    New firmware release 0.9.5.b1, Pymate iOS released and improved docs
    21 Posts 5 Posters 9.0k Views 5 Watching
      alangman @daniel
      Hi @Daniel. I just updated my WiFy 2.0 to the latest firmware version (1. I noticed that I cannot find the RTC module.
      If I import machine and then do a dir(machine); RTC class seems to be missing.
      Best
      Alan
        jmaralc @jmaralc
        @jmaralc In deed I am noticing that I can not connect with pymakr with the serial COM, I did it this morning but through the wifi.....Could it be a defective board?
          livius
          No - pymakr have problem connecting by COM
            jmaralc @livius
            @livius And any suggestion for the board not being detected by any computer/system after connecting it with USB? Any special USB cable is needed? Could you show me a screenshot of how the device list should look like in case of a proper detection?
            Thanks and sorry for the extra work. I was eager to work on the board....I am still but more frustrated.
              jmaralc
              @livius Just some good news. In Ubuntu, I manage to connect the board through the serial port (COM) with the updater and the pymakr. I notice that the port was /dev/ttyUSB0 and I could type it in the linux updater and worked fine.
              Thanks for the help. Motivation comes up again!
                jmaralc @jmaralc
                May I ask which USB cable do you use to connect the board? I lost the connection again with the same cable in Ubuntu, not accessible any more.....
                  livius @jmaralc
                  @jmaralc
                  best use expansion board
                  if you have not one then use any converter - e.g. - remember about voltage 3V3
                  alt text
                    jmaralc @livius
                    @livius Thanks Livius. I am already using the expansion board (the Wipy 2.0 is plugged in).
                    Still no solution...next time today after work. I have some ideas in mind that this board could help a lot but.....well let see whether it improves or at least I manage to solve my problems
                    Cheers
                      livius
                      I work on Windows and there are no problems with updater
                      If you connect GND + GP23 by wire
                      and turn power on(or reset WiPy)
                      and you run Firmware Updater - it work for me without problem with Expansion Board
                        livius
                        if someone have not expansion board then this is i suppose helpfull
                        I attache WiPy2 to computer by UART/USB converter like this
                        alt text
                        • 2 / 2
