    New LTE Firmware releases v1.18.1.r4 (stable) & 1.19.0.b5 (development) & NB-IoT firmware 40343
    firmwarelte
    51 Posts 12 Posters 11.9k Views 14 Watching
      tlanier @tlanier
      @tlanier
      I'm now successfully connecting and downloading from a non-secure site using either LTE or WIFI. The errors occur if I try to connect to a secure site (www.google.com) using either LTE or WIFI.
      # TEST - uses cell modem
      def get1():
          try:
              log('creating LTE object - carrier verizon')
              # lte = LTE()
              lte = LTE(carrier="verizon")
              # lte = LTE(carrier="at&t")         # instantiate the LTE object
              log('resetting modem, may take up to 5 secs...')
              lte.reset()
              log('attaching...')
              lte.attach(apn='apn.hologram.io')        # attach the cellular modem to a base station
              # lte.attach(band=13)        # attach the cellular modem to a base station
              i = 0
              while not lte.isattached():
                  log('waiting for isattached...')
                  utime.sleep_ms(1000)
              log('connecting...')
              # lte.connect()       # start a data session and obtain an IP address
              lte.connect(cid=3)    # cid=3 for verizon - start a data session and obtain an IP address
              while not lte.isconnected():
                  log('waiting for isconnected...')
                  utime.sleep_ms(500)
              log('create socket')
              s = socket.socket()
              log("Connect to: www.ces-web.com")
              sockaddr = socket.getaddrinfo('www.ces-web.com', 80)[0][-1]
              #log("Connect to: www.google.com")
              #s = ssl.wrap_socket(s)
              #sockaddr = socket.getaddrinfo('www.google.com', 443)[0][-1]
              log("socket address: {}".format(sockaddr))
              s.connect(sockaddr)
              log("send GET request")
              s.send(b"GET / HTTP/1.0\r\n\r\n")
              log("receive response")
              log(s.recv(16))
              s.close()
              log("socket closed")
              lte.disconnect()
              log("disconnected")
              lte.dettach()
              log("dettached")
              lte.deinit()
              log("deinit")
          except Exception as ex:
              sys.print_exception(ex)
              sys.exit()
        panda
        With this latest version on a GPy and latest CAT M1 modem firmware I can no longer connect with hologram SIM.
        lte.connect() will dettach the modem and the REPL input hangs.
        Previously I could successfully do:
        lte = LTE('verizon')
        lte.connect(cid=3)
        Going back to 1.18.1.r1 and 38638 modem fw works fine. Why would this change? How do I connect to Hologram with the latest updates?
        The creg info is:
        ['+CEREG: 2,5,"3D03","00F0F703",7', 'OK']
        • X Offline
          Xykon administrators
          Thanks everyone for the reports.
          @iwahdan is looking into the SSL issue as this doesn't seem to be directly related to the LTE changes I made.
          @panda Unfortunately we don't have hologram.io in The Netherlands so all I can do is emulate Verizon on our Amarisoft eNB.
          Could you please try the following 3 commands between attach and connect?
          print(lte.send_at_cmd('AT+CGATT?'))
          print(lte.send_at_cmd('AT+CFUN?'))
          print(lte.send_at_cmd('AT!="showphy"'))
          You mention that the REPL input hangs after connect()... if you do a hard reset does it keep hanging?
          If you are able to reset the module and enter code, can you please run the 3 commands again without calling attach first?
          Christian Ehlers
            panda @Xykon
            @xykon said in New LTE Firmware releases v1.18.1.r4 (stable) & 1.19.0.b5 (development) & NB-IoT firmware 40343:
            text
            ['+CGATT: 1', 'OK']
            ['+CFUN: 1', 'OK']
            ['DL SYNCHRO STATISTICS', '=====================', ' Synchro state : DRX_SLEEP', ' PPU SIB1 ACQ watchdog : 0', ' Frequency Hypothesis RF (Hz) : 0', ' RSRP (dBm) : -94.06', ' RSRQ (dB) : -10.79', ' Channel estimation state (Cell-spec.) : HIGH CINR', ' Channel estimation state (UE-spec.) : LOW CINR', ' Channel estimation state (MBSFN) : LOW CINR', ' Channel estimation CINR : 10.10', ' Channel length : SHORT', ' AGC', ' AGC RX gain (dB) : 53.71', ' RX PSD BO (dBFs) : -20.63', ' RX PSD (dBm) : -99.33', ' Noise level RS (dBm) : -104.16', ' Digital gain (dB) : 9.03', ' CINR RS (dB) : 10.10', ' NARROWBANDS', ' Last DL NB : Central', ' Last UL NB : N/A', ' AFC', ' Frequency offset RF (Hz) : -316', ' Frequency offset BB (Hz) : 0', ' PBCH', ' MIB received quantity : 1239', ' MIB timeout quantity : 0', 'OK']
            No, reset solves it.
            ['+CGATT: 0', 'OK']
            ['+CFUN: 4', 'OK']
            ['DL SYNCHRO STATISTICS', '=====================', ' Synchro state : OFF', ' PPU SIB1 ACQwatchdog : 0', ' Frequency Hypothesis RF (Hz) : 0', ' RSRP (dBm) : 0.00', ' RSRQ (dB) : 0.00', ' Channel estimation state (Cell-spec.) : LOW CINR',' Channel estimation state (UE-spec.) : LOW CINR', ' Channel estimation state (MBSFN) : LOW CINR', ' Channel estimation CINR : 0.00', ' Channel length : SHORT', ' AGC', ' AGC RX gain (dB) : 0.00', ' RX PSD BO (dBFs) : 0.00', ' RX PSD (dBm) : 0.00', ' Noise level RS (dBm) : 0.00', ' Digital gain (dB) : 0.00', ' CINR RS (dB) : 0.00', ' NARROWBANDS', ' Last DL NB :0', ' Last UL NB : 0', ' AFC', ' Frequency offset RF (Hz) : 0', ' Frequency offset BB (Hz) : 0', ' PBCH', ' MIB received quantity : 0', ' MIB timeout quantity : 0', 'OK']
            • I Offline
              iwahdan @tlanier
              Hi @tlanier ,I am not able to reproduce the stack overflow issue you got yet, however I've made some improvements to LTE and sockets in a pre-release v1.18.1.r5 :
              https://github.com/pycom/pycom-micropython-sigfox/releases/tag/v1.18.1.r5
              maybe you can see if that solves the problem.
              Wahdan
                danielm @iwahdan
                @iwahdan
                I am testing 1.18.1.r5 on FiPy with NB1-40343 running following code in main.py:
                import network
                import urequests
                class httpPostTest():
                	def __init__(self):
                		self.apn = None
                		self.band = None
                		self.LTEisAttached = False
                		self.LTEisAttachedLast = False
                		self.LTEisConnected = False
                		self.LTEisConnectedLast = False
                		self.start = True
                	def initLTE(self, band, apn):
                		self.apn = apn
                		self.band = band
                		print("INFO", "Starting initialization of LTE")
                		try:
                			self.lte = network.LTE()
                			print("INFO", "LTE initialized")
                		except:
                			print("WARNING", "LTE init command failed")
                		print("LTE is attached after init:", self.lte.isattached())
                		print("LTE is connected after init:", self.lte.isconnected())
                	def run(self, url):
                		n = 0
                			self.LTEisAttached = self.lte.isattached()
                			if not self.LTEisAttached and (self.LTEisAttachedLast or self.start):
                				if not self.start:
                					print("WARNING", "Dettached from LTE network")
                				try:
                					self.lte.attach(band = self.band, apn = self.apn)
                					print("INFO", "LTE attach command sent")
                					self.start = False
                				except:
                					print("WARNING", "LTE attach command failed")
                			if self.LTEisAttached and not self.LTEisAttachedLast:
                				print("INFO", "Attached to LTE network")
                				try:
                					self.lte.connect()
                					print("INFO", "LTE connect command sent")
                				except:
                					print("WARNING", "LTE connect command failed")
                			self.LTEisAttachedLast = self.LTEisAttached
                			self.LTEisConnected = self.lte.isconnected()
                			if self.LTEisConnected and not self.LTEisConnectedLast:
                				print("INFO", "Connected to LTE network")
                			elif not self.LTEisConnected and self.LTEisConnectedLast:
                				print("WARNING", "Disconnected from LTE network")
                			self.LTEisConnectedLast = self.LTEisConnected
                			if self.LTEisConnected:
                				n+=1
                				try:
                					response = urequests.post(url, headers={"Content-Type": "application/json", "Accept": "application/json"}, data='{"time": "%s"}' % (time.time()))
                					print("INFO", "%s. HTTP POST successful: %s" % (n, response.text))
                				except Exception as e:
                					print("WARNING", "%s. HTTP POST failed: %s" % (n, e))
                			time.sleep(0.25)
                test = httpPostTest()
                test.initLTE(20, "nbiot.telekom.sk")
                test.run(url = "https://54.167.116.227/post")
                It is also available here for download including slightly modified urequests library:
                https://drive.google.com/open?id=19hA2KGq4iwkkv36d2cuW1M4j0Tab9_YP
                Issues:
                1. The code often hangs during LTE initialization (self.lte = network.LTE())
                2. If it makes it through init only first request is sent successfully and then the modem seems to dettach from the network:
                INFO Starting initialization of LTE
                INFO LTE initialized
                LTE is attached after init: False
                LTE is connected after init: False
                INFO LTE attached command sent
                INFO Attached to LTE network
                INFO LTE connect command sent
                INFO Connected to LTE network
                INFO 1. HTTP POST successful: {"args":{},"data":{"time":"13"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","host":"54.167.116.227","content-length":"14","accept":"application/json","content-type":"application/json","x-forwarded-port":"443"},"json":{"time":"13"},"url":"https://54.167.116.227/post"}
                WARNING 2. HTTP POST failed: Avialable Interfaces are down
                WARNING Dettached from LTE network
                Application code written for our product behaves in a similar way since 1.18.1.r3.
                  danielm
                  In the meantime I left the test code running on 1.18.1.r2 with NB1-40343 modem firmware.
                  It was necessary to replace line
                  with:
                  self.lte.send_at_cmd('AT+CGDCONT=1,"IP","%s"' % (self.apn))
                  self.lte.attach(band = self.band)
                  because lte.attach() does not support "apn" parameter in 1.18.1.r2.
                  After almost 5000 requests the test failed with error codes as follows:
                  INFO 4866. HTTP POST successful: {"args":{},"data":{"time":"41384"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","host":"54.167.116.227","content-length":"17","accept":"application/json","content-type":"application/json","x-forwarded-port":"443"},"json":{"time":"41384"},"url":"https://54.167.116.227/post"}
                  INFO 4867. HTTP POST successful: {"args":{},"data":{"time":"41392"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","host":"54.167.116.227","content-length":"17","accept":"application/json","content-type":"application/json","x-forwarded-port":"443"},"json":{"time":"41392"},"url":"https://54.167.116.227/post"}
                  INFO 4868. HTTP POST successful: {"args":{},"data":{"time":"41399"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","host":"54.167.116.227","content-length":"17","accept":"application/json","content-type":"application/json","x-forwarded-port":"443"},"json":{"time":"41399"},"url":"https://54.167.116.227/post"}
                  WARNING 4869. HTTP POST failed: -76
                  WARNING 4870. HTTP POST failed: -1
                  WARNING 4871. HTTP POST failed: -1
                  WARNING 4872. HTTP POST failed: -1
                  WARNING 4873. HTTP POST failed: -1
                  WARNING 4874. HTTP POST failed: -1
                  WARNING 4875. HTTP POST failed: -1
                  WARNING 4876. HTTP POST failed: -1
                  WARNING 4877. HTTP POST failed: -1
                  WARNING 4878. HTTP POST failed: -1
                  WARNING 4879. HTTP POST failed: 23
                  WARNING 4880. HTTP POST failed: 23
                  WARNING 4881. HTTP POST failed: 23
                  WARNING 4882. HTTP POST failed: 23
                  WARNING 4883. HTTP POST failed: 23
                  WARNING 4884. HTTP POST failed: 23
                  WARNING 10843. HTTP POST failed: 23
                  WARNING 10844. HTTP POST failed: 23
                  WARNING 10845. HTTP POST failed: 23
                  WARNING 10846. HTTP POST failed: [Errno 105] ENOBUFS
                  WARNING 10847. HTTP POST failed: [Errno 105] ENOBUFS
                  WARNING 10848. HTTP POST failed: [Errno 105] ENOBUFS
                  Methods lte.isattached() and lte.isconnected() returned True during entire test period.
                  After Ctrl-F reset (without power supply disconnection) it was not possible to init LTE (from REPL). I upgraded Pycom FW to 1.18.1.r5 via FTP OTA an LTE init failed as well.
                    danielm
                    @Xykon @iwahdan
                    I would appreciate feedback on my previous two posts.
                    LTE implementation in 1.18.1.r3 to 1.18.1.r5 works worse than in 1.18.1.r2. Testing code is provided, you may check yourself.
                      Paul Thornton
                      Hi All,
                      Due to moving office's and limited internet access the development team are unable to investigate the LTE issues at the moment. Thanks for being patient whilst we work on this.
                      @danielm Ill make sure they see your response and take a look just as soon as they can.
                      Paul T,
                        robert-hh @Paul Thornton
                        @paul-thornton Hello Paul. Welcome to the community.
                          Paul Thornton @robert-hh
                          Thanks :D Ill make a proper introduction post soon. I just snuck on to post this and get you all updated. Look forward to getting stuck in the forums some cool projects being worked on in here. :)
                            danielm @Paul Thornton
                            @paul-thornton
                            Hi Paul, thanks for the information regarding moving of the office.
                              combaindeft
                              @Xykon ... the new firmware doesn't work with Telia NB-IOT in sweden :-( ... cannot attach anymore ...
                              I tried to just use the "update" dup ... but I'm trying now to use the total reset method and see if that helps ... elsewise I'll be downgrading back to the previous version that worked ...
                              • W Offline
                                wghirakawa
                                I was having major problems, with trying to do the update using v1.18.1.r4 and using the FW package 39529. After following multiple recommendations from other FiPy Users, as well as trying to do the method as described in the Docs, it was to no avail. Then I viewed @rskoniec post at https://forum.pycom.io/topic/3995/fipy-firmware-upgrade-failed-cat-m1/26 showed me a potential way of getting my FW at least to 38638. But after attempting downgrading my FiPy Firmware to v1.18.1.r1 and trying to upgrade to 38638 it just was not happening. It kept getting stuck on Attempting AT Auto-Negotiation, then it would eventually fail.
                                ERROR sending AT command... no response? b''
                                AT auto-negotiation failed! Exiting.
                                Unable to load updater from /sd/updater.elf
                                @rskoniec was kind enough to remotely connect to my computer and we spent roughly 3 hours trying to do the firmware upgrade to the SQNS Modem. @rskoniec knows exactly what he did, and will be replying to this post with how he was able to get my firmware on my modem upgraded. As it stands I have a FiPY + Pytrack and my sqnsupgrade.version() is as bellow.
                                SYSTEM VERSION
                                  FIRMWARE VERSION
                                    Bootloader0  : 5.1.1.0 [33080]
                                    Bootloader1  : 5.1.1.0 [38638]
                                    Bootloader2* : 5.1.1.0 [38638]
                                    NV Info      : 1.1,0,0
                                    Software     : 5.1.1.0 [38638] by robot-soft at 2018-08-20 09:51:46
                                    UE           : 5.0.0.0d
                                  COMPONENTS
                                    ZSP0         : 1.0.99-13604
                                    ZSP1         : 1.0.99-12341
                                I will be attempting to upgrade to the newest SQNS Firmware after updating the FiPy to r4. I will attempt upgrading to 39529 using the method as described in the forum, and will post my results.
                                I cannot thank @rskoniec enough for the time he dedicated to help another developer! I hope that my post will save others valuable time, especially during this holiday season.
                                If everyone in the world could do their passion, the world would be an unbelievable place!
                                W 1 Reply Last reply Reply Quote 1
                                • I Offline
                                  iwahdan @danielm
                                  @danielm said in New LTE Firmware releases v1.18.1.r4 (stable) & 1.19.0.b5 (development) & NB-IoT firmware 40343:
                                  Hello @danielm , I could reproduce the issue you had with getting disconnected after the first HTTP post request I submitted a fix now for it as pre-release v1.18.1.r6.
                                  Thanks for your feedback
                                  Wahdan
                                  • W Offline
                                    wghirakawa @wghirakawa
                                    After upgrading the FiPy Firware to v1.18.1.r4 I attempted to follow the instructions on the forum to ugprade to 39529. Using the following method.
                                    1. Use Filezilla to transfer upgdiff_38638-to-39529.dup and updater.elf to flash memory.
                                    2. Executed the following in the REPL
                                    import sqnsupgrade
                                    sqnsupgrade.run('upgdiff_38638-to-39529.dup','updater.elf')
                                    which ultimately resulted in the successful upgrade of my SQNS Modem Firmware to the version info below.
                                    SYSTEM VERSION
                                      FIRMWARE VERSION
                                        Bootloader0  : 5.1.1.0 [39529]
                                        Bootloader1* : 5.1.1.0 [39529]
                                        Bootloader2  : 5.1.1.0 [39529]
                                        NV Info      : 1.1,0,0
                                        Software     : 5.1.1.0 [39529] by robot-soft at 2018-09-28 16:07:40
                                        UE           : 5.0.0.0d
                                      COMPONENTS
                                        ZSP0         : 1.0.99-13616
                                        ZSP1         : 1.0.99-12355
                                      danielm @iwahdan
                                      @iwahdan
                                      Thanks a lot, I will start testing in the evening or tomorrow.
                                      Could you please let my test code running on 1.18.1.r6 over the weekend just to be sure that there will not be any unexpected hang?
                                        danielm @iwahdan
                                        @iwahdan
                                        I did some testing and it seems that LTE init/disconnect issues are solved.
                                        When I left the test running for some time socket errors/exceptions started to be raised at some point.
                                        INFO 1140. HTTP POST successful: {"args":{},"data":{"time":"10843"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","host":"34.202.13.18","content-length":"17","accept":"application/json","content-type":"application/json","x-forwarded-port":"443"},"json":{"time":"10843"},"url":"https://34.202.13.18/post"}
                                        INFO 1141. HTTP POST successful: {"args":{},"data":{"time":"10858"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","host":"34.202.13.18","content-length":"17","accept":"application/json","content-type":"application/json","x-forwarded-port":"443"},"json":{"time":"10858"},"url":"https://34.202.13.18/post"}
                                        INFO 1142. HTTP POST successful: {"args":{},"data":{"time":"10873"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","host":"34.202.13.18","content-length":"17","accept":"application/json","content-type":"application/json","x-forwarded-port":"443"},"json":{"time":"10873"},"url":"https://34.202.13.18/post"}
                                        INFO 1143. HTTP POST successful: {"args":{},"data":{"time":"10894"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","host":"34.202.13.18","content-length":"17","accept":"application/json","content-type":"application/json","x-forwarded-port":"443"},"json":{"time":"10894"},"url":"https://34.202.13.18/post"}
                                        INFO 1144. HTTP POST successful: {"args":{},"data":{"time":"10936"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","host":"34.202.13.18","content-length":"17","accept":"application/json","content-type":"application/json","x-forwarded-port":"443"},"json":{"time":"10936"},"url":"https://34.202.13.18/post"}
                                        WARNING 1145. HTTP POST failed: -76
                                        WARNING 1146. HTTP POST failed: -1
                                        WARNING 1147. HTTP POST failed: -1
                                        WARNING 1148. HTTP POST failed: -1
                                        WARNING 1149. HTTP POST failed: -1
                                        WARNING 1150. HTTP POST failed: -1
                                        WARNING 1151. HTTP POST failed: -1
                                        WARNING 1152. HTTP POST failed: -1
                                        WARNING 1153. HTTP POST failed: -1
                                        WARNING 1154. HTTP POST failed: -1
                                        WARNING 1155. HTTP POST failed: 23
                                        WARNING 1156. HTTP POST failed: 23
                                        WARNING 1157. HTTP POST failed: 23
                                        WARNING 1158. HTTP POST failed: 23
                                        WARNING 1159. HTTP POST failed: 23
                                        WARNING 1160. HTTP POST failed: 23
                                        WARNING 1161. HTTP POST failed: 23
                                        WARNING 1162. HTTP POST failed: 23
                                        WARNING 7130. HTTP POST failed: 23
                                        WARNING 7131. HTTP POST failed: 23
                                        WARNING 7132. HTTP POST failed: 23
                                        WARNING 7133. HTTP POST failed: 23
                                        WARNING 7134. HTTP POST failed: 23
                                        WARNING 7135. HTTP POST failed: [Errno 105] ENOBUFS
                                        WARNING 7136. HTTP POST failed: [Errno 105] ENOBUFS
                                        WARNING 7137. HTTP POST failed: [Errno 105] ENOBUFS
                                        WARNING 7138. HTTP POST failed: [Errno 105] ENOBUFS
                                        WARNING 7139. HTTP POST failed: [Errno 105] ENOBUFS
                                        WARNING 7140. HTTP POST failed: [Errno 105] ENOBUFS
                                        WARNING 10758. HTTP POST failed: [Errno 105] ENOBUFS
                                        WARNING 10759. HTTP POST failed: [Errno 105] ENOBUFS
                                        WARNING 10760. HTTP POST failed: [Errno 105] ENOBUFS
                                        WARNING 10761. HTTP POST failed: [Errno 105] ENOBUFS
                                        WARNING 10762. HTTP POST failed: [Errno 105] ENOBUFS
                                        WARNING 10763. HTTP POST failed: [Errno 105] ENOBUFS
                                        WARNING 10764. HTTP POST failed: [Errno 105] ENOBUFS
                                        The code was hanged at 10764. POST attempt. It was not possible to break the loop using Ctrl + C, but it was possible to reset the machine using Ctrl+F.
                                        After soft-reset POST attempts were unsuccessful as well. LTE dettach attempt resulted in OSError, however the modem did dettach. After consequent machine.reset() POST requests worked. It seems that after several hundreds socket creations the modem starts to act weirdly.
                                        configsip: 0, SPIWP:0xee
                                        mode:DIO, clock div:1
                                        load:0x3fff8028,len:8
                                        load:0x3fff8030,len:1728
                                        load:0x4009fa00,len:0
                                        load:0x4009fa00,len:14584
                                        entry 0x400a059c
                                        LTE is attached after init: True
                                        WARNING 1. HTTP POST failed: -1
                                        WARNING 2. HTTP POST failed: -1
                                        WARNING 3. HTTP POST failed: -1
                                        WARNING 4. HTTP POST failed: -1
                                        WARNING 5. HTTP POST failed: -1
                                        WARNING 6. HTTP POST failed: -1
                                          File "main.py", line 78, in <module>
                                          File "main.py", line 70, in run
                                        KeyboardInterrupt:
                                        Pycom MicroPython 1.18.1.r6 [v1.8.6-849-a8966d1] on 2018-11-23; FiPy with ESP32
                                        >>> test.lte
                                        <LTE>
                                        >>> test.lte.dettach()
                                        >>> test.lte.isattached()
                                        False
                                        >>> import machine
                                        >>> machine.reset()
                                        ets Jun  8 2016 00:22:57
                                        entry 0x400a059c
                                        INFO LTE attach command sent
                                        INFO 1. HTTP POST successful: {"args":{},"data":{"time":"69"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","host":"34.202.13.18","content-length":"14","accept":"application/json","content-type":"application/json","x-forwarded-port":"443"},"json":{"time":"69"},"url":"https://34.202.13.18/post"}
                                        INFO 2. HTTP POST successful: {"args":{},"data":{"time":"77"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","host":"34.202.13.18","content-length":"14","accept":"application/json","content-type":"application/json","x-forwarded-port":"443"},"json":{"time":"77"},"url":"https://34.202.13.18/post"}
                                        INFO 3. HTTP POST successful: {"args":{},"data":{"time":"87"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","host":"34.202.13.18","content-length":"14","accept":"application/json","content-type":"application/json","x-forwarded-port":"443"},"json":{"time":"87"},"url":"https://34.202.13.18/post"}
                                        INFO 4. HTTP POST successful: {"args":{},"data":{"time":"95"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","host":"34.202.13.18","content-length":"14","accept":"application/json","content-type":"application/json","x-forwarded-port":"443"},"json":{"time":"95"},"url":"https://34.202.13.18/post"}
                                        INFO 5. HTTP POST successful: {"args":{},"data":{"time":"103"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","host":"34.202.13.18","content-length":"15","accept":"application/json","content-type":"application/json","x-forwarded-port":"443"},"json":{"time":"103"},"url":"https://34.202.13.18/post"}
                                        INFO 6. HTTP POST successful: {"args":{},"data":{"time":"111"},"files":{},"form":{},"headers":{"x-forwarded-proto":"https","host":"34.202.13.18","content-length":"15","accept":"application/json","content-type":"application/json","x-forwarded-port":"443"},"json":{"time":"111"},"url":"https://34.202.13.18/post"}
                                        During tests with 1.18.1.r2 long-term test did behave in a similar way:
                                        https://forum.pycom.io/topic/3985/new-lte-firmware-releases-v1-18-1-r4-stable-1-19-0-b5-development-nb-iot-firmware-40343/22
                                        Exception value of first failed POST request was -76 in both tests. What does it mean?
                                        • I Offline
                                          iwahdan @danielm
                                          @danielm this error code is :
                                          #define MBEDTLS_ERR_NET_RECV_FAILED -0x004C /**< Reading information from the socket failed. */
                                          So these socket errors you get I think occurs when using ssl, did you have same problem with posting to non-secure site?
                                          Anyway I am also running your code over the weekend via our NB-IoT network emulator , I will see if I get same errors as yours.
                                          Wahdan
                                            danielm @iwahdan
                                            @iwahdan
                                            I just started the same test without SSL and will leave it running during the night.
                                            Thank you for conducting tests in your environment.
                                            Where can I find list of socket exceptions?
                                            • 2 / 3
