    Fipy with OTAA node - Nano Gateway - TTN (not join)
    fipyloraotaa
    19 Posts 3 Posters 4.1k Views 3 Watching
      robert-hh @apiwize
      [ 46.132] Received packet: {"rxpk": [{"data": "AOGzANB+1bNwtK98lknVs3CYfmhRlw8=", "time": "2018-04-02T07:01:43.918247Z", "chan": 0, "tmst": 46124070, "stat": 1, "modu": "LORA", "lsnr": 8.0, "rssi": -37, "rfch": 0, "codr": "4/5", "freq": 868.1, "datr": "SF7BW125", "size": 23}]}
      [ 46.199] Push ack
      [ 50.209] Downlink timestamp error!, t_us: -1955412445
      [ 50.216] Pull rsp
      After this line the should be a starting with "Sent downlink packet". Could you include that too in your log?
        apiwize @robert-hh
        @robert-hh Well... I don't receive any "sent downlink" notification. My router should be ok, with port forwarding (1700) on gateway, I am to check in deep if there is no tric on firewall...
        Serial port COM6 opened
        [ 3356.303] Pull ack
        [ 3362.082] Received packet: {"rxpk": [{"data": "AOGzANB+1bNwtK98lknVs3As4NAlkvU=", "time": "2018-04-02T07:56:59.867743Z", "chan": 0, "tmst": 3244603296, "stat": 1, "modu": "LORA", "lsnr": 6.0, "rssi": -60, "rfch": 0, "codr": "4/5", "freq": 868.1, "datr": "SF7BW125", "size": 23}]}
        [ 3362.138] Push ack
        [ 3366.168] Downlink timestamp error!, t_us: 1748657865
        [ 3366.175] Pull rsp
        [ 3366.323] Push ack
        [ 3381.325] Pull ack
        [ 3392.077] Received packet: {"rxpk": [{"data": "AOGzANB+1bNwtK98lknVs3BWv1/hxjA=", "time": "2018-04-02T07:57:29.863851Z", "chan": 0, "tmst": 3273498056, "stat": 1, "modu": "LORA", "lsnr": 6.0, "rssi": -60, "rfch": 0, "codr": "4/5", "freq": 868.1, "datr": "SF7BW125", "size": 23}]}
        [ 3392.144] Push ack
        [ 3396.158] Downlink timestamp error!, t_us: 577930084
        [ 3396.165] Pull rsp
        [ 3406.303] Pull ack
        [ 3422.076] Received packet: {"rxpk": [{"data": "AOGzANB+1bNwtK98lknVs3ASxvFISZM=", "time": "2018-04-02T07:57:59.862767Z", "chan": 0, "tmst": 3302392157, "stat": 1, "modu": "LORA", "lsnr": 6.0, "rssi": -61, "rfch": 0, "codr": "4/5", "freq": 868.1, "datr": "SF7BW125", "size": 23}]}
        [ 3422.134] Push ack
        [ 3426.177] Downlink timestamp error!, t_us: -593913532
        [ 3426.184] Pull rsp
        [ 3426.330] Push ack
        [ 3431.322] Pull ack
          robert-hh @apiwize
          @apiwize I see. Are you sure that you updated the firmware of the gateway to v1.17.3.b1? Other wise the driver for the sx127x chip and the nanogateway script use different timers.
            apiwize @robert-hh
            @robert-hh : Firmware should be OK, I apdate again. I had 1 "result" (but no "join) on the currnt config by turning ther self window compensation (line 189) to 10 000. But just once, see enclosed : 0_1522658173794_7b1d45ff-9118-4aea-a74c-889b355ee097-image.png
              robert-hh @apiwize
              @apiwize The timestamps in you log message are inconsistent. Please check again in your gateway:
              import uos
              uos.uname()
              Remark: the window compensation values should be negative, since the gateway is normally a little bit too late.
                apiwize @robert-hh
                @robert-hh Hi Robert, here is the result :
                (sysname='FiPy', nodename='FiPy', release='1.17.3.b1', version='v1.8.6-849-83e2f7f on 2018-03-19', machine='FiPy with ESP32', lorawan='1.0.2', sigfox='1.0.1')
                Additionnally, after firmware update + back to 6000 ms windows compensation, I obtained, with no payload sent to TTN :
                [ 441.622] Received packet: {"rxpk": [{"data": "AOGzANB+1bNwtK98lknVs3AHN+Adc+8=", "time": "2018-04-02T08:43:10.304316Z", "chan": 0, "tmst": 168393914, "stat": 1, "modu": "LORA", "lsnr": 6.0, "rssi": -61, "rfch": 0, "codr": "4/5", "freq": 868.1, "datr": "SF7BW125", "size": 23}]}
                [ 441.691] Push ack
                [ 445.707] Pull rsp
                [ 446.714] Sent downlink packet scheduled on 173.387, at 868,100,000 Hz using SF7BW125: b' ^\xac\xf3\x93\x91\xec\xcc\x97o\xcf\xe7\x07\x8a\xb4AG#\x81\xef\x0b\x9e\xc3\x7f\xac\xef\xf2`.\xe3\xdc\x95g'
                [ 455.324] Pull ack
                [ 460.337] Push ack
                [ 471.644] Received packet: {"rxpk": [{"data": "AOGzANB+1bNwtK98lknVs3C3/zKOlqs=", "time": "2018-04-02T08:43:40.326154Z", "chan": 0, "tmst": 198392668, "stat": 1, "modu": "LORA", "lsnr": 6.0, "rssi": -62, "rfch": 0, "codr": "4/5", "freq": 868.1, "datr": "SF7BW125", "size": 23}]}
                [ 471.704] Push ack
                [ 475.747] Pull rsp
                [ 476.707] Sent downlink packet scheduled on 203.386, at 868,100,000 Hz using SF7BW125: b' \x9a\x81\x82\x95#\xac\x91\x081H^\xe4\xfb\xa6\xdf\x08ML\x81*1\xd3\x82|T_U[\x1a\xcb1!'
                [ 480.352] Pull ack
                [ 505.342] Pull ack
                [ 520.331] Push ack
                  robert-hh @apiwize
                  @apiwize The timestamps look ok now for a join message. The differences is 4994 ms (5 seconds - 6 ms compensation). in the rx message, microseconds are shown, in the TX message it's seconds. Could be aligned better. You could vary the window_compensation a little bit, like setting it to 0 or -3000. The steps do not have to be too fine.
                    robert-hh @apiwize
                    @apiwize In the initial post, you were using 923MHz frequencies. Now you are at 868.1. Which region are you in?
                      apiwize @robert-hh
                      @robert-hh Hi Robert, sounds to work fine now. I'll try to improve the time windows (I lose about 2 message / 3 for the moment). Anyway, many thanks for your help !
                        robert-hh @apiwize
                        @apiwize after the join worked, the TTN server will send a list of frequencies to use. The node will uses these in a random matter. Unfortunately the nanogateway can listen only to one of these three frequencies, meaning that you will miss 2 of 3 messages. That is not related to timing.
                        The best option then is to switch to abp mode, copying over from the TTN console the values for device address, network session key and app session key.
                        See the discussion at this thread about 10 days ago.
                        https://forum.pycom.io/topic/2728/lopy-and-nanogateway-example-inaccurate-timing-prevent-otaa-join
