    New firmware release v1.17.2.b1 (Flash encryption support)
    firmware
    20 Posts 6 Posters 3.7k Views 6 Watching
      livius @daniel
      @daniel
      Impressive work. Thank you for flash encryption :) I have to test it on the weekend.
      Thank you for fixes also.
      1. Question - what do wdt on boot? I suppose it can be turned on/off?
        But how to access to the object instance then?
        We must create wdt object self and feed it or it is created on boot time with some timeout?
        Maybe i misunderstood this..
      2. https://github.com/pycom/pycom-micropython-sigfox#steps-for-using-secure-boot-and-flash-encryption
        if SECURE=on by default - why?
        robert-hh @daniel
        @daniel Hi Daniel, I have a simple script for testing the µs-timer. Thios script crashed with the new firmware on my FiPy. I cloned the repository new, updated esp-idf. Here is the script:
        import utime
        from machine import Pin
        pin = Pin("P10", Pin.OUT)
        pin(0)
        diff = const(2500000)
        while(True):
            start = utime.ticks_us()
            pin(1)
            while utime.ticks_diff(start, utime.ticks_us()) < diff:
                pass
            pin(0)
                pass
        It just creates an ~0.2 Hz square signal on P10.
        >>> import ttest
        Guru Meditation Error: Core  0 panic'ed (LoadProhibited)
        . Exception was unhandled.
        Register dump:
        PC      : 0x4008cc27  PS      : 0x00060333  A0      : 0x8008b6ed  A1      : 0x3ffd4320
        A2      : 0x3ffd4554  A3      : 0x00060323  A4      : 0x3ffd4538  A5      : 0x00000001
        A6      : 0x000000fe  A7      : 0x00060023  A8      : 0x00000000  A9      : 0x3ffd4554
        A10     : 0x3ffd4554  A11     : 0x00000000  A12     : 0x3ffd4538  A13     : 0x00000001
        A14     : 0x000000fe  A15     : 0x00060023  SAR     : 0x0000000c  EXCCAUSE: 0x0000001c
        EXCVADDR: 0x00000004  LBEG    : 0x400e64bc  LEND    : 0x400e64f8  LCOUNT  : 0x00000000
        Backtrace: 0x4008cc27:0x3ffd4320 0x4008b6ea:0x3ffd4340 0x4008a0a7:0x3ffd4360 0x4008375d:0x3ffd43a0 0x4008380b:0x3ffd43d0 0x400838da:0x3ffd43f0 0x400996cc:0x3ffd4410 0x40083da5:0x3ffd4430 0x400e7bc8:0x3ffd4460 0x401436d9:0x3ffd4480 0x4008b249:0x3ffd44a0
          @robert-hh can you post the crash log?
          • X Offline
            Xykon administrators @livius
            @livius said in New firmware release v1.17.2.b1 (Flash encryption support):
            It is not possible to use secure boot without flash encryption.
            Christian Ehlers
              robert-hh @daniel
              @daniel Done, added.
                livius @Xykon
                @xykon
                but if i do not need to encrypt flash?
                  https://docs.pycom.io/chapter/firmwareapi/pycom/pycom.html#pycomwdtonboottimeouttimeout
                  Just use the WDT as usual when your app starts.
                    livius @daniel
                    @daniel
                    Now its clear :) and docs are refreshed :)
                    • X Offline
                      @xykon
                      Flash encryption and secure boot are optional features.
                      If you want to use secure boot then you also have to use flash encryption.
                      Christian Ehlers
                        livius @Xykon
                        @xykon
                        Then if i do not specify SECURE=on it is not defaulted to on? as you say it is optional.
                        ach!! i ommit ":" it is not about default on only what is default after turned on ;-)
                        if SECURE=on by default:
                        encryption is enabled
                        secure_boot_signing_key.pem is the secure boot key, located relatively to Makefile
                        flash_encryption_key.bin is the flash encryption key, located relatively to Makefile
                        i go to sleep and rest ;-)
                          @robert-hh thanks. I can reproduce it. We will analyse and resolve ASAP.
                            robert-hh @daniel
                            @daniel It crashes not all the time with a crash log. Similar often it simply stalls and cannot even be interrupted with Ctrl-C.
                              robert-hh @daniel
                              @daniel Changing the script into the below makes it stable. Just sleep_ms(1) added to the loop:
                              import utime
                              pin(0)
                              diff = const(2500000-1000)
                              while(True):
                                  pin(1)
                                      utime.sleep_ms(1)
                                  pin(0)
                                      utime.sleep_ms(1)
                                robert-hh @daniel
                                @daniel Similar problems on a simple reboot with Ctrl-D. Just tried it a few times. Empty main.py, empty boot.py.
                                MicroPython 1bf377b on 2018-03-16; FiPy with ESP32
                                PYB: soft reboot
                                network config: ('10.0.0.149', '255.255.255.0', '10.0.0.240', '10.0.0.240')
                                Guru Meditation Error: Core  1 panic'ed (StoreProhibited)
                                Register dump:
                                PC      : 0x4008c239  PS      : 0x00060133  A0      : 0x8008b9be  A1      : 0x3ffe3040
                                A2      : 0x00fe4dc8  A3      : 0x00060120  A4      : 0x00000001  A5      : 0x0000abab
                                A6      : 0xb33fffff  A7      : 0x3ffc2d3c  A8      : 0x0000cdcd  A9      : 0x3ffe3040
                                A10     : 0x0000abab  A11     : 0x00060123  A12     : 0x00060120  A13     : 0x3ffb4fa0
                                A14     : 0x00000003  A15     : 0x00060023  SAR     : 0x00000018  EXCCAUSE: 0x0000001d
                                EXCVADDR: 0x00fe4dc8  LBEG    : 0x4009b2ac  LEND    : 0x4009b2b7  LCOUNT  : 0x00000000
                                Backtrace: 0x4008c239:0x3ffe3040 0x4008b9bb:0x3ffe3070 0x40102cb3:0x3ffe30b0
                                zDoAABEAAABsAQAA
                                dHf9P3Bf/T8gYf0/
                                cF/9P8Bg/T9XcQAAGFL8PxhS/D90d/0/EFL8PwcAAACQw/0/kMP9P3R3/T8AAAAA
                                EgAAACRT/T90aVQAdAClJkZyBeD8qegA////fyBh/T8AAAAAIQAGABIAAAAAAAAA
                                AAAAAAAAAAAAAAAAAAAAAAAAAAAke/0/jHv9P/R7/T8AAAAAAAAAAAEAAAAAAAAA
                                01lAPwAAAACouAlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAINehw==
                                  @robert-hh yeap, I'm seeing that as well....
                                    robert-hh @daniel
                                      robert-hh @daniel
                                      @daniel I reverted back to 1.17.0b1. It looks like the soft reset problem already existed there.
                                      Update: No soft reset problem in version 1.16.0.b1
                                        ssmith
                                        @Xykon You said awhile back that you were working on a release program for FW releases and possibly Beta testing before releasing FW. How close are you to implementing this? I'm having a real hard time accepting the fact that PyCom keeps releasing new FW with very little testing. I have seen issues in almost every FW release that just a minimal QA test should discover. If PyCom's target customers are hobbyists, you have a great product. If PyCom wants to sell products to companies that are trying to base a business off using these devices then something needs to change ASAP. This kind of behavior from PyCom will put many start-ups relying on PyCom out of business.
                                        T 1 Reply Last reply Reply Quote 5
                                          timh @ssmith
                                          @ssmith I would agree with your assessment.
                                          I am endeavoring to use GPY & FiPY to monitor a number of devices in a commercial setting (between 50 and 150 high value devices) which implies that many pycom boards.
                                          The package, functionality (LTE, sigfox, gps) etc.. all go together to make it an ideal platform.
                                          However not being able to get LTE to work, finding a way to repeatably hang device in latest firmware doesn't instill a great deal of confidence.
                                          I have a little bit of time up my sleeve however if I have no traction resolving LTE in the next few weeks, then I must look to another solution.
