    Simple MQTT Tutorial
    34 Posts 13 Posters 30.0k Views 16 Watching
      MrPy
      Hmmm, do you have your Mosquito broker details to hand to i can test?
      I usually have a node-red instance running that connects to my broker so i can quickly test if the broker is up or down. A few of these public test brokers are not that stable so 9/10 it's the broker being down that causes my issues.
        thibault
        Sorry i don't speak very well english, so i hav'nt really understand what you says exactly. But i mean you want data about the different version
        I have use the pycom_update_0.9.3.b2 on the lopy. And for the mosquitto the version is 1.3.4-2. I'm begin in the IoT world, and maybe i have too few knowledge in it for understand you. If i have not answer that you wait, feel good about explain another way.
          MrPy @thibault
          @thibault My apologies, I was replying to vruizil below.
          • V Offline
            vruizvil
            Well, thanks a lot for the comments.
            After uppgrade recent firmware, the code works fine connecting mosquitto broker.
            But, I can't connect two differents sockets with two differentes brokers at same time.
            It needs run .disconnect() function to be abel to use the other one broker.
            I don't know the reason....., well, I'am not a python expert.
            # Initialize MQTT Client
            def settimeout(duration): pass
            def t3_publication(topic, msg):
            	print (topic, ';', msg)
            	pycom.rgbled(0xff00)
            UNIQUE_ID = machine.unique_id()
            MQTT_BROKER = "192.168.2.220"
            MQTT_PORT = 1883
            mqtt_client = MQTTClient(UNIQUE_ID, MQTT_BROKER, port=MQTT_PORT)
            mqtt_client.settimeout = settimeout
            mqtt_client.set_callback(t3_publication)
            mqtt_client.connect()
            MQTT_BROKER_2 = "test.mosquitto.org"
            #MQTT_PORT = 1883
            mqtt_client2 = MQTTClient(UNIQUE_ID, MQTT_BROKER_2, port=MQTT_PORT)
            mqtt_client2.settimeout = settimeout
            mqtt_client2.set_callback(t3_publication)
            mqtt_client2.connect()
              MainSheet
              Dummy question,
              I have the code on my LoPy working :
              from simple import MQTTClient
              import  time
              client = MQTTClient("MainSheet", "broker.hivemq.com", port=8000)
              client.connect()
                  print("Sending ON")
                  client.publish("/lights", "ON")
                  time.sleep(1)
                  print("Sending OFF")
                  client.publish("/lights", "OFF")
                  time.sleep(1)
              output is this
              connected with goofy, channel 1
              Sending ON
              Sending OFF
              Sending ON
              Sending OFF
              Sending ON
              Sending OFF
              Sending ON
              Sending OFF
              Sending ON
              Sending OFF
              Connecting to http://www.hivemq.com/demos/websocket-client/? with Chrome
              Host = broker.hivemq.com
              ClientID = MainSheet
              Port = 8000. ( I tried setting the port to 1883 but then I can't connect to hivemq. I also tried to set the code above to connect to port 8000, however, got an out of range error)
              subscribed to /lights
              however, the messages never get through to HiveMQ
              Steve
              V G 2 Replies Last reply Reply Quote 0
              • V Offline
                vruizvil @MainSheet
                @MainSheet said in Simple MQTT Tutorial:
                broker.hivemq.com
                Try client.disconnect(), then client.connect(). Try on firefox, it works fine in my tests, and try another topic (without slash), ie.: "mylopytopic"
                • V Offline
                  vruizvil @vruizvil
                  @vruizvil
                  For Windows, I use MQTTFX Client. Here the link
                  http://www.jensd.de/apps/mqttfx/
                    gertjanvanhethof Pybytes Beta @MainSheet
                    @MainSheet I'am not able to connect.
                    What do I wrong?
                    In my main.py I setup the wifi connection successfully.
                    I checked that by doing an http get call and I was able to get HTML data from a website. So internet connection is working.
                    I went to: http://www.hivemq.com/demos/websocket-client/
                    And created a connection with the following details:
                    Host: broker.hivemq.com
                    Port: 8000
                    ClientID: MyLoPy
                    I created a subscription and tested some messages. All works.
                    Then I typed the following commands on my LoPy:
                    MicroPython v1.8.6-40-gd10463e on 2016-11-25; LoPy with ESP32
                    from umqtt import MQTTClient
                    client = MQTTClient("MyLoPy", "broker.hivemq.com", port=8000)
                    client.connect()
                    0xc b'10:12:00:04:4d:51:54:54:04:02:00:00'
                    File "umqtt.py", line 86, in connect
                    IndexError: bytes index out of range
                    • V Offline
                      vruizvil @gertjanvanhethof
                      @gertjanvanhethof Hi!, try with machine.reset(), then try your code one more time, you need only one client socket, when you try few times the code, I think the socket doesn't work fine. That is the way to solve the same problem in my tests, but I don't know the reason.
                        gertjanvanhethof Pybytes Beta @vruizvil
                        @vruizvil
                        My code is as following:
                        def connect():
                        if machine.reset_cause() != machine.SOFT_RESET:
                        client = MQTTClient("MyLoPy", "broker.mqttdashboard.com", port=8000)
                        client.connect()
                        print('Connected MQTT Broker.')
                        return client
                        def send(client):
                        print("Sending ON")
                        client.publish("/lopy", "ON")
                        time.sleep(1)
                        client.publish("/lopy", "OFF")
                        time.sleep(1)
                        I do a connect() and the result is as following:
                        client.connect()
                        Still going wrong. What could be the solution?
                          gertjanvanhethof Pybytes Beta @MrPy
                          @MrPy Are you sure those are you messages? I checked and somebody else was publishing these messages.
                            gertjanvanhethof Pybytes Beta @gertjanvanhethof
                            I found the error. The port is wrong.
                            It should be: 1883.
                            Then connect is working.
                              gas @vruizvil
                              @vruizvil Hi
                              I started a mosquitto on my laptop (vm debian) and it is working with the code as it is i updated it a little to make it configurable via config param file (wifi and mqtt)
                              what error you are getting ?
                                gertjanvanhethof Pybytes Beta @gas
                                @gas It's working now. The used port was wrong. Thxs for your help.
                                  RSK
                                  MQTTClient is missing in the latest firmware, using the image release on 02/Dec/2016.
                                  Could someone confirm this.
                                  0_1481092220727_upload-95d4b814-1a49-47db-b229-f9092eb4c7e0
                                    sakis @RSK
                                    @RSK umqtt is not part of Pycom's firmware or standard micropython. It is an external Python library, so to be able to use it you need to upload it to your device.
                                    The easiest way to do that is using Pymakr. Another way is using plain FTP (https://docs.pycom.io/pycom_esp32/pycom_esp32/general.html#local-file-system-and-ftp-access).
                                    Please read step 2 again and try to follow the instructions. If you have any problems let us know.
                                      RSK
                                      @sakis Thanks!
                                      I have downloaded umqtt.simple.py from https://github.com/micropython/micropython-lib and placed it in /flash/simple.py of the LoPy using FTP.
                                      And trying to connect from my LoPy application:
                                      0_1481109485470_upload-f0cd9d87-92ef-4d6a-8a64-b3240df41eb4
                                      With Hive settings:
                                      0_1481109531558_upload-397a9e59-4d48-495d-9538-b57cf969c284
                                      But connect fails with error "bytes index out of range":
                                      0_1481109598988_upload-974ac761-263f-4c25-8604-d9a97e83b289
                                      Please help to resolve.
                                      Thanks & Regards,
                                      Satish Kumar. R.
                                        RSK
                                        Sorry the link i provided is incorrect, downloaded from the below link:
                                        https://pypi.python.org/pypi/micropython-umqtt.simple
                                        And the changes done to line number 57 "self.sock.settimeout(self.timeout)"
                                        Thanks & Regards,
                                        Satish Kumar. R.
                                          sakis @RSK
                                          @RSK Have you tried using port 1883 instead of 8000?
                                            RSK
                                            I am trying in Windows, by default http://www.hivemq.com/demos/websocket-client/
                                            give port number 8000.
                                            If i try to change in the browser to 1883 then socket connection fails in websocket client.
