    AWSIoTMQTTClient keepalive interval?
    aws mqttaws iotbandwidthlte-mlte m1
    4 Posts 2 Posters 976 Views 2 Watching
      reidfo
      I've just gotten my FiPy to connect to AWS IoT via TLS and MQTT. In monitoring the device it is sending a little over 200 bytes to AWS every 20 seconds. I see Packet sent. (Length: 2) at 20 second intervals. While this might be fine over WiFi it will nearly use up my 1MB LTE Cat M1 data plan after one day just with these keepalive packets. How do I reduce the keepalive interval with the built-in AWSIotMQTTClient? There is no way I can deploy on LTE with this much data being transmitted. This doesn't even include any of my actual MQTT messages! Just the keepalives.
        cmisztur @reidfo
        @reidfo looks like simple.py constructor takes a keepalive
        def __init__(self, client_id, server, port=0, user=None, password=None, keepalive=0,
                         ssl=False, ssl_params={}):
        oh I wasn't aware of AWSIotMQTTClient... maybe this:
        https://github.com/pycom/pycom-micropython-sigfox/blob/f517b1df5083ddc158c075852d7f2497480b0d84/esp32/frozen/Common/MQTTLib.py#L43
          reidfo @cmisztur
          @cmisztur That does take a parameter, in connect() called keepAliveIntervalSecond, but when I set it it seems to be ignored. Keepalive packets are still being sent every 20 seconds. Following the code, AWSIotMQTTClient.connect() ends up calling MQTTClient._send_connect() and is passed the keepalive parameter, but it does nothing with it.
            cmisztur @reidfo
            @reidfo Sure looks like it. Change line 294, see if you get a different behavior.
            http://docs.oasis-open.org/mqtt/mqtt/v3.1.1/os/mqtt-v3.1.1-os.html#_Toc385349238
            https://github.com/pycom/pycom-micropython-sigfox/blob/f517b1df5083ddc158c075852d7f2497480b0d84/esp32/frozen/Common/MQTTClient.py#L294
