    Pybytes registration with Lora OTAA
    pybytes
    3 Posts 2 Posters 992 Views 2 Watching
      asavvin
      Hello!
      I was able to register Lopy4 with Pytrack with new Pybytes.
      But I don't see its registered on TTN.
      I see there is option to download config.py to local machine.
      I downloaded and checked file I have noticed parameters not the same as I created on TTN for
      'app_key': '',
      'app_eui': '',
      'app_device_eui': ''
      even I corrected file and uploaded to Lopy4, when Lopy4 started I am getting an error message
      Uploading project (flash)...
      Not safe booting, disabled in settings
      Reading file status
      Creating dir lib
      [1/10] Writing file boot.py
      [2/10] Writing file config.py
      [3/10] Writing file lib/OTA.py
      [4/10] Writing file lib/mqtt.py
      [5/10] Writing file lib/mqtt_core.py
      [6/10] Writing file lib/pybytes.py
      [7/10] Writing file lib/pybytes_library.py
      [8/10] Writing file lib/pybytes_protocol.py
      [9/10] Writing file lib/terminal.py
      [10/10] Writing file main.py
      OKets Jun 8 2016 00:22:57
      rst:0x7 (TG0WDT_SYS_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff8028,len:8
      load:0x3fff8030,len:1728
      load:0x4009fa00,len:0
      load:0x4009fa00,len:14584
      entry 0x400a059c
      Using configuration config.py file from /flash folder
      WMAC: 30aea4785f7c
      Firmware: 1.17.5.b2
      WiFi connection established
      Using 8192 bytes as stack size
      Connected to MQTT mqtt.pybytes.pycom.io
      main.py was executed properly (using a firmware that does not include frozen libraries)
      File "_main.py", line 184, in <module>
      File "/flash/lib/pybytes.py", line 60, in send_virtual_pin_value
      File "/flash/lib/pybytes_protocol.py", line 526, in send_pybytes_custom_method_values
      TypeError: unsupported types for : 'str', 'int'
      MicroPython v1.8.6-849-b9d53b40 on 2018-05-03; LoPy4 with ESP32
      Thank you
        jmarcelino @asavvin
        Hi @asavvin
        Pybytes assigns it's own TTN account to the device, you shouldn't change it to yours. That's probably what caused the issue if I understand it correctly.
          asavvin
          Thank you for your comments. I was able to get it work w/o error, but since OTAA connection is more complex I tried to use ABP, but I am facing another issue I believe with 3d parameter for ABP. I could not define it in config.py correctly.
          configuration defined to use first lora_abp first
          server': 'mqtt.pybytes.pycom.io',
          'network_preferences': ["lora_abp","wifi"],
          ABP defined as:
          abp': {
          'nwk_skey': 'xxx',
          'app_skey': 'xxx',
          'dev_addr': 'xxxxxx'
          getting an error message for 3d parameter
          WMAC: 30aea4785f7c
          Firmware: 1.17.5.b2
          File "_main.py", line 95, in <module>
          File "/flash/lib/pybytes.py", line 30, in connect_lora_abp
          TypeError: function takes 3 positional arguments but 2 were given
