Lopy4 deep sleep problem
@pierremarsot said in Lopy4 deep sleep problem:
000
Try to close the socket ( s.close ) after your "s.setblocking(False)" and check if the radio module goes to sleep.
Hi @pierremarsot , Actually there is no need to disable bt/wifi or Heartbeat before deepsleep, they are disabled automatically when calling
machine.deepsleepalso the LoRa modem is turned off in deepsleep.I've actually ran you code on a LoPy4 and I get an Avg current consumption in deepsleep = 27uA.
@iwahdan Strange ...
I'll check again the consumption tonight but i was pretty sure -
@iwahdan Sorry but i have an consumption higher (see picture)
Maybe i didn't do the right thing ...
Hi @pierremarsot, I cannot totally get from the picture how you setup the circuit , if you could share the circuit diagram along with pin connections I could try to test with your setup.
Tanks @iwahdan
Can you see clearly on this picture ?Basic circuit. Powered by a power supply (12Vdc / 3A) on 3.3V PIN
I tried on 5V PIN, i got a consumption around 65mA -
@pierremarsot , This is NOT how you power on any of pycom Devices.
Maximum voltage you can use is 5.5v and you Connect to Vin not 3.3v pin! , the 3.3v pin is actually used for supplying 3.3v output.
please use this pinout diagram as a guideline
@iwahdan
Ok, thanks for this issue, sorry ...I just tried with an 5.5V power supply (checked with multimeter) and i got a consumption around 63mA in deep sleep.
Same circuit, just changed power supply input and connected with 5.5v PIN. -
@pierremarsot, well it might very well be that your Lopy was damaged in some way or something got shortened , do you have another device that you can try?
What do you mean by that? Did you connect 12V to the 3.3V Pin? This would certainly damage the device...
Hi @sympatron
Yes, I connected the 12V to the 3.3V and 5V PINs ...
I thought my power supply transformed the 12V input in 5V output but after some tests, it didn't ... -
@pierremarsot that module should step down 12V to 5V or 3.3V. If your LoPy4 still works, then you probably used it fine. Only the 3.3V pin of the xxPy devies is an Input. Always power them throuh Vin.
@robert-hh I think you mean the 3.3V pin is an output, and one should never power the board through it?
@jcaron Of course!
