    Lopy4 deep sleep problem
    lopy4loradeepsleep
    23 Posts 7 Posters 4.9k Views 6 Watching
      pierremarsot @iwahdan
      @iwahdan Thanks for your reply.
      I using the last stable firmware (checked this morning).
      What do you mean about "external circuit" ?
      I power the Lopy4 with an power supply which is power with two options : USB or 5V. So yes, with my point of view, it's an external circuit.
      But i have the same problem when I power the Lopy directly with the board 3.0
      • tobzT Offline
        tobz
        Is Bluetooth turned on by default? Does it need to be desalinized/turned off to save power?
          pierremarsot @tobz
          @tobz I call Bluetooth deinit function in boot.py
          So Bluetooth should be turned off ...
          tobzT 1 Reply Last reply Reply Quote 0
          • tobzT Offline
            tobz @pierremarsot
            @pierremarsot Yeah I saw that, I just assume d it was already off... is that not the case?
              pierremarsot @tobz
              @tobz No. It's not disable by default. You need to called deinit function
              • tobzT Offline
                tobz @pierremarsot
                @pierremarsot Very good to know, thanks for confirming :)
                  pierremarsot
                  So, do you have any idea why the LoPy4 consume 80mA in sleep mode ?
                    MarcoBenini @pierremarsot
                    @pierremarsot said in Lopy4 deep sleep problem:
                    000
                    Try to close the socket ( s.close ) after your "s.setblocking(False)" and check if the radio module goes to sleep.
                    • I Offline
                      iwahdan
                      Hi @pierremarsot , Actually there is no need to disable bt/wifi or Heartbeat before deepsleep, they are disabled automatically when calling machine.deepsleep also the LoRa modem is turned off in deepsleep.
                      I've actually ran you code on a LoPy4 and I get an Avg current consumption in deepsleep = 27uA.
                      Wahdan
                      P 2 Replies Last reply Reply Quote 0
                        @iwahdan Strange ...
                        I'll check again the consumption tonight but i was pretty sure
                          @iwahdan Sorry but i have an consumption higher (see picture)
                          Maybe i didn't do the right thing ...
                          • I Offline
                            iwahdan @pierremarsot
                            Hi @pierremarsot, I cannot totally get from the picture how you setup the circuit , if you could share the circuit diagram along with pin connections I could try to test with your setup.
                            Wahdan
                              Can you see clearly on this picture ?
                              Basic circuit. Powered by a power supply (12Vdc / 3A) on 3.3V PIN
                              I tried on 5V PIN, i got a consumption around 65mA
                              I S 2 Replies Last reply Reply Quote 0
                              • I Offline
                                @pierremarsot , This is NOT how you power on any of pycom Devices.
                                Maximum voltage you can use is 5.5v and you Connect to Vin not 3.3v pin! , the 3.3v pin is actually used for supplying 3.3v output.
                                please use this pinout diagram as a guideline
                                Wahdan
                                  @iwahdan
                                  Ok, thanks for this issue, sorry ...
                                  I just tried with an 5.5V power supply (checked with multimeter) and i got a consumption around 63mA in deep sleep.
                                  Same circuit, just changed power supply input and connected with 5.5v PIN.
                                  • I Offline
                                    @pierremarsot, well it might very well be that your Lopy was damaged in some way or something got shortened , do you have another device that you can try?
                                    Wahdan
                                      Sympatron @pierremarsot
                                      What do you mean by that? Did you connect 12V to the 3.3V Pin? This would certainly damage the device...
                                        pierremarsot @Sympatron
                                        Hi @sympatron
                                        Yes, I connected the 12V to the 3.3V and 5V PINs ...
                                        I thought my power supply transformed the 12V input in 5V output but after some tests, it didn't ...
                                        I used this one : https://www.amazon.fr/SODIAL-Planche-Compatible-puissance-bricolage/dp/B015NUN4QI/ref=asc_df_B015NUN4QI/?tag=googshopfr-21&linkCode=df0&hvadid=106796343001&hvpos=1o3&hvnetw=g&hvrand=2025127917332645665&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9055144&hvtargid=pla-208287294001&psc=1
                                          robert-hh @pierremarsot
                                          @pierremarsot that module should step down 12V to 5V or 3.3V. If your LoPy4 still works, then you probably used it fine. Only the 3.3V pin of the xxPy devies is an Input. Always power them throuh Vin.
                                            jcaron @robert-hh
                                            @robert-hh I think you mean the 3.3V pin is an output, and one should never power the board through it?
