    Pytrack + FiPy setup on Win7
    pytrackfirmwareinstallationerror
    24 Posts 7 Posters 9.2k Views 7 Watching
      combaindeft
      @jmarcelino
      Hi, I'm on a Mac and I to experience the "no FiPy device is detected when I connect the Pytack+Fipy via USB to the computer" ...
      I've done the installation procedure before on a LoPy+PyTrack combination ... and it worked like a charm.
      But when I try now with the FiPy+PyTrack combo ... I don't get a usb-serial connection ...
      The only way I can get it work is:
      1st) Connect only the PyTrack to usb
      2nd) I get a usb-serial device
      3rd) I then plug the FiPy device into the PyTrack ...
      4th) Now I see the FiPy boot up and run the "pycom.heartbeat(True)" ... Led blinking blue ...
      To re-cap, if I try to power on the FiPy+Track (combo) via usb, it doesn't even boot up (no Led blinking blue) ...
        combaindeft @combaindeft
        @jmarcelino
        I also just tried it with a JST LiPo Battery (FiPy+PyTrack+Lipo-Battery combo) ... and now it boots up and I get a usb-serial...
        So the odd thing is, why does it try to boot-up in DFU-mode when FiPy+PyTrack is connected?
        But it boots as usb-serial-device when only the Pytrack is connected? or when adding a battery, FiPy+PyTrack+Battery ...
        I find this a little bit of strange logic ... and It's a little bit odd ... and I do think there is some sort of issue in the Firmware code (pytrack_0.0.8.dfu)
        Where might one find the Firmware code (pytrack_0.0.8.dfu)? ... so one might have an investigative look at boot sequence of the PyTrack :-)
        • sebS Offline
          seb @combaindeft
          @combaindeft
          Could you try measuring Vin and 3.3 of the FiPy + Pytrack combo that does not show the USB serial? We have had a few customers facing issues that are fixed by using a high quality usb cable that can deliver enough current, the fact it works with a battery suggests this could be the issue.
          As for the code for the pytrack/pysense, at the current time we have not made this open source. This may be something that happens in the future but I can't give any more details at this time.
            combaindeft @seb
            @seb
            A) FiPy+PyTrack+LiPo-Battery (Not-Attached-to-USB3.0)
Vin = 4.09~4.10 V
            3V3 = 3.32 V
            B) PyTrack+USB-Serial-device (Attached-to—USB3.0)
            • same port as A)
              Vin = 4.85 V
              3V3 = 0.23 V
            C) PyTrack+USB-Serial-device (Attached-to—USB3.0) + Hotswap-in-FiPy
            • same port as A) & B)
              Vin = 4.55 V
              3V3 = 3.32 V
            D) PyTrack+FiPy+NO-USB-Serial-device (Attached-to—USB3.0)
            • same port as A) & B) & C)
            • same combo as C)
            • Just unplugged USB from PyTrack, and re-attached it…
              Vin = 1.69~2.51 V
              3V3 = 1.15~1.91 V
            • Also, worth nothing is that if my hand slips with the measuring probes, I get it to “boot-up” by accidentally shorting GROUND & 3V3, and I get a USB-Serial-Devices on my computer [ergo like A), B) & C) …] …
            • And then, I get the same Vin & 3V3 as C)
            • Which makes me conclude that you’ve guys have a Firmware issue!!! … and not a “bad usb-cable” or “bad usb-port” … etc etc.
            • For some reason, in the boot-sequence of the PyTrack Firmware, it choose not to boot-up FiPy and enable USB-Serial …
            • And, again, it’s odd that I can short GROUND & 3V3 with my measuring probes, and then it boots up FiPy and enables USB-Serial…
            • 2 / 2
