Pycom Firmware Software does not support Pybytes Registration
During the Firmware upgrading process, we are suppose to input the Pybytes activation token. However I realise that it doesn't work due to the need for Sigfox credentials. Possible to fix this bug? Not everyone uses Sigfox.
Thank you.
Shannon Goh
@reidfo Im as confused as you are.. Think the spam bots are leaking.
@sophiasoph That does not even make sense.
@sh4nnongoh Thank you I was able to reproduce the issue now, and we fixed it now!
Thank you for testing Pybytes. If you found any other problems, please let us know.
@jirkakrepl Hi.
I am using "pycom_firmware_update_1.15.1.exe", with a FiPy board on a PyTrack board.
To reproduce:
- Head to pybytes portal and add new device.
- During the networking selection, do not select Sigfox. I selected WIFI, LTE-M1, LTE-NB, LORA-OTAA.
- Generate the token.
- Plug FiPy to PC and run firmware update, selecting the type as "pybytes"
- Upon entering the token at the pybytes registration window, wait a while and the window will refresh with the screenshot above.
we would like to help. I wasn't able to reproduce this issue.Can you describe steps which led to your problem please?
What version of firmware updater are you using? What type of device and which networks have you added to Pybytes?
Thank you
