    Potential device lockdown - Network providers
    gpycat-m1fipytelstra
    42 Posts 12 Posters 11.1k Views 15 Watching
      micksta @timh
      @timh
      Hey timh & tealbrains, appreciate the contact & follow up with Telstra. I believe in the early day's Pycom had some chats with Telstra, hopefully they still have those contacts. I'm also on the tealbrains path & looking for a solid option for several projects. Thanks guy's - product had promise.
        Apologies for the lack of response. We have a new Cat-M1 firmware which should solve the issues with Telstra. This firmware will be available in a few hours on this link: https://software.pycom.io/downloads/sequans.html (FIPY_GPY_CATM1_36417.dup). In order to connect, the attach command should be as follows:
        AT!="RRC::addScanBand band=28"
        After that, then send (do not call lte.attach() explicitly):
        AT+CFUN=1
        Regards,
        T I 3 Replies Last reply Reply Quote 0
          timh @daniel
          @daniel Hi Daniel
          Thanks for the update.
          Can you provide the full connection details. As you can see the in the other threads we spent quite a bit of time trial and error working out how to connect to Telstra.
          For instance we have all been sending
          AT!="RRC::addscanfreq band=28 dl-earfcn=9410"
          Is that relevant now ?
          Some clear repeatable instructions would be really good.
          Tim
            timh @daniel
            @daniel oh and the firmware isn't available yet (a few hours have passed ;-)
            • X Offline
              Xykon administrators @timh
              @timh said in Potential device lockdown - Network providers:
              The file is now only available.
              Christian Ehlers
                timh @Xykon
                @xykon Awesome. Thanks
                  micksta @timh
                  @timh
                  Telstra still no go (for me anyway'z), seems to find tower but then issues out - tried several location around town.. Some notes below.
                  Modem f/w --> FIPY_GPY_CATM1_36417.dup
                  (sysname='GPy', nodename='GPy', release='1.17.5.b6', version='v1.8.6-849-56d00234 on 2018-05-18', machine='GPy with ESP32')
                  I'm not calling lte.attach(), use 'AT+CFUN=1' for that --> snippet of below below was definitely working before changes to telstra network
                  'AT!="addscanfreq band=28 dl-earfcn=9410"' # lte frequency band - from forum
                  AT+CGDCONT=1,"IP","mdata.net.au"' # Aldi sim / Aldi APN (aka Telstra network)
                  FSM (loops through the below)
                  SCANNING
                  SYNCING
                  STOPPED
                  -------- e.g. --------------------------------
                  SYSTEM FSM
                  | RRC TOP FSM              |SYNCING             |
                  | RRC SEARCH FSM           |WAIT_SYNC           |
                  | RRC ACTIVE FSM           |NULL                |
                  | PMM PLMN FSM             |NORM_WAITCELL       |
                  | EMM AUTH FSM             |KASME_DEFINED       |
                  DL SYNCHRO STATISTICS (loops through some of the below but random)
                  CELL_SEARCH
                  FAST SCAN
                  FRAME_UPDATE
                  MIB_DETECT
                  IDLE
                  RSRP
                  Synchro state                         : CELL_SEARCH
                  PPU SIB1 ACQ watchdog                 : 0
                  Frequency Hypothesis RF  (Hz)         : 0
                  RSRP (dBm)                            : -21474836.00
                  RSRQ  (dB)                            : 0.00
                  Channel estimation state (Cell-spec.) : LOW CINR
                  Channel estimation state (UE-spec.)   : LOW CINR
                  Channel estimation state (MBSFN)      : LOW CINR
                  Channel estimation CINR               : 5.62
                  Channel length                        : SHORT
                  AGC
                  AGC RX gain (dB)                      : 60.22
                  RX PSD BO (dBFs)                      : -23.42
                  RX PSD (dBm)                          : -111.79
                  Noise level RS (dBm)                  : -128.24
                  Digital gain (dB)                     : 4.78
                  CINR RS (dB)                          : 0.00
                  NARROWBANDS
                  Last DL NB                            : Central
                  Last UL NB                            : 0
                  AFC
                  Frequency offset RF  (Hz)             : -379
                  Frequency offset BB  (Hz)             : 0
                  PBCH
                  MIB received quantity                 : 21
                  MIB timeout quantity                  : 0
                  WITH CREG SHOWING
                  +CREG: 2,0
                    timh @micksta
                    @micksta bugger ;-( I haven't had a chance to test myself yet. Up to my eyeballs. Hoping later this afternoon.
                    Some my guidance on specifics from @daniel or @xykon would help a lot.
                      tealbrains
                      Not only it is not working for me but it is even worse now (I did not think it could get any worse but it did.)
                      I am not able to get a CCID from the (M2Mone) SIM card when issuing:
                      send_at_cmd_pretty('AT+SQNCCID')
                      I thought it would maybe be an issue with the SIM card itself so used a GPY that still had the previous modem firmware (FIPY_GPY_CATM1_33988.dup) with the same SIM card and it worked.
                      So, summarising:
                      • GPy on stable 1.18.0 with FIPY_GPY_CATM1_33988 -> Lost Telstra connectivity a few weeks ago but it can talk to the SIM card.
                      • GPy on stable 1.18.0 with FIPY_GPY_CATM1_36417 -> Can't talk to SIM card, which I believe is what is producing an ERROR response when issuing
                      send_at_cmd_pretty('AT!="RRC::addScanBand band=28"')
                      It would seem we are taking one step forward and two steps backward...
                      If @micksta, @timh and @Prawnhead can confirm this behaviour the problem is still there.
                      P T 2 Replies Last reply Reply Quote 0
                        tealbrains
                        @tealbrains said in Potential device lockdown - Network providers:
                        So, summarising:
                        If @micksta and @Prawnhead can confirm this behaviour the problem is still there.
                        EDIT:
                        The SIM command does work, eventually. I think the new pycom firmware blocks some commands sometimes if the modem is busy.
                        @daniel
                        A bit of extra info would be nice. The way the first command you mentioned needs to be sent is slightly different.
                         send_at_cmd_pretty("AT!=\"RRC::addScanBand band=28\"")
                        It must include the escape characters, otherwise it seems to produce an ERROR. The modem won't attach though.
                          micksta @tealbrains
                          @tealbrains
                          Here works no probs, have 2 GPY's - different revs of modem f/w.
                          Using (Aldi Sim aka Telstra & below GPy f/w)
                          send_at_cmd_pretty('AT+SQNCCID?') # reads the ICCID ID on the SIM card.
                          I'm also using (as @Daniel suggested below AT!)
                           - System FSM & Synchro Stats still loops with no connection (although it does seem to see the tower) . CREG still stuck  --> +CREG: 2,0
                            tealbrains @micksta
                            @micksta I am guessing the AT+SQNCCID is what works without problems, right? It's a different story for the Cat-M1 connection. If you can't connect either I guess the issue is not resolved then...
                              micksta @tealbrains
                              @tealbrains
                              Sure CCID no prob's --> same no Connection. Had a look at some alt. LTE M1 products (googled "Certified Modules and Devices - Telstra") & ordered several SIM7000E. Will be interesting to compare.. Hopefully the Pyboards make the list soon.
                                Prawnhead @tealbrains
                                So, summarising:
                                I'm using this as minimum viable code:
                                from network import LTE
                                def at_cmd(command):
                                    print("Command:  {}".format(command))
                                    result = lte.send_at_cmd(command)
                                    print("Response: {}".format(result))
                                print(os.uname())
                                lte = LTE()
                                at_cmd('AT+CGDCONT=1,"IP","telstra.internet"')
                                at_cmd('AT!="addscanfreq band=28 dl-earfcn=9410"')
                                at_cmd('AT+CFUN=1')
                                for x in range(20):
                                    print("Attached? {}".format(lte.isattached()))
                                    time.sleep(1)
                                machine.reset()
                                Result is always:
                                >>> Running Z:\Content\Content2\Chris\Pycom\Pycom GPy\Pycom Forum 2878\connect0.py
                                (sysname='GPy', nodename='GPy', release='1.18.0', version='v1.8.6-849-046b350 on 2018-06-01', machine='GPy with ESP32')
                                Command:  AT+CGDCONT=1,"IP","telstra.internet"
                                Response:
                                OK
                                Command:  AT!="RRC::addScanBand band=28"
                                Response:
                                OK
                                Command:  AT+CFUN=1
                                Response:
                                OK
                                Attached? False
                                Attached? False
                                Attached? False
                                Attached? False
                                Attached? False
                                Attached? False
                                Attached? False
                                Attached? False
                                Attached? False
                                Attached? False
                                Attached? False
                                Attached? False
                                Attached? False
                                Attached? False
                                Attached? False
                                Attached? False
                                Attached? False
                                Attached? False
                                Attached? False
                                Attached? False
                                ets Jun  8 2016 00:22:57
                                rst:0x7 (TG0WDT_SYS_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
                                configsip: 0, SPIWP:0xee
                                mode:DIO, clock div:1
                                load:0x3fff8028,len:8
                                load:0x3fff8030,len:1728
                                load:0x4009fa00,len:0
                                load:0x4009fa00,len:14584
                                entry 0x400a059c
                                Pycom MicroPython 1.18.0 [v1.8.6-849-046b350] on 2018-06-01; GPy with ESP32
                                I have tried 1 x FiPy and 1 x GPy on firmware FIPY_GPY_CATM1_33988.dup and FIPY_GPY_CATM1_36417.dup and have not had a successful lte.isattached() in 20+ attempts. However, I'm not completely confident I've got the minimum viable code right. If someone using Optus or Vodafone could post their minimum code or confirm mine (with whatever settings changes are required) I'd appreciate it!
                                • Chris
                                  Dylan
                                  Hey everybody,
                                  I have been using a FiPy and having the same trouble that appears to be happening to most people (maybe everybody) in Australia.
                                  I was in the middle of writing something up for a new topic on FiPy but since this is basically it I'll put it here.
                                  Currently the following occurs:
                                  • LTE connects successfully many times in a row, but can then go for hours without a connection (With 60 second sleep cycles). Just like discussed here:
                                    https://forum.pycom.io/topic/2878/fipy-lte-connection-working-with-telstra/18
                                    and
                                    https://forum.pycom.io/topic/2769/telstra-lte-cat-m-working-on-fipy-just/24
                                  • When doing longer sleeps between messages (15minutes) I very rarely get a connection
                                  • Today I have simply not been able to get a connection at all.
                                  • Sometimes when I do connect, it will say message sent however it is never received by adafruit
                                  • Last successful connection was last night around 9pm.
                                  I just installed the new sequans firmware and having the same result.
                                  I am using SIM cards that are given out by telstra for m2m.
                                  My code:
                                  from pytrack import Pytrack
                                  from MQTT import MQTTClient
                                  from L76GNSS import L76GNSS
                                  def sub_cb(topic, msg):
                                      print(msg)
                                  lte = LTE()
                                  # lte.reset()
                                  print("Line 15") #lots of prints for debugging
                                  time.sleep(1)
                                  lte.send_at_cmd('AT^RESET') #trying this to see if it helps on restart
                                  print(lte.send_at_cmd('AT^RESET'))
                                  print("Line 16")
                                  time.sleep(1)
                                  lte.send_at_cmd('AT+CFUN=0')
                                  print("Line 17")
                                  time.sleep(1)
                                  print(lte.send_at_cmd('AT!="clearscanconfig"'))
                                  print("Line 18")
                                  time.sleep(1)
                                  lte.send_at_cmd('AT+CGDCONT=1,"IP","telstra.m2m"')
                                  print(lte.send_at_cmd('AT+CGDCONT=1,"IP","telstra.m2m"'))
                                  print("Line 19")
                                  time.sleep(1)
                                  lte.send_at_cmd("AT!=\"RRC::addscanfreq band=28 dl-earfcn=9410\"")
                                  print(lte.send_at_cmd("AT!=\"RRC::addscanfreq band=28 dl-earfcn=9410\""))
                                  print("Line 20")
                                  time.sleep(1)
                                  lte.send_at_cmd('AT+CFUN=1')
                                  print(lte.send_at_cmd('AT+CFUN=1'))
                                  print("Line 21")
                                  time.sleep(1)
                                  print("Line 22")
                                  time.sleep(1)
                                  while not lte.isattached():
                                      print("Attaching...")
                                      time.sleep(0.1)
                                  print("Attached")
                                  lte.connect()
                                  while not lte.isconnected():
                                      print("Connecting...")
                                      time.sleep(0.1)
                                  print("Connected!")
                                  time.sleep(2)
                                  def settimeout(duration):
                                     pass
                                  print("line41")
                                     print(msg)
                                  print("line44")
                                  client = MQTTClient("Demo","io.adafruit.com",user="Dylan", password="xxxx", port=1883)
                                  print("Line 38")
                                  client.set_callback(sub_cb)
                                  print("Line 41")
                                  client.connect()
                                  print("Line 43")
                                  time.sleep(1)
                                  client.subscribe(topic="Dylan/feeds/test")
                                  print("Line 46")
                                  py = Pytrack()
                                  battery = py.read_battery_voltage()
                                  l77 = L76GNSS(py, timeout=30)
                                  coord = l77.coordinates()
                                  coord = str(coord) + str(',') + str(battery)
                                  print("Sending ON")
                                  client.publish(topic="Dylan/feeds/test", msg=coord)
                                  print("Line 51")
                                  time.sleep(1)
                                  print("Line 55")
                                  client.check_msg()
                                  py.setup_sleep(60)
                                  py.go_to_sleep()
                                    Prawnhead
                                    Anyone who's got working LTE with Optus or Vodafone wanna share your setup? Just looking for APN/channel configuration that would make testing other carriers quicker. Thanks, Chris.
                                      timh @Prawnhead
                                      @prawnhead I haven't been able to spend time on this (heavy workload on non rpycom related projects).
                                      It does seem worrisome that no one seems to have it working.
                                        timh @tealbrains
                                        @tealbrains So I finally found time to test the SEQUANS firmware.
                                        I performed the firmware upgrade as per the instructions.
                                        The upgrade performed as per instructions on a FiPy
                                        And the result, working fine. - Success for me at least.
                                        (sysname='FiPy', nodename='FiPy', release='1.17.3.b1', version='v1.8.6-849-83e2f7f on 2018-03-19', machine='FiPy with ESP32', lorawan='1.0.2', sigfox='1.0.1')
                                            lte.send_at_cmd('AT+CGDCONT=2,"IP","telstra.internet"')
                                            lte.send_at_cmd('AT!="RRC::addScanBand band=28"')
                                            for i in range(retries):
                                                if wdt:
                                                    wdt.feed()
                                                if (lte.isattached()):
                                                      print("attached")
                                                      lte.connect()
                                                      break
                                                time.sleep(1)
                                        I will keep this running over the weekend, but looks good for me on at least one device.
                                        The other devices are on the other side of the country in mechanical pumps so need to organise people to get me access to perform the upgrade ;-(
                                        M T 2 Replies Last reply Reply Quote 0
                                          micksta @timh
                                          @timh
                                          Hey lads, changed nothing here. Just thought I'd try and connect - Success here as well.
                                          send_at_cmd_pretty('AT+CGDCONT=1,"IP","mdata.net.au"') # Aldi sim / "mdata.net.au" Aldi APN (aka Telstra network)
                                          time.sleep(1)
                                          send_at_cmd_pretty("AT!=\"RRC::addscanfreq band=28 dl-earfcn=9410\"")
                                          time.sleep(1)
                                          send_at_cmd_pretty('AT+CFUN=1') # enable modem & set to full functionality mode
                                          time.sleep(1)
                                          B T 2 Replies Last reply Reply Quote 0
                                            blindman2k @micksta
                                            Same here. Everything was working one day, nothing working the next day, everything working again today.
                                            • 2 / 3
