    New LTE Firmware releases v1.18.1.r4 (stable) & 1.19.0.b5 (development) & NB-IoT firmware 40343
    firmwarelte
    51 Posts 12 Posters 10.8k Views 14 Watching
      tlanier @Xykon
      @xykon
      With v1.18.1.r4 installed I now get an error when I try to do a socket connect.
        serafimsaudade @tlanier
        @tlanier
        I'm getting the same error, but don't happens all the time. It seems a DNS problem.
        If a use the IP address the error disappears.
        Tested with MEO/Altice Portugal
        T danD 2 Replies Last reply Reply Quote 0
          reidfo
          Will you be adding an option to the updater to use LittleFS?
          • danD Offline
            dan @reidfo
            @reidfo If you use the development version of the firmware and updater, you have an option to choose file systems (check Show Advanced Settings).
              tlanier @serafimsaudade
              @serafimsaudade
              I get the same error even if I use an IP address. I don't think it's a DNS problem.
                reidfo @dan
                @dan Thanks, not sure how I missed that. I updated to 1.19.0.b5 using the updater and it broke LTE on my FiPy. The board would initially attach, then after several seconds the connection seemed to hang. AT commands took several seconds to complete. I downgraded back to my previous firmware (1.19.0.b4 built myself from the development branch) and it started working again.
                • danD Offline
                  dan @serafimsaudade
                  @serafimsaudade @tlanier we are looking into the issue with sockets
                  D T 2 Replies Last reply Reply Quote 0
                    danielm @dan
                    @dan
                    Is there any time estimation for fix of socket issue?
                      tlanier @dan
                      @dan
                      If it helps, note that the socket error occurs even if I'm using WIFI and connecting to a static IP. I don't think the problem has anything to do with the LTE module.
                      D S T 3 Replies Last reply Reply Quote 0
                        danielm @tlanier
                        @tlanier
                        Is the behaviour identical on 1.19.0.b5 and 1.18.1.r4?
                          @tlanier
                          I'm using mqtt that use sockets over wifi connection with no problem.
                            tlanier @tlanier
                            @tlanier
                            The problem with the previous code was my own fault. The "ssl.wrap_socket(s)" line should not be used when connecting to a non-secure site.
                            I now believe that the problem only occurs when connecting to a secure site. I can successfully connect using WIFI to a non-secure site. If I try to connect to a secure site (www.google.com), I get a stack overflow error.
                            T I 2 Replies Last reply Reply Quote 0
                              tlanier @tlanier
                              @tlanier
                              I'm now successfully connecting and downloading from a non-secure site using either LTE or WIFI. The errors occur if I try to connect to a secure site (www.google.com) using either LTE or WIFI.
                              # TEST - uses cell modem
                              def get1():
                                  try:
                                      log('creating LTE object - carrier verizon')
                                      # lte = LTE()
                                      lte = LTE(carrier="verizon")
                                      # lte = LTE(carrier="at&t")         # instantiate the LTE object
                                      log('resetting modem, may take up to 5 secs...')
                                      lte.reset()
                                      log('attaching...')
                                      lte.attach(apn='apn.hologram.io')        # attach the cellular modem to a base station
                                      # lte.attach(band=13)        # attach the cellular modem to a base station
                                      i = 0
                                      while not lte.isattached():
                                          log('waiting for isattached...')
                                          utime.sleep_ms(1000)
                                      log('connecting...')
                                      # lte.connect()       # start a data session and obtain an IP address
                                      lte.connect(cid=3)    # cid=3 for verizon - start a data session and obtain an IP address
                                      while not lte.isconnected():
                                          log('waiting for isconnected...')
                                          utime.sleep_ms(500)
                                      log('create socket')
                                      s = socket.socket()
                                      log("Connect to: www.ces-web.com")
                                      sockaddr = socket.getaddrinfo('www.ces-web.com', 80)[0][-1]
                                      #log("Connect to: www.google.com")
                                      #s = ssl.wrap_socket(s)
                                      #sockaddr = socket.getaddrinfo('www.google.com', 443)[0][-1]
                                      log("socket address: {}".format(sockaddr))
                                      s.connect(sockaddr)
                                      log("send GET request")
                                      s.send(b"GET / HTTP/1.0\r\n\r\n")
                                      log("receive response")
                                      log(s.recv(16))
                                      s.close()
                                      log("socket closed")
                                      lte.disconnect()
                                      log("disconnected")
                                      lte.dettach()
                                      log("dettached")
                                      lte.deinit()
                                      log("deinit")
                                  except Exception as ex:
                                      sys.print_exception(ex)
                                      sys.exit()
                                panda
                                With this latest version on a GPy and latest CAT M1 modem firmware I can no longer connect with hologram SIM.
                                lte.connect() will dettach the modem and the REPL input hangs.
                                Previously I could successfully do:
                                lte = LTE('verizon')
                                lte.connect(cid=3)
                                Going back to 1.18.1.r1 and 38638 modem fw works fine. Why would this change? How do I connect to Hologram with the latest updates?
                                The creg info is:
                                ['+CEREG: 2,5,"3D03","00F0F703",7', 'OK']
                                • X Offline
                                  Xykon administrators
                                  Thanks everyone for the reports.
                                  @iwahdan is looking into the SSL issue as this doesn't seem to be directly related to the LTE changes I made.
                                  @panda Unfortunately we don't have hologram.io in The Netherlands so all I can do is emulate Verizon on our Amarisoft eNB.
                                  Could you please try the following 3 commands between attach and connect?
                                  print(lte.send_at_cmd('AT+CGATT?'))
                                  print(lte.send_at_cmd('AT+CFUN?'))
                                  print(lte.send_at_cmd('AT!="showphy"'))
                                  You mention that the REPL input hangs after connect()... if you do a hard reset does it keep hanging?
                                  If you are able to reset the module and enter code, can you please run the 3 commands again without calling attach first?
                                  Christian Ehlers
                                    panda @Xykon
                                    @xykon said in New LTE Firmware releases v1.18.1.r4 (stable) & 1.19.0.b5 (development) & NB-IoT firmware 40343:
                                    text
                                    ['+CGATT: 1', 'OK']
                                    ['+CFUN: 1', 'OK']
                                    ['DL SYNCHRO STATISTICS', '=====================', ' Synchro state : DRX_SLEEP', ' PPU SIB1 ACQ watchdog : 0', ' Frequency Hypothesis RF (Hz) : 0', ' RSRP (dBm) : -94.06', ' RSRQ (dB) : -10.79', ' Channel estimation state (Cell-spec.) : HIGH CINR', ' Channel estimation state (UE-spec.) : LOW CINR', ' Channel estimation state (MBSFN) : LOW CINR', ' Channel estimation CINR : 10.10', ' Channel length : SHORT', ' AGC', ' AGC RX gain (dB) : 53.71', ' RX PSD BO (dBFs) : -20.63', ' RX PSD (dBm) : -99.33', ' Noise level RS (dBm) : -104.16', ' Digital gain (dB) : 9.03', ' CINR RS (dB) : 10.10', ' NARROWBANDS', ' Last DL NB : Central', ' Last UL NB : N/A', ' AFC', ' Frequency offset RF (Hz) : -316', ' Frequency offset BB (Hz) : 0', ' PBCH', ' MIB received quantity : 1239', ' MIB timeout quantity : 0', 'OK']
                                    No, reset solves it.
                                    ['+CGATT: 0', 'OK']
                                    ['+CFUN: 4', 'OK']
                                    ['DL SYNCHRO STATISTICS', '=====================', ' Synchro state : OFF', ' PPU SIB1 ACQwatchdog : 0', ' Frequency Hypothesis RF (Hz) : 0', ' RSRP (dBm) : 0.00', ' RSRQ (dB) : 0.00', ' Channel estimation state (Cell-spec.) : LOW CINR',' Channel estimation state (UE-spec.) : LOW CINR', ' Channel estimation state (MBSFN) : LOW CINR', ' Channel estimation CINR : 0.00', ' Channel length : SHORT', ' AGC', ' AGC RX gain (dB) : 0.00', ' RX PSD BO (dBFs) : 0.00', ' RX PSD (dBm) : 0.00', ' Noise level RS (dBm) : 0.00', ' Digital gain (dB) : 0.00', ' CINR RS (dB) : 0.00', ' NARROWBANDS', ' Last DL NB :0', ' Last UL NB : 0', ' AFC', ' Frequency offset RF (Hz) : 0', ' Frequency offset BB (Hz) : 0', ' PBCH', ' MIB received quantity : 0', ' MIB timeout quantity : 0', 'OK']
                                    • I Offline
                                      iwahdan @tlanier
                                      Hi @tlanier ,I am not able to reproduce the stack overflow issue you got yet, however I've made some improvements to LTE and sockets in a pre-release v1.18.1.r5 :
                                      https://github.com/pycom/pycom-micropython-sigfox/releases/tag/v1.18.1.r5
                                      maybe you can see if that solves the problem.
                                      Wahdan
                                        danielm @iwahdan
                                        @iwahdan
                                        I am testing 1.18.1.r5 on FiPy with NB1-40343 running following code in main.py:
                                        import network
                                        import urequests
                                        class httpPostTest():
                                        	def __init__(self):
                                        		self.apn = None
                                        		self.band = None
                                        		self.LTEisAttached = False
                                        		self.LTEisAttachedLast = False
                                        		self.LTEisConnected = False
                                        		self.LTEisConnectedLast = False
                                        		self.start = True
                                        	def initLTE(self, band, apn):
                                        		self.apn = apn
                                        		self.band = band
                                        		print("INFO", "Starting initialization of LTE")
                                        		try:
                                        			self.lte = network.LTE()
                                        			print("INFO", "LTE initialized")
                                        		except:
                                        			print("WARNING", "LTE init command failed")
                                        		print("LTE is attached after init:", self.lte.isattached())
                                        		print("LTE is connected after init:", self.lte.isconnected())
                                        	def run(self, url):
                                        		n = 0
                                        			self.LTEisAttached = self.lte.isattached()
                                        			if not self.LTEisAttached and (self.LTEisAttachedLast or self.start):
                                        				if not self.start:
                                        					print("WARNING", "Dettached from LTE network")
                                        				try:
                                        					self.lte.attach(band = self.band, apn = self.apn)
                                        					print("INFO", "LTE attach command sent")
                                        					self.start = False
                                        				except:
                                        					print("WARNING", "LTE attach command failed")
                                        			if self.LTEisAttached and not self.LTEisAttachedLast:
                                        				print("INFO", "Attached to LTE network")
                                        				try:
                                        					self.lte.connect()
                                        					print("INFO", "LTE connect command sent")
                                        				except:
                                        					print("WARNING", "LTE connect command failed")
                                        			self.LTEisAttachedLast = self.LTEisAttached
                                        			self.LTEisConnected = self.lte.isconnected()
                                        			if self.LTEisConnected and not self.LTEisConnectedLast:
                                        				print("INFO", "Connected to LTE network")
                                        			elif not self.LTEisConnected and self.LTEisConnectedLast:
                                        				print("WARNING", "Disconnected from LTE network")
                                        			self.LTEisConnectedLast = self.LTEisConnected
                                        			if self.LTEisConnected:
                                        				n+=1
                                        				try:
                                        					response = urequests.post(url, headers={"Content-Type": "application/json", "Accept": "application/json"}, data='{"time": "%s"}' % (time.time()))
                                        					print("INFO", "%s. HTTP POST successful: %s" % (n, response.text))
                                        				except Exception as e:
                                        					print("WARNING", "%s. HTTP POST failed: %s" % (n, e))
                                        			time.sleep(0.25)
                                        test = httpPostTest()
                                        test.initLTE(20, "nbiot.telekom.sk")
                                        test.run(url = "https://54.167.116.227/post")
                                        It is also available here for download including slightly modified urequests library:
                                        https://drive.google.com/open?id=19hA2KGq4iwkkv36d2cuW1M4j0Tab9_YP
                                        Issues:
                                        1. The code often hangs during LTE initialization (self.lte = network.LTE())
                                        2. If it makes it through init only first request is sent successfully and then the modem seems to dettach from the network:
                                        INFO Starting initialization of LTE
                                        INFO LTE initialized
                                        LTE is attached after init: False
                                        LTE is connected after init: False
                                        INFO LTE attached command sent
                                        INFO Attached to LTE network
                                        INFO LTE connect command sent
                                        INFO Connected to LTE network
                                        INFO 1. HTTP POST successful: {"args":{},"data":{"time":"13"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","host":"54.167.116.227","content-length":"14","accept":"application/json","content-type":"application/json","x-forwarded-port":"443"},"json":{"time":"13"},"url":"https://54.167.116.227/post"}
                                        WARNING 2. HTTP POST failed: Avialable Interfaces are down
                                        WARNING Dettached from LTE network
                                        Application code written for our product behaves in a similar way since 1.18.1.r3.
                                          danielm
                                          In the meantime I left the test code running on 1.18.1.r2 with NB1-40343 modem firmware.
                                          It was necessary to replace line
                                          with:
                                          self.lte.send_at_cmd('AT+CGDCONT=1,"IP","%s"' % (self.apn))
                                          self.lte.attach(band = self.band)
                                          because lte.attach() does not support "apn" parameter in 1.18.1.r2.
                                          After almost 5000 requests the test failed with error codes as follows:
                                          INFO 4866. HTTP POST successful: {"args":{},"data":{"time":"41384"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","host":"54.167.116.227","content-length":"17","accept":"application/json","content-type":"application/json","x-forwarded-port":"443"},"json":{"time":"41384"},"url":"https://54.167.116.227/post"}
                                          INFO 4867. HTTP POST successful: {"args":{},"data":{"time":"41392"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","host":"54.167.116.227","content-length":"17","accept":"application/json","content-type":"application/json","x-forwarded-port":"443"},"json":{"time":"41392"},"url":"https://54.167.116.227/post"}
                                          INFO 4868. HTTP POST successful: {"args":{},"data":{"time":"41399"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","host":"54.167.116.227","content-length":"17","accept":"application/json","content-type":"application/json","x-forwarded-port":"443"},"json":{"time":"41399"},"url":"https://54.167.116.227/post"}
                                          WARNING 4869. HTTP POST failed: -76
                                          WARNING 4870. HTTP POST failed: -1
                                          WARNING 4871. HTTP POST failed: -1
                                          WARNING 4872. HTTP POST failed: -1
                                          WARNING 4873. HTTP POST failed: -1
                                          WARNING 4874. HTTP POST failed: -1
                                          WARNING 4875. HTTP POST failed: -1
                                          WARNING 4876. HTTP POST failed: -1
                                          WARNING 4877. HTTP POST failed: -1
                                          WARNING 4878. HTTP POST failed: -1
                                          WARNING 4879. HTTP POST failed: 23
                                          WARNING 4880. HTTP POST failed: 23
                                          WARNING 4881. HTTP POST failed: 23
                                          WARNING 4882. HTTP POST failed: 23
                                          WARNING 4883. HTTP POST failed: 23
                                          WARNING 4884. HTTP POST failed: 23
                                          WARNING 10843. HTTP POST failed: 23
                                          WARNING 10844. HTTP POST failed: 23
                                          WARNING 10845. HTTP POST failed: 23
                                          WARNING 10846. HTTP POST failed: [Errno 105] ENOBUFS
                                          WARNING 10847. HTTP POST failed: [Errno 105] ENOBUFS
                                          WARNING 10848. HTTP POST failed: [Errno 105] ENOBUFS
                                          Methods lte.isattached() and lte.isconnected() returned True during entire test period.
                                          After Ctrl-F reset (without power supply disconnection) it was not possible to init LTE (from REPL). I upgraded Pycom FW to 1.18.1.r5 via FTP OTA an LTE init failed as well.
                                            danielm
                                            @Xykon @iwahdan
                                            I would appreciate feedback on my previous two posts.
                                            LTE implementation in 1.18.1.r3 to 1.18.1.r5 works worse than in 1.18.1.r2. Testing code is provided, you may check yourself.
                                            • 1 / 3
