LoPy Using machine.main(filename)
Default boot.py file looks like below:
from machine import UART import os uart = UART(0, 115200) os.dupterm(uart)Try:
import machine import os uart = machine.UART(0, 115200) os.dupterm(uart) machine.main(filename) -
tried this already in various syntax options,
os.dupterm(uart)
machine.main(test.py)
or
machine.main('test.py')
or
machine.main('./test.py')etc.
Even removed main.py from the file system
but no succes.The basic idea that want to implement is running various
version of software depending in grounding pins.
This is the first step i need to solve. -
You do not need to override it to acomplish task
use
execfile('your file.py')
in your boot.py -
just tested this and works like a charm.
@Rens said in LoPy Using machine.main(filename):
Still curious why this is not working, i assume when execfile('test.py')
would return still will go on with main.py.Thanks for all suggestions !
OK, as I promised I've tried my LoPy with boot.py as below:
import machine import os uart = machine.UART(0, 115200) os.dupterm(uart) machine.main('test.py')with test.py file:
print('Test')and everything is working as it should.
Thanks for trying, no idea were I did go wrong.
Will test and have another close look, as far is i can see
both setup's are identical.When do find the answer I will post it here.
Regards Rens
Well just tested again with machine.main('test.py') and now its
working as i would expect. Thanks again for the support.Rens
Super! I'm glad that you finally did it! :o)
