    SiPy firmware update tool now available with ID and PAC for activation
    41 Posts 13 Posters 15.3k Views 12 Watching
      maku
      I got the updater running, no problems :) os.uname() = (sysname='SiPy', nodename='SiPy', release='1.5.0.b2', version='v1.8.6-429-g062de94 on 2017-02-05', machine='SiPy with ESP32', sigfox='1.0.0') :))
      However - I can't get the Bleutooth lib working?
      You said it would be included in this long awaited fw update?!
        @maku, yes sorry, I made a mistake when publishing the firmware and I used a version with Bluetooth disabled. Apologies for this. A new version will be released today with Bluetooth included.
          maku
          Sweet. Thank you for the effort, quick reply and know it's appreciated.
            MrPy
            All worked fine for me - thanks for the efforts and works great.
              Ricardo M
              The firmware update works fine, but I run the example code (https://docs.pycom.io/pycom_esp32/library/network.Sigfox.html) adapting it to my RCZ and I do not see the messages in the sigfox backend, what am I doing wrong?
              • N Offline
                nicolsc @Ricardo M
                @Ricardo-M said in SiPy firmware update tool now available with ID and PAC for activation:
                1. Check that you plugged the antenna on the right uFL port, next to the sigfox print. I did this mistake at first ...
                2. Did you check Sigfox coverage in your area ?
                Feel free to reach out at devrelations@sigfox.com if you want me to get a closer look (precise coverage, ...)
                Developer Relations @Sigfox
                  daniel @nicolsc
                  @nicolsc thanks for jumping into this so quickly.
                  @Ricardo-M which RCZ are you trying? Is it zone 2 by chance? Adding to what @nicolsc wrote, the pinout sheet points to the correct u.fl connector for the Sigfox antenna: https://www.pycom.io/wp-content/uploads/2017/02/Sipy_v01_1_pinout_rc.pdf :-)
                    Ricardo M
                    @nicolsc and @daniel thank you very much for the clarifications and your quick response, the problem was the same as @nicolsc, I was just seeing the sipy diagram that is shown in the datasheet and the UFL connector where should go the sigfox antenna will be labeled as LORA, So I plug it into the other, but it was just make the connector change and it worked.
                    My RCZ is 4 (Colombia) and I know with certainty that there is coverage where I carry out the tests.
                    I already see the messages in the backend
                    Additionally many garcias by the pinoout.
                    Great job, everything works great.
                    • F Offline
                      felirangelp
                      @daniel,
                      Thank you very much Daniel, this update is very important for my project.
                        javega20 @Ricardo M
                        @ricardo-m hola Ricardo, estoy intentado conectarme por sigfox en Cali, sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ4) pero no puedo ver el dispositivo en el backend, podrías darme alguna indicación, muchas gracias.
                        • 3 / 3
