New firmware release v1.17.2.b1 (Flash encryption support)
@livius said in New firmware release v1.17.2.b1 (Flash encryption support):
@xykon
but if i do not need to encrypt flash?Flash encryption and secure boot are optional features.
If you want to use secure boot then you also have to use flash encryption.
@xykon
Then if i do not specifySECURE=onit is not defaulted to on? as you say it is optional.ach!! i ommit ":" it is not about default
ononly what is default after turned on ;-)if SECURE=on by default: encryption is enabled secure_boot_signing_key.pem is the secure boot key, located relatively to Makefile flash_encryption_key.bin is the flash encryption key, located relatively to Makefilei go to sleep and rest ;-)
@robert-hh thanks. I can reproduce it. We will analyse and resolve ASAP.
@daniel It crashes not all the time with a crash log. Similar often it simply stalls and cannot even be interrupted with Ctrl-C.
@daniel Changing the script into the below makes it stable. Just sleep_ms(1) added to the loop:
import utime from machine import Pin pin = Pin("P10", Pin.OUT) pin(0) diff = const(2500000-1000) while(True): start = utime.ticks_us() pin(1) while utime.ticks_diff(start, utime.ticks_us()) < diff: utime.sleep_ms(1) start = utime.ticks_us() pin(0) while utime.ticks_diff(start, utime.ticks_us()) < diff: utime.sleep_ms(1) -
@daniel Similar problems on a simple reboot with Ctrl-D. Just tried it a few times. Empty main.py, empty boot.py.
MicroPython 1bf377b on 2018-03-16; FiPy with ESP32 Type "help()" for more information. >>> PYB: soft reboot network config: ('10.0.0.149', '255.255.255.0', '10.0.0.240', '10.0.0.240') Guru Meditation Error: Core 1 panic'ed (StoreProhibited) . Exception was unhandled. Register dump: PC : 0x4008c239 PS : 0x00060133 A0 : 0x8008b9be A1 : 0x3ffe3040 A2 : 0x00fe4dc8 A3 : 0x00060120 A4 : 0x00000001 A5 : 0x0000abab A6 : 0xb33fffff A7 : 0x3ffc2d3c A8 : 0x0000cdcd A9 : 0x3ffe3040 A10 : 0x0000abab A11 : 0x00060123 A12 : 0x00060120 A13 : 0x3ffb4fa0 A14 : 0x00000003 A15 : 0x00060023 SAR : 0x00000018 EXCCAUSE: 0x0000001d EXCVADDR: 0x00fe4dc8 LBEG : 0x4009b2ac LEND : 0x4009b2b7 LCOUNT : 0x00000000 Backtrace: 0x4008c239:0x3ffe3040 0x4008b9bb:0x3ffe3070 0x40102cb3:0x3ffe30b0 ================= CORE DUMP START ================= zDoAABEAAABsAQAA dHf9P3Bf/T8gYf0/ cF/9P8Bg/T9XcQAAGFL8PxhS/D90d/0/EFL8PwcAAACQw/0/kMP9P3R3/T8AAAAA EgAAACRT/T90aVQAdAClJkZyBeD8qegA////fyBh/T8AAAAAIQAGABIAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAke/0/jHv9P/R7/T8AAAAAAAAAAAEAAAAAAAAA 01lAPwAAAACouAlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAINehw== -
@robert-hh yeap, I'm seeing that as well....
This post is deleted! -
@daniel I reverted back to 1.17.0b1. It looks like the soft reset problem already existed there.
Update: No soft reset problem in version 1.16.0.b1 -
@Xykon You said awhile back that you were working on a release program for FW releases and possibly Beta testing before releasing FW. How close are you to implementing this? I'm having a real hard time accepting the fact that PyCom keeps releasing new FW with very little testing. I have seen issues in almost every FW release that just a minimal QA test should discover. If PyCom's target customers are hobbyists, you have a great product. If PyCom wants to sell products to companies that are trying to base a business off using these devices then something needs to change ASAP. This kind of behavior from PyCom will put many start-ups relying on PyCom out of business.
@ssmith I would agree with your assessment.
I am endeavoring to use GPY & FiPY to monitor a number of devices in a commercial setting (between 50 and 150 high value devices) which implies that many pycom boards.
The package, functionality (LTE, sigfox, gps) etc.. all go together to make it an ideal platform.
However not being able to get LTE to work, finding a way to repeatably hang device in latest firmware doesn't instill a great deal of confidence.
I have a little bit of time up my sleeve however if I have no traction resolving LTE in the next few weeks, then I must look to another solution.
