    SiPy firmware update tool now available with ID and PAC for activation
    41 Posts 13 Posters 15.3k Views 12 Watching
      daniel @sk
      @sk you need to use either the Windows or the MAC OS one. We will publish the Linux tool supporting the SiPy shortly.
        sk @daniel
        @daniel Im using windows
        The file I download is pycom_firmware_update_1.1.0.b1.exe
          rskoniec
          @sk Yes, it is, description is not vaild, but the link for Windows goes to the right one 1.1.0.b1. Did you try to uncheck the "High speed transfer" option? Sometimes it helps.
            Did you reset the board after connecting G23 to GND?
              sk @daniel
              @daniel No, the instructions on the doc said to do that after update had finished.
              • Disconnect your device from the PC.
              • Connect wire G23+GND using a jumper cable.
              • Connect the board to the USB.
              • Run the upgrader
              • Remove the G23+GND wire.
              • Reboot the device (button or powercycle)
              Should I do that right after connecting the GND+G23 and then run updater?
                OK you are right, but sometimes resetting after connecting the cable jumper helps. We'll update the instructions to include that. Thanks. Please try it...
                  daniel @sk
                  @sk
                  Yes, please :-)
                    sk @daniel
                    @daniel How long does the update usually take? Its been about 30min but the updater is still saying "Please wait, reading information about board..."
                      @sk that part takes like 5 seconds... are you using a expansion board? Is your internet connection via a proxy?
                        sk @daniel
                        @daniel no, no proxy. Yes I'm using the expansion board. I tried again and its still stuck on getting board information.
                        EDIT: Yes proxy. That's what was stopping the updater from updating the SiPy. Thanks for all the help! :D
                        • I Offline
                          iotmaker
                          i had lots of problems to get it to work, i had to Safe boot, the factory
                          firmware and then i did run the update connecting the GND+G23 and then run updater
                          nevertheless the new firmware is useless because pymkr is so buggy i cant even sync a damm project.. i am willing two sell my 2 kits with expansion board here on the US.. message me ..
                            maku
                            I got the updater running, no problems :) os.uname() = (sysname='SiPy', nodename='SiPy', release='1.5.0.b2', version='v1.8.6-429-g062de94 on 2017-02-05', machine='SiPy with ESP32', sigfox='1.0.0') :))
                            However - I can't get the Bleutooth lib working?
                            You said it would be included in this long awaited fw update?!
                              @maku, yes sorry, I made a mistake when publishing the firmware and I used a version with Bluetooth disabled. Apologies for this. A new version will be released today with Bluetooth included.
                                maku
                                Sweet. Thank you for the effort, quick reply and know it's appreciated.
                                  MrPy
                                  All worked fine for me - thanks for the efforts and works great.
                                    Ricardo M
                                    The firmware update works fine, but I run the example code (https://docs.pycom.io/pycom_esp32/library/network.Sigfox.html) adapting it to my RCZ and I do not see the messages in the sigfox backend, what am I doing wrong?
                                    • N Offline
                                      nicolsc @Ricardo M
                                      @Ricardo-M said in SiPy firmware update tool now available with ID and PAC for activation:
                                      1. Check that you plugged the antenna on the right uFL port, next to the sigfox print. I did this mistake at first ...
                                      2. Did you check Sigfox coverage in your area ?
                                      Feel free to reach out at devrelations@sigfox.com if you want me to get a closer look (precise coverage, ...)
                                      Developer Relations @Sigfox
                                        daniel @nicolsc
                                        @nicolsc thanks for jumping into this so quickly.
                                        @Ricardo-M which RCZ are you trying? Is it zone 2 by chance? Adding to what @nicolsc wrote, the pinout sheet points to the correct u.fl connector for the Sigfox antenna: https://www.pycom.io/wp-content/uploads/2017/02/Sipy_v01_1_pinout_rc.pdf :-)
                                          Ricardo M
                                          @nicolsc and @daniel thank you very much for the clarifications and your quick response, the problem was the same as @nicolsc, I was just seeing the sipy diagram that is shown in the datasheet and the UFL connector where should go the sigfox antenna will be labeled as LORA, So I plug it into the other, but it was just make the connector change and it worked.
                                          My RCZ is 4 (Colombia) and I know with certainty that there is coverage where I carry out the tests.
                                          I already see the messages in the backend
                                          Additionally many garcias by the pinoout.
                                          Great job, everything works great.
                                          • F Offline
                                            felirangelp
                                            @daniel,
                                            Thank you very much Daniel, this update is very important for my project.
                                            • 2 / 3
