Where do you start or find at least example code?
I just learned coding in python to make a prototype for a simple measuring device.
I wanted to make a quick program that measures al the sensor data on the pysense and saves it on a SD-card.But i don't know where to start? Are there tutorials?
What do i have to import, what are he names of the sensors?I'm close to throwing the whole thing away, there is no simple starting point for an absolute beginner in this field.
@freddy I suggest you start here: https://docs.pycom.io/chapter/pytrackpysense/ and go through all the chapters of that section. It will ultimately bring you to this example code https://github.com/pycom/pycom-libraries/blob/master/pysense/main.py which shows how to use each sensor.
@freddy I have some Pysense code to send almost all of it over LoRa. Might be useful as a starting point. It is on GitHub at
https://github.com/smbunn/FiPy in the python program 'sense.py' and the latest copy is pasted below.# See https://docs.pycom.io for more information regarding library specifics from network import LoRa #import config from pysense import Pysense from LIS2HH12 import LIS2HH12 from SI7006A20 import SI7006A20 from LTR329ALS01 import LTR329ALS01 from MPL3115A2 import MPL3115A2,ALTITUDE,PRESSURE import time # import library for delay times import pycom import socket import binascii import struct import ujson # Colors off = 0x000000 red = 0xff0000 green = 0x00ff00 blue = 0x0000ff yellow = 0xffff00 # Initialize LoRa in LORAWAN mode. lora = LoRa(mode=LoRa.LORAWAN) # Set up KotahiNet channels lora.add_channel(0, frequency=864862500, dr_min=0, dr_max=5) lora.add_channel(1, frequency=865062500, dr_min=0, dr_max=5) lora.add_channel(2, frequency=865402500, dr_min=0, dr_max=5) lora.add_channel(3, frequency=865602500, dr_min=0, dr_max=5) lora.add_channel(4, frequency=865985000, dr_min=0, dr_max=5) lora.add_channel(5, frequency=866200000, dr_min=0, dr_max=5) lora.add_channel(6, frequency=866400000, dr_min=0, dr_max=5) lora.add_channel(7, frequency=866600000, dr_min=0, dr_max=5) # Turn off hearbeat LED pycom.heartbeat(False) # create an ABP authentication params dev_addr = struct.unpack(">l", binascii.unhexlify('00 70 C3 4D'.replace(' ','')))[0] nwk_swkey = binascii.unhexlify('1BFE9C81AD35B39019244D155CE31D88'.replace(' ','')) app_swkey = binascii.unhexlify('045ABBEFE974D3E257AC31522E8E837B'.replace(' ','')) # join a network using ABP (Activation By Personalization) lora.join(activation=LoRa.ABP, auth=(dev_addr, nwk_swkey, app_swkey)) # create a LoRa socket s = socket.socket(socket.AF_LORA, socket.SOCK_RAW) # set the LoRaWAN data rate s.setsockopt(socket.SOL_LORA, socket.SO_DR, 0) # Builds the bytearray to send the request py = Pysense() si = SI7006A20(py) lt = LTR329ALS01(py) li = LIS2HH12(py) for count in range (2000): print("Count=", count) vt = py.read_battery_voltage() print("Battery voltage: " +str(vt)) dew = si.dew_point() print("Dew point: "+ str(dew) + " deg C") mp = MPL3115A2(py,mode=ALTITUDE) # Returns height in meters. Mode may also be set to PRESSURE, returning a value in Pascals print("MPL3115A2 temperature: " + str(mp.temperature())) temp1 = mp.temperature() alt1 = mp.altitude()+100.0 print("Altitude: " + str(alt1)) mpp = MPL3115A2(py,mode=PRESSURE) # Returns pressure in Pa. Mode may also be set to ALTITUDE, returning a value in meters press1 = mpp.pressure() print("Pressure: " + str(press1)) #Pressure does not work too well temp2 = si.temperature() hum1 = si.humidity() print("Temperature: " + str(temp2)+ " deg C and Relative Humidity: " + str(hum1) + " %RH") t_ambient = 24.4 relhum = si.humid_ambient(t_ambient) print("Humidity Ambient for " + str(t_ambient) + " deg C is " + str(relhum) + "%RH") print("Light (channel Blue lux, channel Red lux): " + str(lt.light())) acct = li.acceleration() acc1 = acct[0] acc2 = acct[1] acc3 = acct[2] roll1 = li.roll() pitch1 = li.pitch() print("Acceleration: " + str(acc1)) print("Roll: " + str(roll1)) print("Pitch: " + str(pitch1)) # Flash the light every time a payload is sent pycom.rgbled(blue) time.sleep(0.5) pycom.rgbled(off) time.sleep(0.5) pycom.rgbled(red) time.sleep(0.5) pycom.rgbled(off) data = bytearray(48) data[0:4] = bytearray(struct.pack(">i", count)) data[4:8] = bytearray(struct.pack(">f", vt)) data[8:12] = bytearray(struct.pack(">f", dew)) data[12:16] = bytearray(struct.pack(">f", temp1)) data[16:20] = bytearray(struct.pack(">f", alt1)) data[20:24] = bytearray(struct.pack(">f", press1)) data[24:28] = bytearray(struct.pack(">f", temp2)) data[28:32] = bytearray(struct.pack(">f", hum1)) data[32:36] = bytearray(struct.pack(">f", relhum)) data[36:40] = bytearray(struct.pack(">f", acc1)) data[40:44] = bytearray(struct.pack(">f", acc2)) data[44:48] = bytearray(struct.pack(">f", acc3)) # data[48:52] = bytearray(struct.pack(">f", roll1)) # data[52:56] = bytearray(struct.pack(">f", pitch1)) print ('Data = ',count,vt,dew, temp1, alt1, press1, temp2, hum1, relhum, acc1, acc2, acc3, roll1, pitch1 ) s.setblocking(True) s.send(data) # send buffer to AWS print('data sent') time.sleep(0.5) # get any data received& s.setblocking(False) data = s.recv(64) time.sleep(0.5) print(data) #anything received?time.sleep(20) # wait time between packets sent time.sleep(59)Note : I had to comment out the last two float values for roll and pitch as you are limited to 51 bytes when using SF12.
The Git Hub has my Node--Red implementation which decodes the payload.Simon
