Trouble with FiPy code not working
@dylan Thanks for sharing but i am using the Atom not the Visual Studio. But until now the Pymakr still cannot installed.
@mj I've tried lots of different things to get Atom working again with no luck, I just didn't even realize Visual studio was an option, I'm liking it so far.
@dylan Is it Visual Studio code work as the same as the Atom? The language using also the same?
@mj Very similar, the biggest difference I found is the Run/Upload/Download buttons are down the bottom left and I guess it all looks slightly different ofcourse.
@Dylan
I would recommend adding some print statements into the code you shared to see where it gets stuck on your fipy -
@seb Yeah I've been putting print("Line #") to catch the errors, excellent way of debugging. However in this case it makes it all the way to the end, it just never wakes back up from either the deepsleep I have above or the time.sleep(10) I use for quick testing (a print is always on the last line of code to check it makes it there).
two things
Code after a deepsleep will never run, once the device goes to deepsleep and wakes up it will be just like the reset button was pressed, it does not continue execution from where it went to sleep
I see no reason why your module should lock up and not wake from deep sleep with the code sample above, Have you tried the latest firmware?
@seb 1. This is true, I had many prints throughout and I'm reasonably sure I thought of that haha
2. This was tried on the latest firmware and pytrack updates as these were new FiPys just arrived. I've had a few things go right for me so I have a some spare time, I might update a FiPy and try to recreate the error and work from there. -
@dylan said in Trouble with FiPy code not working:
this does not guarantee that you have recent firmware there
@livius I checked that I was downloading the most recent firmware from the most recent firmware upgrader aswell (excellent work there compared to how it was back in November, very user friendly). I believe the current firmware updater even tells us when it needs its own update so I'm pretty sure everything should be up to date there. But I've been wrong before so I'll double check everything at some point this week. I'll check back in when I've re-created the issue or if it works.
Yes the GUI updater will check for updates on start and tell you if you're using the latest version or if there is an update. It should currently say: "Version: 1.12.0.b0 (latest) on the welcome screen. We also made this version of the firmware updater mandatory so you cannot use an older version and successfully update the board.
@xykon @livius @seb I have re-created the problem and it still exists.
I updated my FiPy from 1.11.0.b1 to the most recent 1.17.3.b1 with the Pycom firmware updater 1.12.0.b0.
The only change I made to anything was upgrading the firmware and now the FiPy no longer wakes up from the time.sleep at the end. The code is here:
from network import LoRa from pytrack import Pytrack from coords import Coords from CayenneLPP import CayenneLPP from L76GNSS import L76GNSS from LIS2HH12 import LIS2HH12 import machine from machine import Pin from machine import I2C import socket import binascii import struct import time import array # Initialize LoRa in LORAWAN mode. lora = LoRa(mode=LoRa.LORAWAN, public=1, adr=0, tx_retries=0) # Remove default channels dev_addr = struct.unpack(">l", binascii.unhexlify('269928E2'.replace(' ','')))[0] nwk_swkey = binascii.unhexlify('7A7E7000000F93BD1BB4693127C374FE'.replace(' ','')) app_swkey = binascii.unhexlify('F93BD1BBBA53BBF3B4096A72115E9F5D'.replace(' ','')) for index in range(0, 72): lora.remove_channel(index) lora.add_channel(index, frequency=918000000, dr_min=0, dr_max=3) lora.join(activation=LoRa.ABP, auth=(dev_addr, nwk_swkey, app_swkey), timeout=0) # wait until the module has joined the network while not lora.has_joined(): time.sleep(5) # remove all the non-default channels for i in range(8, 15): lora.remove_channel(i) # create a LoRa socket s = socket.socket(socket.AF_LORA, socket.SOCK_RAW) # set the LoRaWAN data rate s.setsockopt(socket.SOL_LORA, socket.SO_DR, 3) # make the socket blocking s.setblocking(False) time.sleep(2.5) while lora.has_joined(): acc = LIS2HH12() print("Line 51") xyz = acc.acceleration() x = xyz[0] y = xyz[1] z = xyz[2] time.sleep(1) py = Pytrack() battery = py.read_battery_voltage() battery = battery * 10 cayenne = CayenneLPP() time.sleep(1) l76 = L76GNSS(py, timeout=10) lat1 = str(l76.lattitude()) lon1 = l76.longitude() if len(lat1) > 5: lona = lat1 lata = lon1 meta = 9500 lat = float(lona) lon = float(lata) met = float(meta) cayenne.add_gps(4, lat, lon, met) cayenne.add_temperature(6, battery) cayenne.add_accelerometer(5, x, y, z) s.send(cayenne.get_buffer()) if len(lat1) < 5: cayenne.add_accelerometer(5, x, y, z) cayenne.add_temperature(6, battery) s.send(cayenne.get_buffer()) print('No fix') rx = s.recv(256) print("Line 83") if rx: print(rx) print("Line 86") time.sleep(10)To double check everything I just used the firmware updater 1.12.0.b0 to downgrade to 1.11.0.b1 and its now waking up and repeating the code as expected:
Line 51
No fix
Line 83
Line 86
Line 51
No fix
Line 83
Line 86
Line 51
No fixJust to triple check, I updated it again back to 1.17.3.b1 and it still doesn't repeat the code as it does on 1.11.0.b1
Terminal after 10mins of running:
Line 51
No fix
Line 83
Line 86I can't think of anything that might be going wrong, its a bit beyond me, but I'm pretty sure it's not a me thing if the only thing I've changed is the firmware.
Feel free to get me to try any tests you need me to run. -
@dylan
time.sleepis not deep sleep. It will just wait for the given time and then resume execution after that instruction (where deep sleep on the other hand restarts the module on wake up).So unless you add a loop, it will just finish execution.
What you want is probably
machine.deepsleep.NB: to correctly format your code in posts, add ``` on a line before and after your code.
@jcaron This problems occurs with both the time.sleep and deepsleep commands. I've used both commands with this exact code below and had the same problem no matter which sleep function I am using.
@dylan Even though sub-optimal in this case, have you tried the Pytrack-controlled deep sleep?
Also, if you're using deep sleep, you should save/restore the LoRa state (
lora.nvram_save()before going to deep sleep,lora.nvram_restore()when starting), and avoid joining every time you start.Ah, with proper formatting I see you actually have a (weird) loop around the sleep. Can you add a trace after the
time.sleep, as well as one after the end of the loop? -
@jcaron I just added a Print("Line 88") after the timer to check it. While on firmware 1.11.0.b1 it prints after the 10 second wait then goes back to the Line 51 straight away (as expected). On 1.17.3.b1 it does not print anything after the sleep function and just never wakes up. And feel free to give any tips on the loop, as you can tell its a bit rough.
I'll give that lora.nvram_save a look, sounds like a good idea cheers.
@dylan
can you move line before the loop?
acc = LIS2HH12()and do you have pytrack libraries up to date?
I did some extra testing this afternoon, made the main.py file have just:
from pytrack import Pytrack import machine import socket import binascii import struct import time import array print("Line 10") machine.deepsleep(1000) print("Line12")This successfully went into deepsleep (yet to check the mA). However there seemed to be an extra delay for the first time it enters deepsleep of up to 3-5 seconds. (Also would not recommend using 1000ms for a test, I can't hit the ctrl c at the right time to stop the code from work and now it just turns on and off all the time haha... any recommendations there would be much appreciated. )
This I guess is sort of good news however it still doesn't answer why upgrading the firmware makes my other code not work. I am trying to make a stripped down GPS using the examples from github however I still seem to have problems with it waking back up.
Cheers for the help.
simply use safe boot mode
https://docs.pycom.io/chapter/gettingstarted/programming/safeboot.html#safe-boot
P12to 3V3 after reset disable your code execution -
So I have found where I was going wrong for anyone else who ever encounters this problem.
It appears I was putting all my .py files into where the main.py goes instead of having the separate \lib folder :/. Apparently that did nothing wrong in all firmware versions until 1.16. Anyway, lesson learned.
Cheers everyone for you patience.
