    LoPy4 Firmware upgrade impossible
    lopy4firmware upgradproblem
    23 Posts 3 Posters 5.1k Views 3 Watching
      dicktonyboy
      No route for firmware upgrade works. Finally PuTTy reveals this during a cmdline test any thoughts pls?
      rst:0x10 (RTCWDT_RTC_RESET),boot:0x2b (HSPI_FLASH_BOOT)
      flash read err, 1000
      ets_main.c 371
      ets Jun 8 2016 00:22:57
      ets_main.c 371
      ets_main.c 371
      ets_main.c 371
      rst:0x10 (RTCWDT_RTC_RESET),boot:0x3b (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:2
      load:0x3fff9010,len:12
      ho 0 tail 12 room 4
      load:0x3fff9020,len:388
      load:0x40078000,len:11584
      load:0x4009fb00,len:848
      entry 0x4009fc9c
      MicroPython v1.8.6-798-gebbcca48-dirty on 2017-10-31; LoPy4 with ESP32
      J D 2 Replies Last reply Reply Quote 0
        jmarcelino @dicktonyboy
        @dicktonyboy
        Can you be more clear please? What do you mean by "No route for firmware upgrade works". What exactly is the error?
          dicktonyboy @jmarcelino
          @jmarcelino Well, at it's simplest, downloading and running 'pycon_firmware_update_1.14.2.exe' accepting all defaults and knowing the com port is correct AND ensuring the port is available (no other software running) The result is 'Upgrade failed Failed to connect ESP32: Invalid head of packet (\x08)' In all other ways I'm pushing and getting files back and forth and running program happily. 1st expereince with these modules and they are almost simple to use than Arduino.
            robert-hh @dicktonyboy
            @dicktonyboy Did you connect P2 to GND, or use the Expansion board 3?
              dicktonyboy @robert-hh
              @robert-hh P2 to ground
                @dicktonyboy P2 to GND and then push reset. When you do that with Putty open, you should see something like:
                rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
                waiting for download
                I see somtimes the message about invalid packet header, if the update speed is too high. Then I have to use a lower speed, like 460800 baud or even less.
                  dicktonyboy
                  thats when i get
                  ets_main.c 371
                  ets_main.c 371
                  ets_main.c 371
                  ets_main.c 371
                  ets_main.c 371
                  ho 0 tail 12 room 4
                  entry 0x4009fc9c
                    @dicktonyboy Then the device is NOT in update state. You have to see the message "waiting for download". That turns up when P2 is connected to GND during Reset (push the reset button on the module or pull reset pin low for a short moment.
                    Edit: Reset is not P0, but the one next to P0
                      Now I am confused. Is this sequence described fully anywhere so that I may follow it pls?
                        @dicktonyboy to some extend it is here:
                        https://docs.pycom.io/chapter/gettingstarted/installation/firmwaretool.html
                        In step 4, it says: reconnect
                        That is equivalent to being connected and pushing reset. My experience is, that reconnecting not always brings the device into proper dowload mode, put pushing reset does.
                        Did it work now?
                          @robert-hh Wow your support is faster than I'm allowed to rely (limit 600s). I'm not using a expansion board but this set up https://github.com/keptenkurk/pyTTNmap/blob/master/documentation/Schematics.jpg . I need a few moments to clear my desk (Thanks for this great response btw )
                            dicktonyboy
                            No - this is where we came in. Note that I cant have Putty and the firmware updater program both running on Com7 simultaneously. Just running the updater produces the failure originally reported.
                              @dicktonyboy Sure. Putty is just for confirming for being in the update state. Then you must close putty and start the updater.
                                @robert-hh grand kids have arrived - must play grandpa for a moment -will get back to you with the results Thanks for all of your help.
                                  dicktonyboy
                                  This board will NOT flash. Even trying lower speeds it does not correctly switch modes. The blue heartbeat led stops as it should when the pin is grounded but nothing more.
                                    @dicktonyboy So did you see the message "waiting for download" in Putty, if you do the download preparation steps, or not?
                                      dicktonyboy @dicktonyboy
                                      @robert-hh No just the original message I posted - repeated several times and can you remove this annoying restriction that pops up each time I reply please
                                      Error
                                      As a new user, you can only post once every 600 second(s) until you have earned 3 reputation - please wait before posting again
                                        @dicktonyboy If you do not see the message, then something may be wrong with P2 aka GPIO0. The sequence of messages you see is also strange.
                                        Remark. I gave you 3 reputations. So the delay should be gone.
                                          @robert-hh Well this is very weird as to all intents and purposes everything else is functioning correctly. I am new to this - and this is my first LoPy project. I'm running TTN Cardiff and wanted to provide the locals with a signal strength mapping project. https://youtu.be/-H-W76OMkyY?t=16s I feel so much cleaner with my new-found reputation - thank you for that!
                                            @robert-hh I've no ideaa whether this is of an help but the response to:-
                                            C:\Users\dicktonyboy>ampy -p com7 ls
                                            flash
                                            and the response to:-
                                            C:\Users\dicktonyboy>ampy -p com7 ls /flash
                                            main.py
                                            sys
                                            lib
                                            cert
                                            boot.py
                                            Location History.json
                                            AdafruitIO.py
                                            filer
                                            umqtt.py
                                            project.pymakr
                                            lopylcd.mpy
                                            micropygps.mpy
                                            micropygps.py
                                            I can't delete the bottom three files or Location History.json (probably due to the space in the name)
