    SiPy firmware update tool now available with ID and PAC for activation
    41 Posts 13 Posters 15.3k Views 12 Watching
      sk @daniel
      @daniel No, the instructions on the doc said to do that after update had finished.
      • Disconnect your device from the PC.
      • Connect wire G23+GND using a jumper cable.
      • Connect the board to the USB.
      • Run the upgrader
      • Remove the G23+GND wire.
      • Reboot the device (button or powercycle)
      Should I do that right after connecting the GND+G23 and then run updater?
        OK you are right, but sometimes resetting after connecting the cable jumper helps. We'll update the instructions to include that. Thanks. Please try it...
          daniel @sk
          @sk
          Yes, please :-)
            sk @daniel
            @daniel How long does the update usually take? Its been about 30min but the updater is still saying "Please wait, reading information about board..."
              @sk that part takes like 5 seconds... are you using a expansion board? Is your internet connection via a proxy?
                sk @daniel
                @daniel no, no proxy. Yes I'm using the expansion board. I tried again and its still stuck on getting board information.
                EDIT: Yes proxy. That's what was stopping the updater from updating the SiPy. Thanks for all the help! :D
                • I Offline
                  iotmaker
                  i had lots of problems to get it to work, i had to Safe boot, the factory
                  firmware and then i did run the update connecting the GND+G23 and then run updater
                  nevertheless the new firmware is useless because pymkr is so buggy i cant even sync a damm project.. i am willing two sell my 2 kits with expansion board here on the US.. message me ..
                    maku
                    I got the updater running, no problems :) os.uname() = (sysname='SiPy', nodename='SiPy', release='1.5.0.b2', version='v1.8.6-429-g062de94 on 2017-02-05', machine='SiPy with ESP32', sigfox='1.0.0') :))
                    However - I can't get the Bleutooth lib working?
                    You said it would be included in this long awaited fw update?!
                      @maku, yes sorry, I made a mistake when publishing the firmware and I used a version with Bluetooth disabled. Apologies for this. A new version will be released today with Bluetooth included.
                        maku
                        Sweet. Thank you for the effort, quick reply and know it's appreciated.
                          MrPy
                          All worked fine for me - thanks for the efforts and works great.
                            Ricardo M
                            The firmware update works fine, but I run the example code (https://docs.pycom.io/pycom_esp32/library/network.Sigfox.html) adapting it to my RCZ and I do not see the messages in the sigfox backend, what am I doing wrong?
                            • N Offline
                              nicolsc @Ricardo M
                              @Ricardo-M said in SiPy firmware update tool now available with ID and PAC for activation:
                              1. Check that you plugged the antenna on the right uFL port, next to the sigfox print. I did this mistake at first ...
                              2. Did you check Sigfox coverage in your area ?
                              Feel free to reach out at devrelations@sigfox.com if you want me to get a closer look (precise coverage, ...)
                              Developer Relations @Sigfox
                                daniel @nicolsc
                                @nicolsc thanks for jumping into this so quickly.
                                @Ricardo-M which RCZ are you trying? Is it zone 2 by chance? Adding to what @nicolsc wrote, the pinout sheet points to the correct u.fl connector for the Sigfox antenna: https://www.pycom.io/wp-content/uploads/2017/02/Sipy_v01_1_pinout_rc.pdf :-)
                                  Ricardo M
                                  @nicolsc and @daniel thank you very much for the clarifications and your quick response, the problem was the same as @nicolsc, I was just seeing the sipy diagram that is shown in the datasheet and the UFL connector where should go the sigfox antenna will be labeled as LORA, So I plug it into the other, but it was just make the connector change and it worked.
                                  My RCZ is 4 (Colombia) and I know with certainty that there is coverage where I carry out the tests.
                                  I already see the messages in the backend
                                  Additionally many garcias by the pinoout.
                                  Great job, everything works great.
                                  • F Offline
                                    felirangelp
                                    @daniel,
                                    Thank you very much Daniel, this update is very important for my project.
                                      javega20 @Ricardo M
                                      @ricardo-m hola Ricardo, estoy intentado conectarme por sigfox en Cali, sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ4) pero no puedo ver el dispositivo en el backend, podrías darme alguna indicación, muchas gracias.
                                      • 2 / 3
