    wipy2.0i2cpycompythonsaving data
    100 Posts 2 Posters 28.4k Views 2 Watching
      robert-hh @VFlorio94
      @vflorio94 You should collect & write at the same time. Since the writikng is buffered, most of the write operations will not take long.
        @vflorio94 The code could look like:
        from machine import Timer
        import lib_imu
        from machine import I2C
        from machine import PWM
        chrono = Timer.Chrono()
        lib_imu.set_configmode()
        time.sleep(0.07)
        lib_imu.set_units()
        time.sleep(0.3)
        lib_imu.set_mode('ndof')
        with open("dati360.txt", "w") as file_dati:
            chrono.start()
            lap = chrono.read()
            while lap < 1200
                file_dati.write(repr(lib_imu.get_euler()[0]))
                time.sleep(0.02)
                lap = chrono.read()
        print("fine")
        chrono.stop()
        • V Offline
          VFlorio94 @robert-hh
          @robert-hh Thank you, I did in this way and the code run, but the real sample isn't 0.02 s but each 0.035 s. And I don't know why?!
            @vflorio94 Taking the measurement and writing takes time too. Now you know, it's about 0.015s.
            V 2 Replies Last reply Reply Quote 0
            • V Offline
              @robert-hh Thank you very much for your help. I've never scheduled with Python, so for me is very difficult and I have to do this for my master thesis. For me you were very valuable.
              thank you.
              • V Offline
                @robert-hh Hi, sorry for my insistence. I have a new problem
                ╝Traceback (most recent call last):
                  File "<stdin>", line 24, in <module>
                OSError: 28
                but i don't know why, because Yesterday this code run and now it give me this message.
                the code is this one
                import lib_imu
                import gc
                time.sleep(0.05)
                lib_imu.set_units()
                time.sleep(0.05)
                # List =[]
                file_dati = open("datiprova_tempo20.txt", "a")
                chrono.start()
                lap = chrono.read()
                while lap <= 1200:
                    #eul = lib_imu.get_euler()
                    file_dati.write(repr(lap) + "\t ")
                    file_dati.write(repr(lib_imu.get_euler()[0]) + "\t ")
                    time.sleep(0.02)
                    lap = chrono.read()
                file_dati.close()
                print("fine")
                chrono.stop()
                Can you help me please?
                  @vflorio94 Error 28 means: "No space left on device"
                  So your file system is full. You have to delete some files, or better change your code to save on an SD card. The internal flash file system is pretty small. I do not know why, because most of the FiPy's flash is not used.
                  • V Offline
                    @robert-hh I delete each file.txt that I write before on the device with Filezilla.0_1534410021987_Screenshot (1).png
                    Yesterday and the day before in this condition I can wrote file.txt on the device, but now I can't and it give me this error.
                    but on the memory there are only those file.py.
                      @vflorio94 Are there any other files in the subdirectories, like in lib?
                      • V Offline
                        @robert-hh No, there aren't any file in the subdirectory. But Yesterday it run program and saved them on memory.
                        after I collected data I deleted immediately file.txt. But now I have this error.
                        Probably do not filezilla really delete file?
                          @vflorio94 At the REPL prompt, you can also get the file list and free space with:
                          import uos
                          uos.listdir()
                          uos.getfree("/flash")
                            @vflorio94 Filezilla just sends commands to the ftp server of the FiPy.
                            • V Offline
                              @robert-hh I use the command that you wrote and it gives me the message:
                              import uos
                              print(uos.listdir())
                              print(uos.getfree("/flash"))
                              ['main.py', 'sending.py', 'sys', 'lib', 'cert', 'boot.py', 'datiprova_tempo20.txt', 'lib_imu.py', 'interval_position.py']
                              0
                              but it's incredible, just Yesterday it run. and I don't know what can I do now?!
                                @vflorio94 You can tell the size ofdatiprova_tempo20.txt with:
                                import uos
                                uos.stat('datiprova_tempo20.txt')
                                Every time you call your script this file will get larger, since you open that in append mode "a". I am just wondering why this file is not shown in the FileZilla screen dump.
                                • V Offline
                                  @robert-hh said in Wipy 2.0 and save data on my pc, not in flash memory:
                                  import uos
                                  now I delete also the function 'interval.py' and 'sending.py' but it continue to give me the same error.
                                    @vflorio94 But how large is 'datiprova_tempo20.txt'? That is the file which grows by about 50kBytes on every execution of your script.
                                    • V Offline
                                      (32768, 0, 0, 0, 0, 0, 0, 315535722, 315535722, 315535722)
                                       File "<stdin>", line 27, in <module>
                                      OSError: 28
                                      MicroPython v1.8.6-849-56d00234 on 2018-05-18; WiPy with ESP32
                                      But Yesterday i did a test of 1200 s and it worked. now i delete everything from flash except the necessary function
                                        @vflorio94 OK. So the file size is 0. Did you change anything else? like the file name (even if that seems strange)?
                                        • V Offline
                                          Yes, I change the name of my file.txt each time that I collect data, but Yesterday I run this script about 20 times , also the day before, And it worked
                                            @vflorio94 So where are these files? if the local file system of your wipy is corrupted, you can always reflash the device with the option to clear the file system, at which point it will be recreated.
                                            • 5
                                            • 3 / 5
