    LoPy and nanogateway example: Inaccurate timing prevent OTAA join
    lopyotaattntiming
    30 Posts 5 Posters 9.3k Views 6 Watching
      @daniel Yes, these are the two places which I changed too.
      You are right, I read it too quickly and missed it.
      @daniel While changing tick_us(), we could also change ticks_ms() to be based on the same timer. It's a 64 bit quantity, so the basic timer will not overflow, before ticks_ms() does. Actually, it will not overflow within ~ 14000 years, at which time it might not matter.
      Makes sense!
        robert-hh @daniel
        @daniel @jmarcelino Jose suggested another approach for the ticks_us() function, similar to the ticks_ms() one, which is:
        STATIC mp_obj_t time_ticks_us(void) {
            struct timeval tv;
            gettimeofday(&tv, NULL);
            return mp_obj_new_int_from_uint(((tv.tv_sec * 1000000) + tv.tv_usec));
        But since that one is already implemented in esp32_mphal.c, one could simply use:
            return mp_obj_new_int_from_uint(mp_hal_ticks_us());
        As simple loop test, creating square wave with 5 s period, resulted in period times of 5.00015 to 5.00020 s for all three variants. Besides the extra call level, then using what's already there seems most elegant.
        The test with the nanogateway also succeeded.
        Edit: There are also a mp_hal_ticks_ms() and mp_hal_ticks_s()
        • K Offline
          kiromn
          Can you please tell me which file should i change for the gateway ?
          This issue drives me mad in the last half an year.
            robert-hh @kiromn
            @kiromn The timing issue in the firmware should be solved in V1.17.3.b1. At least that one works for me. It needs the updated nanogateway example form the lib repository, which according to my tests is still off by 10 ms.
            You can also try the version I am using myself, which is here:
            https://github.com/robert-hh/pycom-libraries/blob/nanogateway/examples/lorawan-nano-gateway/nanogateway.py
            You might have to adapt it to your region. There is a definition of WINDOW_COMPENSATION at the begin, which is set to -10ms, to cope with the 10 ms delay I see. The standard code would have that set to 0 (if it would exist).
            • K Offline
              kiromn @robert-hh
              @robert-hh Thanks for the reply. Now the client associates with the gateway, but after that the packets are not relayed to the network. I get like every 16th packet relayed. The gateway and the client are 5 meters away and the client works with other gateways without issues (esp8266+RN2483A)
              In the gateway console i cant see the packet from the client.
              Also there is no Window_compensation in the code.
              The only related code here is:
              UDP_THREAD_CYCLE_MS = const(10)
              WDT_TIMEOUT = const(120000)
              COMPENSATION_SLOPE = const(-4176)
              COMPENSATION_OFFSET = const(-1667)
                robert-hh @kiromn
                @kiromn That's antoher effect, cause by the gateway being singel channel only. After joining, you have to delete in the node script every channel but the first. There was some communication about that in the forum, maybe hard to find. Like:
                # remove all channels but the first
                for i in range(1, 3):
                    lora.remove_channel(i)
                Edit: I changed the gateway script yesterday, such that the delay compensation adapts to different downlink message lengths.
                • K Offline
                  kiromn @robert-hh
                  No luck with disabling channels also.
                    robert-hh @kiromn
                    @kiromn Interesting. I can try this evening again.
                    For my tests, I usually use ABP join, by transferring the device ID and keys from a previous OTAA join. The keys can be taken form the TTN server console.
                      robert-hh @kiromn
                      @kiromn I can confirm your observation. After OTAA join, only few of the messages are captured by the Lopy gateway. A second gateway based on an IC880a receives all messages.
                      using ABP activation and disabling all channels but one, all messages are receievd by the LoPy gateway.
                      • K Offline
                        kiromn @robert-hh
                        @robert-hh I have tried disabling channels, changing port, but it does not work. Do you think you will be able to fix it? I can help with testing :)
                          robert-hh @kiromn
                          @kiromn did you use OTAA join or ABP join?
                          • K Offline
                            kiromn @robert-hh
                            @robert-hh i use OTAA
                              robert-hh @kiromn
                              @kiromn I have again used OTAA join and have sent 10 packets. Below if a screen dump of the TTN console. Only 5 of the 10 packets were seen by my Lopy based gateway. The IC880A gateway has seen them all. You see, that the other packets have been sent at other frequencies, which have been submitted in the join response. At least its SF7BW125. So unless the node cannot be forced to ignore these other frequencies, the nanogateway will not catch them.
                              • K Offline
                                kiromn @robert-hh
                                @robert-hh Yep i see. So, this gateway is not very usable.
                                  robert-hh @kiromn
                                  @kiromn Yes and no. I found the place in loramac.c (starting around line 760), where the channels setting are taken from the OTAA join response. This evening, I will try to supress that. If it works, one can make special Lopy nodes with match the special LoPy gateway.
                                  Anyway, if you need a fully compliant gateway, use another product. The LoPy is designed as a Lora node and works good enough as such.
                                  • K Offline
                                    kiromn @robert-hh
                                    @robert-hh I will just get multichannel gateway. Thank you for the support :)
                                      robert-hh @kiromn
                                      @kiromn Just out of curiosity I made the change to the loramac.c code mentioned below, and indeed then all packets are sent at the same frequency, being seen by the LoPy gateway. The ttn server does not complain. Only the node is then not compliant to the spec.
                                        livius @robert-hh
                                        meybe not compliant to the spec but it is interesting solution
                                        will be good to see it as parameter in init
                                          robert-hh @livius
                                          @livius The implementation would be pretty straight forward. Just a flag and maybe a little helper function in loramac.c, called by init_helper in modlora.c. But I do not know whether this is welcome.
                                            livius @robert-hh
                                            For me it is :)
                                            I can not speak for pycom but many vendors e.g. RDBMS follow standard but contain some useful exceptions required by their users :) If it work in SQL world why not here ;-)
