    LoPy: socket send command
    lopy lorawanlorawan otaasend datasocketpytrack
    19 Posts 4 Posters 4.1k Views 4 Watching
      robert-hh @DDA
      @dda Yes, I understand.- But if you do not run it from a local file, the line number for the error is always 1, which is not helpful.
        DDA @robert-hh
        The error it seems is for the s.send, sorry new to this so excuse my brevity.
        from network import LoRa
        import binascii
        import struct
         lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.US915)
        app_eui = binascii.unhexlify('00xxxxxxxxxxxx00')
         app_key=binascii.unhexlify('53BF98xxxxxxxxxxxxxxxxxxxxxxxxxx')
        s.setblocking(True)
        s.send(bytes([0x11,0x0E,0xE2,0x06,0xBD,0x06,0x34,0x34,0x34,0x00]))
        At Run
        OSError: [Errno 100] ENETDOWN**
        s.setblocking(False)
        data = s.recv(64)
        print(data)
          robert-hh @DDA
          @dda And, after a OTAA join request, you have to wait & check lora.has_joined() for a join confirm. That will arrive earliest 5 seconds after the request. See also the example at https://github.com/pycom/pycom-libraries/blob/master/examples/lorawan-nano-gateway/otaa_node_US915.py
          That's why you cannot send yet.
            DDA @robert-hh
            @robert-hh @jcaron @jmarcelino
            Thank you @robert-hh & @jcaron .Per your suggestions, I did try adding a "manual" delay in my code posted earlier and the s.send error was resolved, but still no data post...maybe I WAS missing the window of time with the manual method. So I took the code you suggested and modified it.
            import binascii
            import struct
            import config
            # create an OTA authentication params
            dev_eui = binascii.unhexlify('00xxxxxxxxxxxx00')
            app_eui = binascii.unhexlify('00xxxxxxxxxxxx00'')
            app_key = binascii.unhexlify('53BF98xxxxxxxxxxxxxxxxxxxxxxxxxx')
            pycom.heartbeat(False)  # disable the blue blinking
            pycom.rgbled(0xffa500)  # make the LED light up Orange if the loop reaches here
            # join a network using OTAA**
            join_wait = 0
                time.sleep(2.5)
                if not lora.has_joined():
                    join_wait += 1
                    if join_wait == 5:
                        join_wait = 0
                    break
            # create a LoRa socket/ data rate / blocking
            s.setblocking(True)
            # send this dummp data
            #databytes = 0x110EE206BD0634343400
            #s.send(databytes)
            data = s.recv(64)
            print(data)
            pycom.rgbled(0x00ff00)  # make the LED light up Green if the loop reaches here
            I am running firmware 1.17.3.b1 on the LoPy board to which seems be the latest
            When I tried to Run and Upload the above program with VS Code 1.22.2, I get error for "import config" :as no module named 'config' .Following a similar post for import network error I assumed if I uploaded it it will be ignored, but does not seem to be the case. I also tried from lib import config.
            D robert-hhR 2 Replies Last reply Reply Quote 0
              DDA @DDA
                jcaron @DDA
                @dda you can edit your previous posts. Also please edit them to add ``` before and after the code sections so they are properly formatted (python code is very sensitive to indentation, and it’s completely lost with the appropriate formatting).
                Also, do not try to join again, the LoRaWAN stack will retry by itself. Just wait for lora.has_joined() to become true.
                  robert-hh @DDA
                  @dda databytes is still the wrong format. Is has to by a string or a bytes array. In one of your previous posts, it had the right format already.
                  P.S.: I re-edited your post to insert the lines with the three backticks (```). You added backquotes; hard to tell the difference.
                    DDA @robert-hh
                    Thank you, I edited the s.send to match your suggestion and is reflected in my code now.
                    s.send(bytes([0x11,0x0E,0xE2,0x06,0xBD,0x06,0x34,0x34,0x34,0x00])).
                    But, I continue to have problem with "import config", I searched the forum for that error, no one reported that except for one forum where a user reported error with "import network". It was suggested that the error be ignored and pymark code should take care of it at upload.
                    Here are my errors at Run:
                    ♦Traceback (most recent call last):
                      File "<stdin>", line 8, in <module>
                    ImportError: no module named 'config'
                    MicroPython v1.8.6-849-83e2f7f on 2018-03-19; LoPy with ESP32
                    Error at Upload
                    Reading file status
                    No files to upload
                    ets Jun  8 2016 00:22:57
                    rst:0x7 (TG0WDT_SYS_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
                    configsip: 0, SPIWP:0xee
                    mode:DIO, clock div:1
                    load:0x3fff8028,len:8
                    load:0x3fff8030,len:1728
                    load:0x4009fa00,len:0
                    load:0x4009fa00,len:14584
                    entry 0x400a059c
                      File "main.py", line 2, in <module>
                    KeyError: __main__
                    I added "import config" to a simple LED code, which was previously working but with addition of import config even that file does not want to run/upload properly. Is this a version issue with Visual Studio 1.22.2 or Pymakr 0.1.7, my Python Environment is 3.6
                    Thanks again for all your help.
                      jcaron
                      import config is just used for people who put the device-specific configuration parameters in a separate file called config.py... If you have all your parameters in your main script you don't need it.
                        DDA @jcaron
                        @jcaron @robert-hh @jmarcelino
                        Thanks, that definitely helped and I was able to compile and upload the program with no error. LoPy successfully joins/accepts the LoRaWAN gateway, I can see the join/accept on the Senetco portal. So, I modified the code to run the the send portion only in a while true loop every 10 minutes ( for now with the same data payload):
                        send_interval=10
                        seconds=60
                        count=0
                            count+=1
                            print( "Send data loop %d"%count)
                            pycom.rgbled(0x32CD32) # LIMEGREEN LED
                            time.sleep(1)
                            pycom.rgbled(0xffffff)  # White LED
                            time.sleep(1)
                            time.sleep(1)
                            s.setblocking(True)
                            data = s.recv(64)
                            print(data)
                            print(" Send data success....Entering sleep mode")
                            pycom.heartbeat(True)
                            time.sleep(send_interval*seconds)
                        The uplink is hit and a miss, sometimes it uplinks the first time on power up and then nothing for hours, while on my output side its reporting that send has been successful every 10 minutes.
                          jcaron @DDA
                          @dda In the US region, there are a lot of channels a gateway is supposed to listen on, but most usually only listen on a small subset due to hardware limitations. If the network does not correctly send the relevant info to the device, it will try sending on channels the gateway may not be listening on.
                          The best solution is for the network to correctly send the relevant info, but the alternative is to disable channels on the LoPy (which depends on the actual gateway config).
                            DDA @jcaron
                              DDA @jcaron
                              @jcaron
                              Thanks a lot , limiting the channels to 0-8 and 64 ( for join/accept) did the trick for now.
