    TimerWipy
    wipy 2timer interruptimerirq
    17 Posts 2 Posters 2.6k Views 2 Watching
    • V Offline
      VFlorio94 @robert-hh
      @robert-hh the function can be like this?
      from machine import Timer
      import lib_imu
      import lib_imu2
      from machine import I2C
      from math import sqrt
      from machine import PWM
      from machine import SD
      import gc
      sd = SD()
      os.chdir('/sd')
      PERIOD= 0.02 #sample time
      lib_imu.set_configmode()
      time.sleep(0.01)
      lib_imu.set_units()
      time.sleep(0.01)
      lib_imu.set_mode('ndof')
      time.sleep(0.01)
      lib_imu2.set_configmode()
      time.sleep(0.01)
      lib_imu2.set_units()
      time.sleep(0.01)
      lib_imu2.set_mode('ndof')
      time.sleep(0.01)
      fileIMU1 = open('/sd/dati_IMU1.txt', 'w')
      #fileT_IMU1 = open("/sd/datiT_IMU1.txt", "w")
      fileIMU2 = open('/sd/dati_IMU2.txt', 'w')
      #fileT_IMU2 = open("/sd/datiT_IMU2.txt", "w")
      file_tempi = open('/sd/tempi.txt', 'w')
      list_eul = [ ]
      list_eul2 = [ ]
      list_tempi = []
      def sample_and_write(timer_obj):   #timer_obj??
          #list_tempi.append(temp.read())
          list_eul.append(lib_imu.get_euler_int())
          list_eul2.append(lib_imu2.get_euler_int())
          pass
      def acquisition(sec):
          t = Timer.Chrono()
          t.start()
          while 1:
              t = t.read()
              if  t <= sec :
                  alarm = Timer.Alarm(sample_and_write, PERIOD, periodic = true)
                  alarm.cancel()
                  fileIMU1.write(  repr(list_eul) + '\t')
                  fileIMU2.write( repr(list_eul2) + '\t')
                  del list_eul
                  del list_eul2
        robert-hh @VFlorio94
        @vflorio94 You do not have to call alarm. Actually, it is not a function, it is a timer object. The callback function is called by the Timer periodically without further action by your main program. You main code has to prepare the data & objects needed by the callback and then start the timer. Typically, all of that would be enclosed in a class, and the main program would just instantiate this class. That could look like this:
        from machine import Timer, idle
        # add the other imports here that you need
        # acquire  values. The paramters of the constructor are:
        class Acquire:
            def __init__(self, filename_imu1, period=0.2, runtime = 60):
                self.fileIMU1 = open(filename_imu1, "w") # or append
                self.temp = Timer.Chrono()
                self.busy = True
                self.runtime = runtime
                self.temp.start()
                self.alarm = Timer.Alarm(self.sample_and_write, period ,periodic=True)
                # and add all other init tasks you need
            def stop(self):
                self.alarm.cancel()
                self.fileIMU1.close()
            def sample_and_write(self, alarm):
                passed = self.temp.read()
                # check, if done, if the time for sampling is expired, then stop
                if passed >= self.runtime:
                    self.stop()
                    self.busy = False
                    # get data and write
                    print(passed, self.runtime)
                    self.fileIMU1.write(repr(passed) + "," + lib_imu.get_euler_int() + "\n")
                    # and what else you have to do.
        # now here the skeleton main_
        # set up the hardware
        # and start
        acquire = Acquire("my_data_file", 0.2, 20)
        # now get the data, until it's done
        while acquire.busy:
            idle()
        # whatever you have to do for cleanup, do it here
          @vflorio94 Timer.Alarm() has to be called only once.
          • V Offline
            @robert-hh I understand all. finally it works without any interrupt
            than you a lot.
            • V Offline
              @robert-hh Hello. I have to ask you a new thing correlate with this code that you wrote previously.
              I want to implement the code with another part in which I desire to activate PWM depending on the data sample and wrote by IMU. So, the question is:
              Is it correct if I introduced a control on the data that I wrote and the command to activate PWM in the fuction 'sample and write'?
              And have I also to complete class acquire like this?
              self.pwm = PWM(0.02, frequency=500 ) #This sets up the timer to
                      #oscillate at the specified frequency. timer is an integer from 0 to 3.
                      # frequency is an integer from 1 Hz to 78 KHz
              I know that I have also to set PWM channel where I put set-up Hardware parameters.
              I'll be newly grateful if you can help me.
                @vflorio94 said in TimerWipy:
                The first argument of the class instantiation is a timer ID, not a time or the like. The value range is 0 - 3. See: https://docs.pycom.io/firmwareapi/pycom/machine/pwm
                So it should be:
                self.pwm = PWM(0, frequency=500 )
                • V Offline
                  @robert-hh yes, I checked and you are right. And about command to activate pwm responding to data acquire by sensor?
                    @vflorio94 ???
                    • V Offline
                      @robert-hh sorry, I describe the problem in a bad way. I have another question.
                      I have a data that I want to use inside the function 'sample_and_write', but I have some difficulties to pass it from main to the class '''Acquire''' and in the end to the function. Is it possible ? can you help me?
                        @vflorio94 That's a question of scope and visibility in Python.
                        So most simple but unelegant method is to have that data global. So it is created outside every function. Then at any part of your code you can declare is a global to access it. Example:
                        # at the top level of your code:
                        data_buffer = bytearray(100)
                        data_ptr_in = 0
                        data_ptr_out = 0
                        class MyClass:
                            def my_func(self):
                                # declare symbols as global
                                global data_buffer, data_ptr_in, data_ptr_out
                                data_buffer[data_ptr_in] = some_data
                                data_ptr_in = (data_ptr_in + 1) % len(data:buffer)
                        You can also define functions (or better to say methods) to pass along data, and you can use property and setter and getter methods of classes, ...
                        • V Offline
                          @robert-hh Thank you, I solved this problem. I put data as metod.
                          Now I have a new problem because I want to read data from sensor and after a comparisono with reference data I want to activate pwm. I did it in this way.
                          But the problem is that the period change a lot, sample time decrease to 0.04.
                          Is there another way to modify this code for activate pwm that can be better??
                          I need if it is possible that period remain more possible like 0.02.
                          thank you
                          from machine import idle
                          import lib_imu
                          import lib_imu2
                          from math import fabs
                          import gc
                          sd = SD()
                          os.chdir('/sd')
                          # fileIMU1 = open('/sd/dati_IMU1.txt', 'w')
                          class Acquire:
                              def __init__(self, filename_imu1, data, period=0.02, runtime = 60):
                                  self.busy = True
                                  self.data = data
                                  self.temp.start()
                                  self.alarm = Timer.Alarm(self.sample_and_write, period , periodic=True)
                              def stop(self):
                                  self.alarm.cancel()
                                  pwm_c2.duty_cycle(0)
                                  pwm_c5.duty_cycle(0)
                                  #self.fileIMU2.close()
                                      self.stop()
                                      self.busy = False
                                      print('end')
                                      #print(passed, fabs(lib_imu2.get_euler()[2]))
                                      self.fileIMU1.write(repr(passed) + repr(lib_imu2.get_euler()) + "\n")
                                       # avanti
                                      if fabs(lib_imu2.get_euler()[2]) > ( fabs(dati_rif[2]) + 0.2):
                                          if fabs(lib_imu2.get_euler()[2]) < (fabs(dati_rif[2]) + 0.4):
                                              pwm2 = PWM(0, frequency=1000 )
                                              pwm_c2.duty_cycle(0.5)
                                          elif fabs(lib_imu2.get_euler()[2]) >= (fabs(dati_rif[2]) + 2):
                                              pwm2 = PWM(0, frequency=2000 )
                                              pwm_c2.duty_cycle(0.6)
                                      # indietro
                                      elif fabs(lib_imu2.get_euler()[2]) <  fabs(dati_rif[2]) + 0.2:
                                          if fabs(lib_imu2.get_euler()[2]) > (fabs(dati_rif[2]) + 0.4):
                                              pwm5 = PWM(0, frequency=1000 )
                                              pwm_c5.duty_cycle(0.5)
                                          elif fabs(lib_imu2.get_euler()[2])< (fabs(dati_rif[2]) + 2):
                                              pwm5 = PWM(0, frequency=2000 )
                          sd = SD()
                          os.chdir('/sd')
                          ''' SET UP IMU 0X29 '''
                          # Scala Berg: imu L5 - lib_imu - acc
                          lib_imu.set_acc()
                          time.sleep(0.01)
                          time.sleep(0.01)
                          lib_imu.set_units()
                          time.sleep(0.01)
                          time.sleep(0.01)
                          ''' SET UP IMU 0X28 '''
                          # imu t1 - lib_imu2 - eul
                          time.sleep(0.01)
                          time.sleep(0.01)
                          time.sleep(0.01)
                          ''' PWM '''
                          pwm2 = PWM(0, frequency=500 )
                          pwm5 = PWM(0, frequency=500 )
                          pwm_c5 = pwm2.channel(5, pin='P12') #dietro
                          pwm_c2 = pwm5.channel(2, pin='P5')   # avanti
                          time.sleep(0.01)
                          time.sleep(0.01)
                          ''' START'''
                          with open("/sd/Rif.txt", "r") as f:
                              line = f.read()
                              # now you have a list of one string per line
                              dati_rif = [float(el) for el in line.strip("()\n ").split(",")]  # reference data
                          print('start')
                          acquire = Acquire('Acquisition_Vibration.txt', dati_rif[2], 0.02, 30)
                          while acquire.busy:
                              idle()
                            @vflorio94 For a consistent operation at a period of 0.02 or 50 ms it is required that the handler takes not longer than that, and that is executes the OWM changes at almost the same time within the handler. Looking at your code, I see at least two things that could affect timing:
                            a) You write to a file. File i/O is buffered. As long as the data is written into the buffer, it's fast. When the buffer will be written, it can be slow.
                            b) You call lib_imu2.get_euler() several times in the timer handler. I do not know the complexity of that call, but if it includes access to external hardware, then it may take some time. Better call it once, store the result and use that in consecutive statements.
                            V 2 Replies Last reply Reply Quote 0
                            • V Offline
                              @robert-hh I solved the problem creating a new function to compare data acquire by sensor with reference data and then it power on pwm. And in this way the period remain 50 ms.
                              thank you
                              • V Offline
                                @robert-hh Hi, sorry for my insistence on this topic.
                                I 'm not able to use thread but I read about it and I think that it's better for my code if I use them . So do you know if is it possibile to use thread to read from two I2C through the code that I posted before?
                                thank you.
