deep sleep lopy pysense
  • Hello,
    I wrote this code for my pysense and lopy combination.
    The plan is to send data every half hour and between sending data the lopy has to be in deep sleep mode.
    FOr that i need to save the lora connection settings with the nv ram save and restore commands.
    # LoRaWAN (ABP)
    from network import LoRa
    from mqtt import MQTTClient
    import binascii
    import struct
    from deepsleep import DeepSleep
    import ujson
    import gc
    from pysense import Pysense
    from SI7006A20 import SI7006A20
    from LTR329ALS01 import LTR329ALS01
    from MPL3115A2 import MPL3115A2,ALTITUDE,PRESSURE
    py = Pysense()
    mp = MPL3115A2(py,mode=ALTITUDE)
    mpp = MPL3115A2(py,mode=PRESSURE)
    si = SI7006A20(py)
    lt = LTR329ALS01(py)
    ds = DeepSleep()
    gc.enable()
    loraSaved = pycom.nvs_get('loraSaved')
    if not loraSaved:
        lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868)
        for i in range(3, 16):
        lora.remove_channel(i)
        # create an ABP authentication params
        dev_addr = struct.unpack(">l", binascii.unhexlify('14 20 3D xx'))[0]
        nwk_swkey = binascii.unhexlify('ac 6d 18 07 7f 5e 30 a1 4a 2e 3c 90 c1 58 27 xx')
        app_swkey = binascii.unhexlify('27 22 bd dc ec fd 1d 80 b0 ed a3 01 17 99 f3 xx')
        # join a network using ABP (Activation By Personalization)
        lora.join(activation=LoRa.ABP, auth=(dev_addr, nwk_swkey, app_swkey))
        print('Joining the LoRa network')
        while not lora.has_joined():
            time.sleep(2.5)
            print('Not joined yet...')
            machine.idle()
        # create a LoRa socket
        # set the LoRaWAN data rate
        # make the socket blocking
        s.setblocking(False)
        time.sleep(5)
        s.send('LoRa Saved')
        time.sleep()
        lora.nvram_save()
        pycom.nvs_set('loraSaved', 1)
        print("Going to DeepSleep")
        ds.enable_pullups('P17')  # can also do ds.enable_pullups(['P17', 'P18'])
        ds.enable_wake_on_fall('P17') # can also do ds.enable_wake_on_fall(['P17', 'P18'])
        ds.go_to_sleep(30*60)  # go to sleep for 15 minutes
        lora.nvram_restore()
        mqData = {}
        gc.collect()
        mqData ["m"] = {}
        mqData ["m"]["T"] = mp.temperature()
        mqData ["m"]["P"] = (mpp.pressure()/100)
        mqData ["m"]["H"] = si.humidity()
        mqData ["m"]["B"] = py.read_battery_voltage()
        enc = ujson.dumps(mqData)
        gc.collect()
        s.send(enc)
        pycom.nvs_set('loraSaved', 0) # reset for next test
        print('STA node sending packet ...')
        print(enc)
        print('LoRa data saved')
        time.sleep(5)
    # get any data received...
    data = s.recv(64)
    print(data)
    But at the end there is an error message on line 37. Does anybody know what i am doing wrong?
    Please let me know.
    With kind regards, Han
  • @jmarcelino I use a Lopy direct on the KPN LoRa network.
    What should it be in place of this part of code?
  • Also, I don’t think you need to save the LoRa state independently. Just use lora.nvram_restore directly, and check lora.has_joined to decide whether you should join or not.
  • @han
    I don't understand why you are trying to remove channels 3-16 in the EU868 region? What type of gateway do you have?
    In any case the indentation seems wrong in the for loop
4 out of 4
