    Wake machine.deepsleep using pin input from accelerometer [SOLVED]
    deepsleepinterruptpinaccelerometer
    5 Posts 2 Posters 1.5k Views 3 Watching
      alexpul
      I'm trying to create an accelerometer interrupt for machine.deepsleep(). From what I can tell there is no built-in function for that. Since deep sleep can be interrupted with a pin I was thinking that there might be a pin that allows the accelerometer to relay an interrupt to the device.
      I've tried P13, which is denoted as "Accelerometer Interrupt" on the Pytrack pinout but I didn't get a response (even when the device was not asleep). Here is the code I was using
      from machine import Pin
      def pin_handler(arg):
          print("got an interrupt in pin %s" % (arg.id()))
      p_in = Pin('P13', mode=Pin.IN, pull=Pin.PULL_UP)
      p_in.callback(Pin.IRQ_FALLING, pin_handler)
      Any ideas or suggestions would be great!
      My system specs:
      (sysname='WiPy', nodename='WiPy', release='1.18.0.r1', version='v1.8.6-849-9569a73 on 2018-07-20', machine='WiPy with ESP32', pybytes='0.9.0')
        jcaron @alexpul
        @alexpul Did you configure the accelerometer (enable it, set it to monitor events and send interrupts)?
        You need to at least instantiate the LIS2HH12 class, and call the enable_activity_interrupt method.
        There may be more stuff to do. Check the sources of the PyTrack library for more information.
          alexpul @jcaron
          @jcaron This is the code I've tried to test if the accelerometer can wake from machine.deepsleep()
          from LIS2HH12 import LIS2HH12
          import utime
          pycom.heartbeat(False)
          def accel_activity_handler(pin_o):
              pycom.rgbled(0x800080)
              utime.sleep_ms(200)
          ## ACCELEROMETER INTERRUPT
          acc = LIS2HH12()
          acc.enable_activity_interrupt(1000, 200, handler=accel_activity_handler)
          machine.deepsleep(100*1000)
          When I shake the device nothing happens...
          (Note that this script does allow for a deep sleep interrupt but only when pytrack.go_to_sleep() is used to enter deep sleep. I need to use machine.deepsleep() though..)
            jcaron @alexpul
            @alexpul In that code you don't enable wake-on-pin, and you don't do anything visible before going back to sleep, so even if it wakes up you won't see anything...
            Note that as far as I know, the handler will only be called if the interrupt happens while the device is awake, not during sleep.
            Start by using acc.enable_activity_interrupt without any deep sleep to see if the interrupt gets triggered (i.e. just remove the machine.deepsleep in your code).
            Once you have confirmed that, you can add the wake-on-pin, and do something visible when you wake up before going back to sleep.
              alexpul
              Ah ha. I was using the wrong interrupt script.
              This is the correct working code for an accelerometer interrupt (P13) of machine.deepsleep():
              machine.pin_deepsleep_wakeup(['P13'], machine.WAKEUP_ANY_HIGH, False)
              machine.deepsleep(10*1000)
              So for pin interrupts there is a callback() function to create interrupts of active and sleep modes but the pin_deepsleep_wakeup() is needed to interrupt deep sleep (is that what you meant by "wake-on-pin" @jcaron?). There is no interrupt handler for pin_deepsleep_wakeup() because the working memory is cleared after deep sleep (as mentioned by @jcaron below).
              @jcaron I had tested my interrupt handler without sleep and it did work. In my main.py I had the following script to test that it woke from deep sleep and ran main.py.
              import utime
              pycom.heartbeat(False)                      #turn off LED
              pycom.rgbled(0xFF0000)                    #red LED
              utime.sleep(2)
              With your input, this post could be even better šŸ’—
