Wipy 3 irregularly crashes after deepsleep
  • Hi,
    I have been evaluating the deepsleep capabilities of my Wipy 3 quite intensively during the last days. I noticed that it always crashes after a random amount of deepsleep cycles upon which a hard reset is required.
    When it crashed, it has not connected to my WIFI (as specified in boot.py) and also did not setup its own WIFI, so I cannot access the REPL. However, it consumes power as it is warm. I am not sure whether the board crashes while going to deepsleep or while waking up from it.
    Am I doing something wrong or is this a firmware/hardware issue? Find below a boot.py and main.py that I can use to reproduce the problem, it usually occurs during the first hour.
    # boot.py -- run on boot-up
    def connectToWlan():
        from network import WLAN
        wlan = WLAN(mode=WLAN.STA)
        nets = wlan.scan()
        for net in nets:
            if net.ssid == '<SSID>':
                print('Network found!')
                wlan.connect(net.ssid, auth=(net.sec, '<AUTH>'), timeout=5000)
                while not wlan.isconnected():
                    pycom.rgbled(0x7f0000) # red
                wlan.ifconfig(config=('192.168.0.14', '255.255.255.0', '192.168.0.1', '192.168.0.1'))
                print(wlan.ifconfig())
                break
    # Code to be run on boot-up
    pycom.heartbeat(False)
    connectToWlan()
    time.sleep(1) # wait shortly
    # main.py -- runs after boot.py
    # Constants
    DEEPSLEEP_TIME = 2 # seconds
    print("Going to deepsleep in 10 seconds")
    for i in range(10):
        pycom.rgbled(0) # off
        time.sleep(0.5)
        pycom.rgbled(0xffa500) # orange
        time.sleep(0.5)
    print("Going to deepsleep")
    time.sleep(1) # better wait a little
    machine.deepsleep(DEEPSLEEP_TIME * 1000)  # must be milliseconds
    Personally, I think the Wipy crashes after the wake up and before boot.py is run, but I am not sure how to proof that without staring at the Wipy for an hour.
  • As of last week, I cannot reproduce the error anymore... . If I encounter the issue again, I will write here again.
  • @moewex I have been having the same issue. My deep sleep time is 60 minutes. The WiPy will function fine for 1 - 2 weeks, then it hits this stall out mode where it does not connect to wifi and heats up. Not sure where the issue is on this one.
