    Problem getting MAG data from Adafruit LSM303
    adafruitlopymagnetometer
    4 Posts 2 Posters 737 Views 2 Watching
    • O Offline
      oldGuyDave
      I have an Adafruit LSM303 board connected to a PyCOM LoPY (ESP32 cpu) and I can communicate to the LSM303HDLC chip over I2C.
      I am getting what appears to be reasonable data from the accelerometer.
      I can read, write, modify and verify i2c changes to the 3 config magnetometer registers. For some reason (maybe I missed something in the LSM303 data sheet) the mag data registers, temperature registers and the status register always read 0x00.
      My config registers currently contain:
      CRA_REG_M = 0x98
      CRB_REG_M = 0x20
      MR_REG_M = 0x00
      Any ideas?
      “Life is trying things to see if they work.” ~Ray Bradbury
      • rcolisteteR Offline
        rcolistete
        Are you using your own code or a LSM303HDLC MicroPython driver ?
        • O Offline
          oldGuyDave
          The code is my own, albeit copied in content and structure from what I believe is a working adafruit project. My modifications include such changes as...
          adafruit project code:
          self._mag.write8(LSM303_REGISTER_MAG_MR_REG_M, 0x00)
          mag_raw = self._mag.readList(LSM303_REGISTER_MAG_OUT_X_H_M, 6)
          vs.
          my code:
          self.i2c.writeto_mem(LSM303_ADDRESS_MAG,LSM303_REGISTER_MAG_CRA_REG_M, 0x98)
          self.i2c.writeto_mem(LSM303_ADDRESS_MAG,LSM303_REGISTER_MAG_CRB_REG_M, 0x20)
          self.i2c.writeto_mem(LSM303_ADDRESS_MAG,LSM303_REGISTER_MAG_MR_REG_M, 0x00)
          MAG=self.i2c.readfrom_mem(LSM303_ADDRESS_MAG,LSM303_REGISTER_MAG_OUT_X_H_M | 0x80, 6)
          Please keep in mind the accelerometer part of the chip seems to be working fine.
          • O Offline
            oldGuyDave @rcolistete
            @rcolistete Maybe I misunderstood your question. The code I was referring to above is my own library that calls the 'built-in' machine.I2C micropython driver supplied in the LoPy firmware binary rev. 1.18.1.r1.
            Example:
            def __init__(self):
                            self.i2c = I2C(0, mode=I2C.MASTER, pins=(sda, scl), baudrate=100000);
                    magEnable = [0x10, 0x20, 0x00]
                    self.i2c.writeto_mem(MAG_DEV_ADDR, MAG_CONFIG_REG_A, bytearray(magEnable));
