    LoPy Nano-Gateway
    62 Posts 27 Posters 52.0k Views 31 Watching
      Roberto @brotherdust
      Hi @brotherdust
      This issue is not related to the nano-gateway code, it is a known issue regarding the WatchDog and we will be addressing it soon, i'll keep you informed with a fix for this.
        Hi @brotherdust,
        The watchdog problem was fixed in the new firamware version, please download it since this is important not only for the nano-gateway but for all the other apps you want to run as well.
        The update is here:
        https://www.pycom.io/support/supportdownloads/
        Please test the nano-gateway code afterwards to make sure that everything is working
        Best,
        Roberto
        • K Offline
          kgadeshi
          @Roberto
          Is it possible to implement some kind of ranging algorithm in LoRa. So that one can calculate the distance between the nodes to the gateway or something along those lines? Thanks.
            livius
            time measurement should be then in nanoseconds i believe
            you can send signal and wait for receive and calc distance divide time by two ;-)
              @kgadeshi with the RSSI of the received packet and knowing the amount of power that was used to transmit it, the free space loss formula can be used to estimate the distance between the 2 nodes.
                Batilan
                You might also have a look at these resources:
                • An extensive discussion on the TTN forum
                • An article by Linklabs stating the issues especially for LoRa (they do have competing products, but the reasoning seems sound)
                • X Offline
                  Xykon administrators
                  After quite a bit of trial and error I have managed to get the LoPy to "talk" in P2P mode to a Dragino LoRa/GPS hat (which uses the same SX1272 chip that's in the LoPy.
                  For anyone interested I have posted some more details here and have made the source code for the LoPy and Raspberry Pi available on github.
                  Christian Ehlers
                  A 1 Reply Last reply Reply Quote 4
                    arista @Xykon
                    This is extremely exiting, since I have exactly the same hardware! I hope I'll have some time this month to test your code, @Xykon, and make the bits fly.
                      angel.imaz
                      Hello.
                      It would be great to get a proper tutorial on how to do a http request from a lora through a nano gateway.
                      I backed you in KS because you made a big point of making this possible. It is great to have the device. But really not very user friendly at all. And you are already launching a new one with more radios. Yet you still have not make LoPy work as promised.
                      Please help!
                      Thank you!
                      Angel
                        bioagbob @angel.imaz
                        Ditto. What's LoRa without a gateway!? Time for proper documentation on this product feature.
                          @angel-imaz please see my post here:
                          https://forum.pycom.io/topic/98/lopy-as-lorawan-basestation/20
                          Our team is working on examples and there will be in the docs soon. If you need a HTTP client library, please try this one out: https://github.com/micropython/micropython-lib/tree/master/http.client
                          • O Offline
                            Oneillsite
                            A good way to test it:
                            2 Lopy's with PymakrBoard connected on 2 usb ports
                            2 instances of Pymakr
                              microman7k
                              I test this sample but after about one hour of working i get "ValueError: buffer too small" on nano gateway. Any clues why?
                              Firmware: (sysname='LoPy', nodename='LoPy', release='0.9.7.b1', version='v1.8.6-234-g765f2bc on 2016-12-02', machine='LoPy with ESP32')
                              Best Regards
                              • O Offline
                                Oneillsite @microman7k
                                @microman7k Hi, first of all you should update the firmware of your Lopy.
                                  microman7k @Oneillsite
                                  @Oneillsite On the latest firmware (1.0.1.b1), results are even worse. After one event i get:
                                  execfile('nanogw.py')
                                  D: 1 P: b'22.5'
                                  E (200196) wifi: error malloc bcn_param
                                  File "nanogw.py", line 20, in <module>
                                  • O Offline
                                    @microman7k i can't figure out why the message mention "wifi"...
                                      borjam @Roberto
                                      I have been playing with it, actually receiving the packets on a Raspberry Pi with a Dragino Lora+GPS Hat and it works. (The "hat" is based on the SX1276).
                                      There is a possibility of making an ugly hack in order to support multiple channels for a gateway. It wouldn´t be a multi channel gateway, but a channel hop capable gateway :)
                                      The trick (I'll try next week) is to use the CAD functionality. Given the length of the prefix it may be possible to do something like this:
                                      • Set frequency
                                      • repeat
                                        CAD
                                        if CAD_DONE // this means timeout
                                        next frequency in list
                                        until CAD_DETECTED
                                      . receive packet
                                      It may be a bit tight, but it should be possible to monitor three frequencies. I'll get back with the results.
                                        @Oneillsite
                                        Hi, on latest firmware version (1.2.0.b1) you get "MemoryError: parser could not allocate enough memory"
                                        File "nanogw.py", line 23
                                        Pycom, can you please provide working sample with the latest firmware version or is this another bug?
                                          lmetcalfe @microman7k
                                          @microman7k
                                          I am getting same error.
                                            We are checking what's happening with this nano-gateway example and we'll get back to you shortly. The memory error can be explained due to the newly added interrupt handler task which is using some of the GC memory and the Bluetooth system also consuming a big chunk. Espressif is due to provide some good memory optimizations to sort this out and give us back several tens of KBs of precious RAM.
                                            • 2 / 4
