    errno 12 ENOMEM ?
    bluetoothenomembeaconslopyerrno 12
    21 Posts 7 Posters 8.4k Views 7 Watching
      robert-hh @soren
      @soren That typically happens when you open too many sockets, or try to re-open a socket which is already in use. Please ensure, that you close sockets when you do not need them any more.
      A subtle pitfall is, that a soft reset does not close open sockets. You have to either push the reset button or call machine.reset().
        alvaroav
        Dear all,
        I am working with a wipy 2.0, trying to send data with UDP sockets, and I still have the same problem reported on this thread.
        I am able to send just 3 packets before the OSError: [Errno 12] happens.
        Has anyone solved this issue?
        I also include gc.enable() before the message loop, gc.collect() within the loop and gc.disable() before leaving the routine.
        Moreover, the sent message is fixed, just to "Hello"
          robert-hh @alvaroav
          @alvaroav Never call gc.disable(). garbage collection is normally done automatically, gc.collect() just enforces that and can be called to avoid the automatic collection at time critical situations. It will however not help if objects are not released. But I do not think that this is the issue here. As said, I've seen this error in cases, when sockets have been opened and not closed. So you should check the flow of you code, wheter sockets you use are either opened once and then used repeatedly, or closed after use and opened again when needed the next time.
          Edit: I see you code behaves just like that. The only thing that seems a little bit unneeded is to get the addr value again every time you send.
            alvaroav @robert-hh
              alvaroav @robert-hh
              Dear Robert,
              Thanks for your advise on gc.disable().
              Regarding the UDP sockets used:
              1. When I open the socket out of the send loop:
              gc.enable()
              socketUDP = socket.socket(socket.AF_INET, socket.SOCK_DGRAM, socket.IPPROTO_UDP)
              flag = 1
              while (flag<1000):
                  time.sleep(0.1)
                  data=bytes()
                  data = data + b'contador = ' + bytes(str(flag),'utf-8')
                  sent = socketUDP.sendto(data, addr)
                  flag=flag+1
              socketUDP.close()
              the program breaks after 3 sent messages
              when I include the socket open-close commands within the loop, sometimes it reaches the last 1000th message, some others breaks after some messages sent:
              gc.enable()
              flag = 1
              while (flag<1000):
                  time.sleep(0.1)
                  data=bytes()
                  flag=flag+1
                  socketUDP.close()
              Someone knows why sometimes it crashes or some others not?
                livius @alvaroav
                @alvaroav
                I know that you have gc.enable()
                but what if you add also to the end of this loop gc.collect()?
                  alvaroav @livius
                  @livius
                  Dear livius
                  Thanks for your reply.
                  I also include the
                      gc.collect()
                      print('where:', str(gc.mem_free()))
                  without succes.
                  This is what happens from time to time. Sometimes it reached couter= 1000
                  b'contador = 1'
                  where: 48336
                  b'contador = 2'
                  where: 48336
                  b'contador = 3'
                  where: 48368
                    File "<stdin>", line 109, in <module>
                  OSError: [Errno 12] ENOMEM
                  It is really strange. I also use to perform machine.reset() to avoid any left opened connection or socket.
                    livius @alvaroav
                    @alvaroav said in errno 12 ENOMEM ?:
                    add also print statment about (some are duplicated but now worry):
                    print('free:', str(gc.mem_free()))
                    print('info:', str(machine.info()))
                    print('info:', str(gc.mem_alloc()))
                    print('info:', str(micropython.mem_info()))
                    gc.collect()
                    to print above info add at start imports if you do not have it already
                    import gc
                    import micropython
                      alvaroav @livius
                      @livius said in errno 12 ENOMEM ?:
                      gc.collect()
                      Thanks again for your help.
                      This is what I get when I place these lines:
                      b'counter = 1'
                      free: 50176
                      System memory info (in bytes)
                      MPTask stack water mark: 5396
                      ServersTask stack water mark: 980
                      TimerTask stack water mark: 2160
                      IdleTask stack water mark: 604
                      System free heap: 82232
                      info: None
                      info: 16864
                      stack: 768 out of 7168
                      GC: total: 67008, used: 16896, free: 50112
                       No. of 1-blocks: 91, 2-blocks: 26, max blk sz: 384, max free sz: 2854
                      info: None
                      b'counter = 2'
                      free: 50336
                      System free heap: 82048
                      info: None
                      info: 16704
                      GC: total: 67008, used: 16736, free: 50272
                       No. of 1-blocks: 85, 2-blocks: 24, max blk sz: 384, max free sz: 2854
                      info: None
                      b'counter = 3'
                      free: 50352
                      System free heap: 81864
                      info: None
                      info: 16688
                      GC: total: 67008, used: 16720, free: 50288
                       No. of 1-blocks: 89, 2-blocks: 24, max blk sz: 384, max free sz: 2854
                      info: None
                        File "<stdin>", line 110, in <module>
                      MicroPython v1.8.6-849-83e2f7f on 2018-03-19; WiPy with ESP32
                        livius @alvaroav
                        ENOMEM
                        then i have not clue maybe @daniel @administrators can help more
                        i do not see the reason of out of memory exception
                          alvaroav @livius
                          @livius
                          Thanks agian
                          BTW I already ordered a Wipy3.0 module, in order to check that the RAM increase from 512KB to 4MB avoids this issue...
                          I'll keep you updated.
                            alvaroav @alvaroav
                            @alvaroav
                            I received today the new Wipy 3.0, and the problem is still the same.
                            Someone with some ideas?
                              jcaron
                              On what line does the error actually occur? Given the different behaviour when the socket is kept or closed I guess it should be on the socketUDP.sendto line, but just to be sure...
                                alvaroav @jcaron
                                @jcaron
                                Dear jcaron
                                Exactly, is on the socketUDP.sendto line, but sometimes it happens some others not.
                                I open and close the socket every iteration on the loop, as suggested by other users.
                                • sebS Offline
                                  seb
                                  One suggestion would be to set the socket as blocking, then send, then close the socket. This will ensure that all the data has been sent.
                                    blindman2k @alvaroav
                                    @alvaroav I saw the same behavior with the UDP client sockets. I was using UDP sockets to log to a server so I could debug issues remotely but it turned out the biggest issue was actually the UDP logger. I never solved it rather just removed the logger.
                                    What's odd is I have another bidirectional UDP client that works just fine. Maybe the difference is I am reading its buffer with recvfrom() on every loop thus clearing its memory.
                                    I also find the wlan.scan() function throws the same error when there are no networks visible. That exception is caught successfully by a try/except block. Something else you can try.
                                      alvaroav @blindman2k
                                      @blindman2k @seb
                                      Thank you very much for your help and support.
                                      I've been working around this tipic on the last days, atill without a solution, but with some conclusions ready.
                                      I work with a client continously sending data, and a "server" which is an sniffer, listeing to all UDP packets received (liek your UDP logger @blindman2k).
                                      When th elogger is correctly working, and listeing, there is no error
                                      When the sniffer is closed, or the wifi from the sniffer PC is unliked (sometime happens), the error appears.
                                      It seems that the UDP sockets need the confirmation from reception in the server side... this is strange since I understood (maybe I am worng) that the UDP sockets do not rely on any reception acknowldege, and is a lossy protocol (instead of the TCP sockets where the transmission is controlled).
                                      I will still working on the blocking UDP, I havce found some tutorials, but some of them are just for python and not micropython, with different commads not available on our wipy.
                                      Moreover, my idea is to have an stand alone remote sensor sending UDP packets, and a receptor, just sniffering them when required... like the OSC protocol.
                                      http://opensoundcontrol.org/spec-1_0
                                      Thanks and BR
                                        alvaroav @alvaroav
                                        @alvaroav
                                        Dear all,
                                        More advances on the ENOMEN.
                                        I still have random success or unsuccess data transmisios with a UDP client (Wipy) / UDP server (PC host) programs.
                                        However, I tried to use a TCP server on the PC host, and the surprise is that I am able to send data from teh wipy without any ENOMEN error!
                                        Unfortunately the TCP server is not able to receive the data frames (as expected, since I am using UDP for Tx)
                                        This is the code for the TCP server:
                                        # Listen on port 8000
                                        # (to all IP addresses on this system)
                                        #listen_addr = ("",8000)
                                        listen_addr = ('192.168.1.158',8000)
                                        # Set up a TCP server
                                        TCPSock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
                                        TCPSock.bind(listen_addr)
                                        TCPSock.listen()
                                        print("Ready to listen\n")
                                        	TCPSock.accept()		# accept the connection
                                        	data, addr = TCPSock.recvfrom(1024)
                                        	while data:			        # till data is coming
                                        		print(data)
                                        	print("All Data Received")	# Will execute when all data is received
                                        	#TCPSock.close()
                                        	break
                                        Any ideas with this new info?
                                        When I tried to do the same with UDP, both socket.listen() and socket.accept() seems to be "not compatible" with the socet object.
                                        I will still try to develop a success UDP server, based on this new advances.
                                        Thanks to all!
                                          alvaroav @alvaroav
                                          @alvaroav
                                          Dear all,
                                          Some advances by the end of the week.
                                          I have tried from a clean code, just building a new program. I come back to the option to open the socket, send all data in a loop, and at the end of the loop, close the socket.
                                          I am not so sure why, BUT now the ENOMEM error just appears from time to time. Moreover, I don't need any server (blocking or non-blocking) running.
                                          Moreover, I place this exception into the loop, and allow me to "reconnect" and continue the program even if an error appers.
                                          flag = 1
                                          Nerrors = 0;
                                          socketUDP = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
                                          while (flag<200):
                                              time.sleep(0.05)
                                              data=bytes()
                                              data = data + b'counter = ' + bytes(str(flag),'utf-8')
                                              try:
                                                  print(data)
                                                  led.toggle()
                                                  flag=flag+1
                                              except OSError:
                                                  Nerrors+=1
                                                  print('error ', Nerrors)
                                                  continue
                                          socketUDP.close()
                                          I am thinking that the problem might come from the wifi connection to the router... I will check this next week.
                                          BR
