.
                            Standard tools
                            Console: telnet, Screen, picocom, putty, Teraterm, ....
                            Filetransfer: ftp, filezilla, fireftp, linux file managers like nautilus, thunar, ...,
                            Code editor: Any editor of your choice. On linux, once you mounted the WiPy/LoPy#s file system in nautilus, you can directly edit the files on the module.
                            • K Offline
                              kephasp
                              We use Pycom or Arduino in a teaching context, where the UI component are rather critical.
                              Not really an option either to teach programming beginners that struggle with writing a 3-line function to use ftp and telnet
                                robert-hh
                                That's a point, but then pymakr should work reliably, like the Arduino UI does, as long as you stick with standard boards. At least, I never had any issues with installing Arduino on Linux or Windows.
                                AFAIK, the Windows version of pymakr has no installation problems, but I just tried an early version for a few moments.
                                • 2 / 2
