    LoPy4 Firmware upgrade impossible
    lopy4firmware upgradproblem
    23 Posts 3 Posters 5.1k Views 3 Watching
      robert-hh @dicktonyboy
      @dicktonyboy P2 to GND and then push reset. When you do that with Putty open, you should see something like:
      ets Jun  8 2016 00:22:57
      rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
      waiting for download
      I see somtimes the message about invalid packet header, if the update speed is too high. Then I have to use a lower speed, like 460800 baud or even less.
        dicktonyboy
        thats when i get
        rst:0x10 (RTCWDT_RTC_RESET),boot:0x2b (HSPI_FLASH_BOOT)
        flash read err, 1000
        ets_main.c 371
        ets_main.c 371
        ets_main.c 371
        ets_main.c 371
        ets_main.c 371
        rst:0x10 (RTCWDT_RTC_RESET),boot:0x3b (SPI_FAST_FLASH_BOOT)
        configsip: 0, SPIWP:0xee
        mode:DIO, clock div:2
        load:0x3fff9010,len:12
        ho 0 tail 12 room 4
        load:0x3fff9020,len:388
        load:0x40078000,len:11584
        load:0x4009fb00,len:848
        entry 0x4009fc9c
        MicroPython v1.8.6-798-gebbcca48-dirty on 2017-10-31; LoPy4 with ESP32
          @dicktonyboy Then the device is NOT in update state. You have to see the message "waiting for download". That turns up when P2 is connected to GND during Reset (push the reset button on the module or pull reset pin low for a short moment.
          Edit: Reset is not P0, but the one next to P0
            dicktonyboy @robert-hh
            Now I am confused. Is this sequence described fully anywhere so that I may follow it pls?
              @dicktonyboy to some extend it is here:
              https://docs.pycom.io/chapter/gettingstarted/installation/firmwaretool.html
              In step 4, it says: reconnect
              That is equivalent to being connected and pushing reset. My experience is, that reconnecting not always brings the device into proper dowload mode, put pushing reset does.
              Did it work now?
                @robert-hh Wow your support is faster than I'm allowed to rely (limit 600s). I'm not using a expansion board but this set up https://github.com/keptenkurk/pyTTNmap/blob/master/documentation/Schematics.jpg . I need a few moments to clear my desk (Thanks for this great response btw )
                  dicktonyboy
                  No - this is where we came in. Note that I cant have Putty and the firmware updater program both running on Com7 simultaneously. Just running the updater produces the failure originally reported.
                    @dicktonyboy Sure. Putty is just for confirming for being in the update state. Then you must close putty and start the updater.
                      @robert-hh grand kids have arrived - must play grandpa for a moment -will get back to you with the results Thanks for all of your help.
                        dicktonyboy
                        This board will NOT flash. Even trying lower speeds it does not correctly switch modes. The blue heartbeat led stops as it should when the pin is grounded but nothing more.
                          @dicktonyboy So did you see the message "waiting for download" in Putty, if you do the download preparation steps, or not?
                            dicktonyboy @dicktonyboy
                            @robert-hh No just the original message I posted - repeated several times and can you remove this annoying restriction that pops up each time I reply please
                            Error
                            As a new user, you can only post once every 600 second(s) until you have earned 3 reputation - please wait before posting again
                              @dicktonyboy If you do not see the message, then something may be wrong with P2 aka GPIO0. The sequence of messages you see is also strange.
                              Remark. I gave you 3 reputations. So the delay should be gone.
                                @robert-hh Well this is very weird as to all intents and purposes everything else is functioning correctly. I am new to this - and this is my first LoPy project. I'm running TTN Cardiff and wanted to provide the locals with a signal strength mapping project. https://youtu.be/-H-W76OMkyY?t=16s I feel so much cleaner with my new-found reputation - thank you for that!
                                  @robert-hh I've no ideaa whether this is of an help but the response to:-
                                  C:\Users\dicktonyboy>ampy -p com7 ls
                                  flash
                                  and the response to:-
                                  C:\Users\dicktonyboy>ampy -p com7 ls /flash
                                  main.py
                                  sys
                                  lib
                                  cert
                                  boot.py
                                  Location History.json
                                  AdafruitIO.py
                                  filer
                                  umqtt.py
                                  project.pymakr
                                  lopylcd.mpy
                                  micropygps.mpy
                                  micropygps.py
                                  I can't delete the bottom three files or Location History.json (probably due to the space in the name)
                                    @dicktonyboy If you have the REPL prompt, you can always reformat the internal file system with uos.mkfs().
                                    But updating requires the device to be in upload mode. Sorry if I'm asking the obvious again, but are you sure that you connected P2 to GND. That's the 4th Pin from the edge close to the reset button, next to TX. Strapping it low sometime causes the RGB LED to switch colors.
                                      @robert-hh double and triple checked - correct. :)
                                        @dicktonyboy You could check, whether P2 is connected at least to the RGB Led. It is one of the connections faced to the LoPy Shield, opposite to P2.
