    Pytrack firmware update fails
    firmware updatepytrack
    6 Posts 3 Posters 1.5k Views 3 Watching
      buw
      I get a "dfu-util: Lost device after RESET?" after initiating "dfu-util --device 05ac:8bcd -D ./pytrack_0.0.8.dfu".
      I am running Mac OS X, brewing the dfu-utils. The update of a wipy 2 with an Extension Board was successful.
      Any idea?
      The full output is:
      dfu-util 0.9
      Copyright 2010-2016 Tormod Volden and Stefan Schmidt
      Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
      Deducing device DFU version from functional descriptor length
      ID 05ac:8bcd
      Determining device status: state = appIDLE, status = 0
      Device really in Runtime Mode, send DFU detach request...
      Resetting USB...
        jcaron @buw
        @buw there’s a timing issue to achieve the upgrade which is not necessarily obvious.
        What usually works for me is have the command ready in terminal, press and hold the button, plug in the USB port (on the computer, usually much easier), release button, wait 1 or 2 seconds, hit return. If it doesn’t work, try again.
          buw
          Thanks jcaron for confirming this. I was not really aware of this but operated as you proposed. So I am still not successful.
          Just to note: In the meantime I have tried to run the example code for the acc. sensor. It does not work and shows up with an I2C error. This is probably what I should have expected with the WiPy being updated and the PyTrack operating still with the old firmware.
          • sebS Offline
            seb
            The method I've found works best for me is as follows:
            1. Disconnect the board from USB and remove the **Py board
            2. prepare the dfu command in your terminal but don't press enter
            3. Press and hold the button on the Pysense/Pytrack
            4. Insert the USB
            5. wait a couple seconds
            6. run the dfu command
            You may need to try the above process a couple times to get it work, but this always seems to work the best for me.
              buw
              @seb: Thanks a lot! This time, the update process did not throw any error message. My fault was that I did not remove the **Py board.
                jcaron @buw
                @buw I'm surprised that made a difference, I have nearly always upgraded Pysense boards with a module on. But whatever works for you!
