    wipy2.0i2cpycompythonsaving data
    100 Posts 2 Posters 25.6k Views 2 Watching
      robert-hh @VFlorio94
      @vflorio94 The error message shown below:
      MemoryError: memory allocation failed, allocating 1954 bytes
      tells, that your code wants to allocat a chunk of memory. What line is causing that? Doese teh code create a buffer, or doesn it try to write to a file?
      Just the explanation of the code does not help, we need the source to help you, since it's about the little details.
      • V Offline
        VFlorio94 @robert-hh
        @robert-hh the line isn't indicate.
        I show you the code if you can help me i'll be greatful
        from machine import Timer
        import lib_imu
        from machine import I2C
        from math import sqrt
        from machine import PWM
        import gc
        def media(sequenza):
            # calculate mean
            return sum(sequenza[1:len(sequenza)]) / (len(sequenza)-1)
        def varianza(sequenza):
            # calculate variance
            mean = media(sequenza)
            return sum([(x-mean)**2 for x in sequenza])/len(sequenza)
        def dev_std(sequenza):
            # Calculate standard deviation
            return sqrt(varianza(sequenza))
        def calcolo_position(secondi):
        # function to calculate the position each second, the number of second is assigned
            gc.collect()
            # Configure I2C to extract euler angle
            lib_imu.set_configmode()
            time.sleep(0.03)
            # set unit
            lib_imu.set_units()
            time.sleep(0.03)
            # set mode
            lib_imu.set_mode('ndof')
            # create 3 lists
            lista_heading = []
            lista_roll = []
            lista_pitch = []
            t = Timer.Chrono()
            t.start()
            time.sleep(0.1)
            while 1:
                t_now = t.read()
                if  t_now <= secondi:
                    eul = lib_imu.get_euler()
                    lista_heading.extend([eul[0]])
                    lista_roll.extend([eul[1]])
                    lista_pitch.extend([eul[2]])
                    time.sleep(0.5)
                    if ( ((secondi - 0.5) < t_now < secondi)  & (len(lista_heading) == len(lista_roll)) & (len(lista_roll) == len(lista_pitch))):
                    # Calculate mean and standard deviation
                        print(lista_heading)
                        print(lista_roll)
                        print(lista_pitch)
                        l = len(lista_pitch)
                        print("Calcolo media")
                        for i in range (0,l):
                            mean_pitch = media(lista_pitch)
                            mean_roll = media(lista_pitch)
                            mean_heading = media(lista_heading)
                        mean_pos = (mean_heading,mean_roll,mean_pitch)
                        # Calcolo deviazione standard
                        dev_std_heading = dev_std(lista_heading)
                        dev_std_roll = dev_std(lista_roll)
                        dev_std_pitch = dev_std(lista_pitch)
                        devstd_pos =(dev_std_heading, dev_std_roll, dev_std_pitch)
                        return mean_pos, devstd_pos
                    t.stop()
                    gc.collect()
                    del lista_heading[0:l]
                    del lista_pitch[0:l]
                    del lista_roll[0:l]
                    print("Acquisizione terminata")
                    break
        def acquisizione_interval_pitch(delta_t,sec, mean_pos_ok,mean_pos_no, dev_std_no ):
            lib_imu.set_units()
            pwm = PWM(1, frequency=2000) # timer indica il tempo di oscillazione alla specifica frequenza
            pwm_c5 = pwm.channel(5, pin='P12') #dietro
            pwm_c4 = pwm.channel(4, pin='P7')  # dx
            pwm_c3 = pwm.channel(3, pin='P6')
            pwm_c2 = pwm.channel(2, pin='P5')   # avanti
            pwm_c1 = pwm.channel(1, pin='P3')   # sx
            pwm_c5.duty_cycle(0)
            time.sleep(0.01)
            pwm_c4.duty_cycle(0)
            time.sleep(0.01)
            pwm_c3.duty_cycle(0)
            time.sleep(0.01)
            pwm_c2.duty_cycle(0)
            time.sleep(0.01)
            pwm_c1.duty_cycle(0)
            time.sleep(0.01)
            # DAC
            dacRight = machine.DAC('P21') #right
            dacLeft = machine.DAC('P22') #left
            dacRight.deinit()
            dacLeft.deinit()
            # Intervallo di inclinazione
            if mean_pos_no[2] < mean_pos_ok[2]:
                position_intervalPitch = (mean_pos_ok[2] - mean_pos_no[2] - (dev_std_no[2])/2 )
            elif  mean_pos_no[2] > mean_pos_ok[2]:
                position_intervalPitch = (mean_pos_no[2] - mean_pos_ok[2] - (dev_std_no[2])/2 )
            print("intervallo totale", position_intervalPitch)
            delta_i = position_intervalPitch / 4 #imposto un valore fisso per la suddivisione dell'intervallo
            # CRONOMETRO
            chrono_i = Timer.Chrono()
            chrono_i.start()
            time.sleep(0.01)
            position_sec = []
            while 1:
                chrono_i_now = chrono_i.read()
                x = 500
                y = 3
                if chrono_i_now <= delta_t:
                    gc.collect()
                    position_sec = calcolo_position(sec)
                    media_pos_sec= position_sec[0]
                    dev_std_pos_sec = position_sec[1]
                    # Calcolo per il pitch : movimento avanti-indietro
                    # Calcolo posizioni di partenza, tenendo conto della std:
                    # - maggiore di 90° indietro
                    # - minore di 90° avanti
                    start_p_av = (mean_pos_ok[2] - (dev_std_no[2])/2 )
                    start_p_ind = (mean_pos_ok[2] + (dev_std_no[2])/2 )
                    print("start avanti",start_p_av )
                    print("start ind",start_p_ind)
                    # Movimento AVANTI: pwm C2 = P5
                    if media_pos_sec[2] <= mean_pos_ok[2]:
                        if start_p_av <= media_pos_sec[2] < (start_p_av - delta_i):
                            # for x in seq:
                            #     pwm_c2.duty_cycle(x)
                            pwm_c2.duty_cycle(0.3)
                            time.sleep(0.01)
                            dacLeft.deinit()
                            dacRight.init()
                            dacRight.tone(x,y)
                            time.sleep(0.01)
                        elif (start_p_av - delta_i) <= media_pos_sec[2] < (start_p_av - (2)*delta_i):
                            pwm_c2.duty_cycle(0.5)
                            time.sleep(0.05)
                            dacLeft.deinit()
                            dacRight.init()
                            x= x + 1000
                            y = y - 1
                            dacRight.tone(x,y)
                            time.sleep(0.01)
                        elif (start_p_av - 2*delta_i) <= media_pos_sec[2] < (start_p_av - (3)*delta_i):
                            pwm_c2.duty_cycle(0.7)
                            time.sleep(0.01)
                            dacLeft.deinit()
                            dacRight.init()
                            x= x + 2000
                            y = y - 1
                            dacRight.tone(x,y)
                            time.sleep(0.01)
                        elif (start_p_av - 3*delta_i) <= media_pos_sec[2] < (start_p_av - (4)*delta_i):
                            pwm_c2.duty_cycle(0.8)
                            time.sleep(0.01)
                            dacLeft.deinit()
                            dacRight.init()
                            x= x + 3000
                            y = y - 1
                            dacRight.tone(x,y)
                            time.sleep(0.01)
                        elif media_pos_sec[2] <= (start_p_av - 4*delta_i)  :
                            pwm_c5.duty_cycle(0.5)
                            pwm_c4.duty_cycle(0.5)
                            pwm_c1.duty_cycle(0.5)
                            time.sleep(0.01)
                            dacLeft.deinit()
                            dacRight.init()
                            x= x + 4000
                            y = y - 1
                            dacRight.tone(x,y)
                            time.sleep(0.01)
                    # Movimento INDIETRO: pwm C5 = P12
                    elif media_pos_sec[2] > mean_pos_ok[2]:
                        if start_p_ind <= media_pos_sec[2] < (start_p_ind + delta_i):
                            # for x in seq:
                            pwm_c5.duty_cycle(0.3)
                            time.sleep(0.01)
                            dacLeft.deinit()
                            dacRight.init()
                            dacRight.tone(x,y)
                            time.sleep(0.01)
                        elif (start_p_ind + delta_i) <= media_pos_sec[2] < (start_p_ind + (2)*delta_i):
                            time.sleep(0.05)
                            dacLeft.deinit()
                            dacRight.init()
                            x= x + 1000
                            y = y - 1
                            dacRight.tone(x,y)
                            time.sleep(0.01)
                        elif (start_p_ind + 2*delta_i) <= media_pos_sec[2] < (start_p_ind + (3)*delta_i):
                            pwm_c5.duty_cycle(0.7)
                            time.sleep(0.01)
                            dacLeft.deinit()
                            dacRight.init()
                            x= x + 2000
                            y = y - 1
                            dacRight.tone(x,y)
                            time.sleep(0.01)
                        elif (start_p_ind + 3*delta_i) <= media_pos_sec[2] < (start_p_ind + (4)*delta_i):
                            pwm_c5.duty_cycle(0.8)
                            time.sleep(0.01)
                            dacLeft.deinit()
                            dacRight.init()
                            x= x + 3000
                            y = y - 1
                            dacRight.tone(x,y)
                            time.sleep(0.01)
                        elif media_pos_sec[2] >= (start_p_ind + 4*delta_i)  :
                            time.sleep(0.01)
                            dacLeft.deinit()
                            dacRight.init()
                            x= x + 4000
                            y = y - 1
                            dacRight.tone(x,y)
                            time.sleep(0.01)
                        time.sleep(0.01)
                        dacRight.deinit()
                        dacLeft.init()
                        x= x + 1000
                        y = y - 1
                        dacLeft.tone(x,y)
                        time.sleep(0.01)
                    chrono_i.stop()
                    print("fine prova")
                    dacRight.deinit()
                    dacLeft.deinit()
                    break
        # the instruction like the main, in which I use the function
        print("START ACQUISITION")
        print("Rilevazione posizione corretta")
        time.sleep(1)
        position_ok = []
        position_ok = calcolo_position(6)
        mean_pos_ok = position_ok[0]
        print("media posizione corretta", mean_pos_ok[2])
        dev_std_ok = position_ok[1]
        gc.collect()
        print("END FIRST ACQUISITION")
        time.sleep(2)
        print("SECOND AQUISITION ")
        time.sleep(1)
        position_no =[]
        position_no = calcolo_position(6)
        mean_pos_no = position_no[0]
        dev_std_no = position_no[1]
        gc.collect()
        print("END SECOND AQUISITION")
        time.sleep(1)
        print("START test pitch")
        time.sleep(1)
        acquisizione_interval_pitch(20, 1,  mean_pos_ok, mean_pos_no, dev_std_no )
          @vflorio94 Which line is causing the error?
          • V Offline
            @robert-hh I think that the error can be caused by the function "Calcolo_position', because I call it more and more time when the code run
            thank you
              @vflorio94 When the error pops ups, there is usually a line number shown. Which line number is it?
              • V Offline
                @robert-hh there isn't any line number.
                only this message
                ╝MemoryError: memory allocation failed, allocating 2029 bytes
                MicroPython v1.8.6-849-56d00234 on 2018-05-18; WiPy with ESP32
                Type "help()" for more information.```
                  @vflorio94 A few questions:
                  So you call calcolo_position() and it never returns, but gives that error?
                  The intention of calcolo_position(sec) is to collect data for the time sec, about 2 values per second, and return the average values?
                  Is the exact time the acquisition runs important?
                  Edit:
                  what is returned by lib_imu.get_euler()?
                  • V Offline
                    The intention of calcolo_position(sec) is which you have write. The function collect 2 values each second, calculate mean and re-use this value in the next function "acquisizione_interval_pitch", to generate the output.
                    I need to mantain this time of acquisition because i work on subject and I want to extract data about their trunk posture in real time. I want to give them some feedback in real time.
                    lib_imu is a simple library create to extract by I2c BNO055.
                    lib_imu.get_euler return the Euler Angle of pitch, roll and yaw.
                      @vflorio94 said in Wipy 2.0 and save data on my pc, not in flash memory:
                      I am asking about the data type: Does it return a tuple with three float values?
                      • V Offline
                        @robert-hh Sorry, I didn't understand your question before.
                        it returns TUPLE
                        thank you for your help and your patience
                          @vflorio94 In the first step, i changed two functions, media and calcolo_position. I simplified calcolo_position and reordered some lines. The major problem as I guess was a termination problem. It simply never hit the 0.5 second window for termination. It still is not perfect in matters of memory allocation, because it would better preallocate the "lists" as arrays. But that is a bigger change.
                          I changed media(), because the way it is it would implicitely allocate a list. The way it is now it's a little bit slower.
                              gc.collect()
                              time.sleep(0.03)
                              # set unit
                              lib_imu.set_units()
                              time.sleep(0.03)
                              # set mode
                              # create 3 lists
                              lista_heading = []
                              lista_roll = []
                              lista_pitch = []
                              t = Timer.Chrono()
                              t.start()
                              time.sleep(0.1)
                              while 1:
                                  t_now = t.read()
                                      lista_heading.append(eul[0])
                                      lista_roll.append(eul[1])
                                      lista_pitch.append(eul[2])
                                      time.sleep(0.5)
                                      if t_now > (secondi - 0.5):
                                          print(lista_roll)
                                          print(lista_pitch)
                                          mean_pos = (media(lista_pitch),
                                                      media(lista_pitch),
                                                      media(lista_heading))
                                          devstd_pos = (dev_std(lista_heading),
                                                        dev_std(lista_roll),
                                                        dev_std(lista_pitch))
                                      t.stop()
                                      del lista_heading
                                      del lista_pitch
                                      del lista_roll
                                      gc.collect()
                                      break
                              # calculate mean
                              mean = 0.0
                              for _ in range (1, len(sequenza)):
                                  mean += sequenza[_]
                              return mean / (len(sequenza)-1)
                          • V Offline
                            @robert-hh thank you for your help, but also after the changes that you suggest the error stay.
                            i think that I need to preallocate the list as arrays, but I don't know i can do. i've never programming with python before.
                            Could you help me please?
                              @vflorio94 I simplified calcoco_position() slightly more and added a print statement. can you tell me how far that progresses, and what is the argument you call calcoso:position(9 with?
                                  gc.collect()
                                  time.sleep(0.03)
                                  # set unit
                                  lib_imu.set_units()
                                  time.sleep(0.03)
                                  # set mode
                                  # create 3 lists
                                  lista_heading = []
                                  lista_roll = []
                                  lista_pitch = []
                                  t = Timer.Chrono()
                                  t.start()
                                  time.sleep(0.1)
                                  while 1:
                                      t_now = t.read()
                                          print("t-now = ", t_now)
                                          time.sleep(0.5)
                                          t.stop()
                                          print(lista_roll)
                                          print(lista_pitch)
                                                      media(lista_pitch),
                              • V Offline
                                VFlorio94
                                when i call calcolo_position I pass to it calcolo_position(1). But i call the function more than one time.
                                i change another time the code but the same is the same.
                                this is my 'main'
                                and few comment before you can find the other function that use inside the function 'calcolo_position(1)'
                                time.sleep(1)
                                position_ok = []
                                gc.collect()
                                time.sleep(2)
                                time.sleep(1)
                                position_no =[]
                                gc.collect()
                                time.sleep(1)
                                time.sleep(1)
                                acquisizione_interval_pitch(20, 1,  mean_pos_ok, mean_pos_no, dev_std_no )`
                                  If you run that line, will it ever return or just give the error?
                                    robert-hh @robert-hh
                                    @robert-hh And if in calcolo_posuition you add a print before the while 1: loop, will that be printed?
                                      @robert-hh I understand. It is the calcolo_position(1) which crashes. That could be another problem in the function media() (division by zero).
                                      Edit: Just to be sure: can you show how the code for calcolo_position() looks now?
                                      • V Offline
                                        @robert-hh if i add a print before 'while 1:' each time that the function is call inside the the other function 'acquisizione_interval_pitch()' I have the print that I write. So during the first time that i run the code it works. Then, if I try to run the same file for the second time it crashes.
                                        The problem is the function 'calcolo_position(1)'.
                                        Calcolo Position before while
                                        t-now =  0.1012856
                                        funzione get euler
                                        t-now =  0.6119527
                                        funzione get euler
                                        [359.25, 359.0]
                                        [-0.875, -0.5]
                                        [82.5, 70.9375]
                                        Calcolo media
                                        Acquisizione terminata```
                                          @vflorio94 But when the program terminates with the call to 'calcolo_position(1)', what is the error message?
                                          V 2 Replies Last reply Reply Quote 0
                                          • V Offline
                                            yes, the problem is the function 'calcolo_position(1)'. But after I call this function and I acquire data during 1 second, in the next call of the function the data collected before are not important.
                                            So, I think that I need to refresh/ release this memory allocation after the call to the function but I don't know how.
                                            Can you help me? thank you a lot.
                                            • 5
                                            • 1 / 5
