    Lopy4 Guru meditation error
    firmwarelopy4errorguru meditationguru error
    37 Posts 4 Posters 9.5k Views 4 Watching
      jmarcelino @bjsi9
      Hi @bjsi9
      Does the code do anything visible before this crash?
      Have you tried erasing the erasing the filesystem with os.mkfs('/flash') and re-uploading your code?
      If so I'd appreciate if you could email your main.py to me at jmarcelino@pycom.io
      Thank you.
      B M 6 Replies Last reply Reply Quote 0
        bjsi9 @jmarcelino
        @jmarcelino Thank you for response.
        I have "erased the flash file system" via the Updater tool. I cannot do it manually in the line command, because the error keeps re-displaying.
        It did not help to erase the filesystem. This is what the code does before the chrash:
        configsip: 0, SPIWP:0xee
        mode:DIO, clock div:1
        load:0x3fff8028,len:8
        load:0x3fff8030,len:1728
        load:0x4009fa00,len:0
        load:0x4009fa00,len:14584
        entry 0x400a059c
        MicroPython v1.8.6-849-83e2f7f on 2018-03-19; LoPy4 with ESP32
        >>> Guru Meditation Error: Core  0 panic'ed (InstrFetchProhibited)
        . Exception was unhandled.
        Register dump:```
          bjsi9 @jmarcelino
          @jmarcelino Hi, i've just tried with a new LoPy4. Using FTP instead of Atom to upload. Same problem.
          I'm gonna sent my main.py to you now.
          Thank you!
            bjsi9 @jmarcelino
            @jmarcelino
            So this is what i know so far:
            • New Lopy4 (from package) updated to latest stable firmware connected to Pymakr. No error.
            • Upload my code, the guru meditation error comes
            • Upload and overwrite the main.py back to standard (empty). Reboot. Still dumb error.
              bjsi9 @jmarcelino
              @jmarcelino I managed to sneak in the os.mkfs('/flash') command.
              But still no luck. see pictures:
                robert-hh @bjsi9
                @bjsi9 Does that also happen with the safe boot (P12 at 3.3v during reset)?
                  bjsi9 @robert-hh
                  @robert-hh Hi, no error if i safe boot!
                  But when i remove the jumper, the errors comes back.
                  Also after reset.
                    robert-hh @bjsi9
                    @bjsi9 That means, like you suspekt, the crash is caused by something in main.py, or by the attempt of accessing main.py. Safe boot does not run boot.py or main.py.
                      bjsi9 @robert-hh
                      @robert-hh Thanks, good point.
                      Here is fresh pictures of what is in the boot and main, that still gives me error:
                        robert-hh @bjsi9
                        @bjsi9 main.py looks definitely uncritical. I'm a little bit thinking about boot.py, because setting REPL to UART0 is the default. I have to check this evening back home what I have on my devices. But you could try to comment that out. During safe boot you will still have access to the file system via ftp. I would not use Pymakr for that basic debug stuff. It has its own complications.
                          bjsi9 @robert-hh
                          @robert-hh Hi, the boot.py is the same code as on my SiPy. And that has no error.
                            bjsi9
                            I just updated my Sipy (which have been working for half year). And now i have the exsact same problem with Guru error.
                            (i dont know which firmware was on before the upgrade, i will try to find out)
                            Update: its 1.15.0.b1
                              robert-hh @bjsi9
                              @bjsi9 Looking into the sources, this is the code in the embedded _boot.py, which is executed on any boot, even the safe boot:
                              # _boot.py -- always run on boot-up, even during safe boot
                              from machine import UART
                              os.dupterm(UART(0, 115200))
                              So this code is not required in boot.py, and you can drop it. Do the file copying with ftp. The youre sure about what you get.
                                robert-hh @bjsi9
                                @bjsi9 Duplicating the dupterm code in boot.py does not hurt, at least in my test with a FiPy and a WiPy.
                                  bjsi9 @robert-hh
                                  Hi @robert-hh , still no luck.
                                  The LoPy4 boots, and are ready for commands. But after some seconds it chrashes with the Guru error. Then it boots again, and chrashes again.. and so on.
                                  Very sad story for my 2 Sipy's and 2 LoPy4's. But i'm sure we will find a solution at some point. Any suggestions are welcome :)
                                    bjsi9
                                    New update:
                                    I dont care about my code anymore, i just want the LoPy4 to work as from factory.
                                    I have tried with a new expansionboard, LoPy4 with erased filesystem and downgrading to 1.15.0.b1.
                                    Still chrash chrash chrash every 2 seconds.
                                    No luck after manually flash-reset, or FTP upload standard boot and main.
                                    Safe boot dosent chrash.
                                      robert-hh @bjsi9
                                      @bjsi9 That's strange. I have a Lopy here running since 5 weeks in a row as Lora nanogateway, and some Fipy's for testing, but they never crashed.
                                      • When crashing, do your devices run code or are they just waiting in the REPL prompt?
                                      • Do you always connect the devices in the same way - same expansion board, same cable, same USB port?
                                        bjsi9 @robert-hh
                                        @robert-hh Hi, yes its very strange. I have also some Sipy's for testing, never had any problems. But after upgrade they chrashes all the time, even when downgrading and flash-reset.
                                        • The device starts up, and waits in the prompt with: >>>>
                                          After som seconds, it chrashes.
                                        • I have two expansionsboard, and tested with different USB ports also. Its the same cable i've used since i started working with pycom device the past year.
                                        Remember: the safe boot works
                                          robert-hh @bjsi9
                                          @bjsi9 Looking at the code, this is hard to understand:
                                          With safeboot, only _boot.py is executed.
                                          with normal boot, _boot.py, boot.py, _main.py and main.py are run (in that order). That is mostly th whole difference. This is the section in the file mptask.c, which I'm talking about (line 282 ff):
                                              if (!safeboot) {
                                                  // run boot.py
                                                  int ret = pyexec_file("boot.py");
                                                  if (ret & PYEXEC_FORCED_EXIT) {
                                                      goto soft_reset_exit;
                                                  if (!ret) {
                                                      // flash the system led
                                                      mperror_signal_error();
                                              if (!safeboot) {
                                                  // execute the frozen main first
                                                  pyexec_frozen_module("_main.py");
                                                  // run the main script from the current directory.
                                                  if (pyexec_mode_kind == PYEXEC_MODE_FRIENDLY_REPL) {
                                                      const char *main_py;
                                                      if (MP_STATE_PORT(machine_config_main) == MP_OBJ_NULL) {
                                                          main_py = "main.py";
                                                      } else {
                                                          main_py = mp_obj_str_get_str(MP_STATE_PORT(machine_config_main));
                                                      int ret = pyexec_file(main_py);
                                                      if (!ret) {
                                            bjsi9 @robert-hh
                                            @robert-hh Okay, maybe _boot.py or _main.py is corrupted? What could i do about that, any suggestions? Thanks
